Question about Sylvania G-Netbook
G netbook cursor moves way too fast but i find no way to slow it down. apparently the solution is not in the help file.
  • 748 Answers
The touchpad is very small on this netbook, so the ratio between the finger movement and cursor movement has to be high in order to be able to move the cursor from one side of the screen to the opposite.
The cursor cannot be too slow, because you would have to glide the finger several times on the touchpad to move it across the whole screen.
However, the speed of the cursor can be adjusted in the mouse properties in Control Panel (Start->Settings->Control Panel->Mouse) in the Pointer Options tab. Experiment with different settings to find one that suits you.
With such small touchpad I would suggest forming a habit of rocking the finger on the touchpad to achieve better precision and control, instead of sliding it. Put a finger on the touchpad center and tilt it left/right, up/down - You'll see that the cursor can be controlled quite well this way. And if you need a larger movement, then it's enough to move the finger the normal way.
Good luck and please come back with a rating/testimonial if helped.
Posted on Aug 01, 2010
Eveytime i navigate ....it talkes time because my cursor keeps spinning??
Its a slow pc having less ram and cache, however take a few steps that may help you in fast start up:
Keep your task bar and tray free of the extra programs which cause slowing down your pc and all other animations too
Sep 14, 2011 | HP Pavilion dv6000z Notebook
My netbook is generally running very slow,what can I do to improve speed
Hi
To speedup your netbook follow these steps;
1. Remove if any apps in the 'startup' (like instant messaging, dictionary, world clock openoffice etc (just remove it from the startup folder) Make sure programs like these are not starting up when you boot up else your netbook will feel slow.
2. Be sure that you are running your spyware and virus scanners are working, updated, and have fully scanned your system. These malicious pieces of software can slow down a fast system. They will wreck the speed on your netbook if you aren't careful.
3. One upgrade that you can do to your system that is cheap and easy to do on your own is to add RAM. It's best to maximize your netbook's RAM for best performance.
4. Uninstall unwanted or heavy load softwares.
5. Don't have open programs that you aren't using minimized. If you aren't going to use a program, shut it off. Try to only have a few programs open at once.
6. Use cloud based applications. These are software that you can use that are being processed on a server versus your machine. This is a better way to multitask on your netbook.
7. Consider adding Linux or buying a Linux netbook versus a Windows netbook. Typically the Linux netbooks do run much faster as they are designed to take up less resources making your netbook run much faster.
8. Delete temp files.
9. Running heavy loaded softwares will make the battery hot, that way the battery life is shortened which causes a slow running netbook.
Hope this helps.
Please rate if this solution was helpful, thanks!
Jul 14, 2011 | ASUS Eee PC 900HD Netbook
Slow
Your windows partition should have at least 1GB empty space. More is welcome. If not try to remove the files & transfer them onto another partition. It is recommended not to put your data files on the windows partition. Remove all the files on the desktop & dump them in a separate folder on a partition. Remove any screensaver/ themes with animation that you are using. Keeping files on the desktop slows the laptop. De-fragment your hard disk. Right click on hard disk partitions. Goto disk cleanup. Select the files which are unwanted. Delete temporary internet files, cookies, history accessible from the browser's options. After carrying out these procedures your netbook shall be fast. If not, check your physical memory& the memory shown in system properties. If it does not match then you need to change your affected memory module.
sonsunny
Jul 04, 2011 | Acer Aspire One D255 Netbook
I want to reboot my netbook because its moving slow
If you mean a clean install as in reformat everything and begin from scratch, I'm sorry to tell you that's with netbook it's hard because the CD is not included with the computer.
If you happen to have an XP (for example) installation CD and an USB CD/DVD reader, then it's easy ! just insert the CD and follow the autorun.
If you don't have all these (which is probably the case) the simplest solution is cleaning yourself your computer. To do so : go to control panel and look for program and features (on Vista / 7) or Add/remove programs (on XP) and get rid of everything that you don't need. Then click on this link to download the free version of a cleanup program that takes care of your computer. It's quite easy, just install it and then hit the big care button and it should remove small files in your netbook that slows it down.
If it's still not fast enough you might want to find an expert in your area that can reboot it you.
Good luck :)
May 28, 2011 | Acer Aspire One Netbook 8.9" Notebook
The cursor on my laptop is non functioning. The trackpad wont control it at all. If I use a mouse the cursor just jumps around the edges of the page. I cant get to the control panel to try to make...
what OS, please if windows, use CTRL+ESC to activate the menu, find control panel, by using the arrow keys all the way till you get to the control panel also use the enter key to activate. make necessary adjustment
this should resolve it, vote for when if resolved
regards
Mar 24, 2010 | Computers & Internet
My cursor moves but i cant click on my acer aspire 5335
Check the click rate under mouse setting.
The default or the last owner's setting may be too slow/fast for you.
Jul 16, 2009 | Acer Aspire 5610-4648 Notebook
Can i slow down my mouse cursor
Open the Control Panel. Select "Printers and other Hardware". Select "Mouse".
(Note: If you open Control Panel and it is in Classic View, just double-click "Mouse".)
Select the Pointer Options tab. (The exact tab name may differ.)
There should be a slider button to adjust the speed of the mouse. Click OK.
Thanks for using Fixya.
May 12, 2009 | Logitech Cordless Desktop S 510
G netbook cursor speed
Hello my name is Tim Ehrhart, to slow your cursor speed go to controll panel and click mouse, then click pointer options and adjust the pointer speed. I hope this helps you and please leave feedback as I am new and am trying to gain a awesome rep.
Mar 16, 2009 | Sylvania G-Netbook
Speed strip on touch mouse is too sensitive
remove the touch pad software if u have any installed for the touch mousepad
Nov 24, 2008 | Computers & Internet
Sylvania G-Netbook Logo
162 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
