I have a 20pin power supply adapter that reduceses to a(p8) 6wire&(p9)6wire plug that plugs into the mother board of my system.
  • Computers & ... Master
  • 5,660 Answers
Understandable.
A 20-pin ATX main power cable, is converted into two 6-pin AT main power cables, by that adapter.
20-pin ATX main power cable, and it's respective connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
6-pin AT main power cable, and it's respective connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#oldpc
As I'm sure you are aware, the color code of the insulation of those power wires, deems what Voltage they are.
Let's look at charts that compare the older AT main power cable connector, and power wires, to the newer ATX main power cable, and it's power wires,
http://en.wikipedia.org/wiki/Computer_power_supply
Scroll towards the bottom of the page, and look at the comparison charts under the heading - Wiring Diagrams
Now if you would, post back in a Comment, as to what the actual problem is.
Posted on Aug 01, 2010
Dell Dimension 2400 PC Desktop how to wire
Industry standard PC, XT, AT, and LPX motherboards use the same type of main power supply connectors. They use two main power connectors: P8 and P9. Each of the P8 and P9 connectors has 6 pins that connect power supply to the motherboard.
May 29, 2014 | Dell Dimension 2400 PC Desktop
Just replaced the PS and while I have power (thank goodness) I still don't have video and I cannot (stupid me) remember where all the power cables went. I have cabled to the DVD and CD drives, the floppy...
did you put the main plug in the board 20pin or 24 pin cables wire with the white is pin one on dvd cd hardrive power cables or red cd dvd hardrive if your board takes the 4 pin than plug it to the 4pin ok jim
Apr 17, 2011 | Computers & Internet
Power supply pulled from working system about 1.5 years ago. Connected to the previous mother board. On board power LED solid green. Tried to power up, but the light just flickered very fast. Tried...
try 800W power supply? also make sure you connect the big flat multi cable plug and small 4 cable plug into the mother board usually on opposite side of the big plug
Mar 02, 2011 | ASUS A-55GA (A55GAATX550WAPFC) 550-Watt...
I have 20 pin smps that i want use for gigabyte 68 motherboard, i hv amd phenon2 cpu, so can i used 20 pin smps
hello ashwin27_as
my name is ausi.
in most cases yes you can use a 20pin power supply as long as it is powerful enough. for example it is not recommended to use a 500watt power supply 20pin with the kind of system you setting up.
also the main board manual does say if you can or can not.
also there are adapters avilable that turn 20pin to 24pin. i have used them in the past.
hopefully this has been helpful.
good luck and please vote for me
Jan 07, 2011 | Intel Motherboard
Acer one notebook no display and automatic shutdown
= if your laptop computer will not start =
laptops have power supplys that can lock up
the power adapters conectors break all the time
and the batterys are designed to be "con$umable$"
so
- - -- - -- - -power reset - - -- - -- - -- - -
remove the power adapter's wall plug &
leave the power adapter plugged into the computer
but pull the laptop battery out of the laptop.
press the power button just like you are trying to start it
but press it longer, this will drain & reset
the internal supply, now relese the button.
-- - -- - -power adapter only test - - -- - -- - -
reconnect the power adapter's wall plug
press the power button to start it with just the power adapter ,
If the power adapter starts the laptop on its own go down to
"If the computer can be started"
If the power adapter does not start the laptop on its own
leave the power adapter plugged into the computer but
remove the power adapter's wall plug & press the power button
just like you are trying to start it again,
then relese the button
- - -- - - battery only test - - -- - -- - -
unplug the power adapter & put the battery back in
press the power button to start it with just the battery
if the battery starts it on its own go down to
if the battery ALMOST starts it on its own
DO NOT BUY A NEW ONE! it may only be discharged
locate another laptop just like yours and charge it,
and yes this is crazy and yes i am sorry!.
- if your laptop computer cannot start at all -
this can be caused by a bad;
connector ($5-$60), power adapter($5-$60),
battery ($70), internal supply ($40-$90),
or main/mother board ($100-$300)
If the internal power supply is bad or if the
power conector fails at random (intermitant)
most of the cost is determined by how dificult
finding parts and dismantling the laptop is
and if it's external or internal
Jun 05, 2010 | Acer Aspire 5720-6661 Notebook PC
Power supply for compaq persario
it depends on the type of casing you have. alos it will depend on the power connector ( to the motherboard) you have. some are 20Pin & some are 24 pin. make sure you chk this mostly.
Feb 25, 2009 | Astec SA302-3515 (6500165) 300-Watt Power...
Part number: 316809100002-R02
I too have the same power board burnt out ... did anyone ever find the part you was looking for ... Thanks
Nov 20, 2008 | Computers & Internet
No Power of a Compaq Presario Computer
Make sure that the power button is conected to the right prongs on the mother board. On the writing next to the prongs it should say power.
Feb 23, 2008 | Computers & Internet
Computers & Internet Logo
103 people viewed this question
Alun Cox
David Payne
David Payne
