Question about Garmin nuvi 350 GPS Receiver
My satellite wont find a satellite what can i do an how much will it cost to fix it
  • 79lamont Aug 01, 2010
    still the same thing nothing changed what next
    Sergeant:
  • 313 Answers
Have a look though the setting to see if there is a manufactures reset mode (check instructions of go to there web site for help before spending money on it) If you can reset it, this will rest all setting to when it was made. then reload your map and see if it can find the satellites then. Good luck.
Posted on Aug 01, 2010
Toshiba laptop Satellite serial 17147597K
The answer to the cost vs. benefit equation is dump it, especially if is more than 5 years old.
Jan 28, 2014 | Toshiba Satellite Computers & Internet
My adapter is lose and is not making a good connection to charge ...what can i do to fix it ?
If you are not good at tech, you should take it to a tech center to fix it, that will cost your at least $20, so you may replace it with a new charger, buy one from an online store, it is less than $20:
Replacement Toshiba Satellite C655 AC Adapter 75Watt 19V 3.95A
Nov 21, 2012 | Toshiba Satellite C655-S5512 laptop
My dvd/cd-rom wont work. it has a code 39. is this going to cost me it doesnt play movies or music from a cd
That means that the driver has not loaded properly.
Go to www.toshiba.com and download the updated drivers and firmware for your model.
That should fix it.
Feb 15, 2011 | Toshiba Satellite L455D-S5976 Notebook
My laptop wont charge
There's several things that cause this:
- Your ac adaptor could be dead - use a spare one or but a replacement and test. - The power jack on the laptop could be damaged - you need to have a specialist replace this for you - The battery could be dead - test with a spare battery if you have one - If all else fails it means that the motherboard has malfunctioned and needs to be replaced.
It is highly suggested that you bring this system to a professional for repair or purchase a used one with the same specs and swap out your hard drive as it could cost you hundreds to fix this problem. You can buy a used, working one for $250 ob buy it now on ebay, or cheaper if you buy one on a regular auction: http://cgi.ebay.com/Toshiba-Satellite-M35X-S149-1-5GHz-512GB-Ram-60GB-HD-/320664896971?pt=Laptops_Nov05&hash=item4aa91e05cb
Feb 08, 2011 | Toshiba Satellite M35X-S149 Notebook
Toshiba turns on but screen stays black wont boot anything
My 1st inclination would be to tell you to hook up an external monitor and see if the computer actually does anything (i.e., do you get a POST screen or does it stay dead as well).
Obviously, either condition (working or not) alludes to a problem with the motherboard and merits being replaced, however, in several cases with Satellite laptops (I have repaired a multitude of) the cost of the replacement board ends up being quite cost prohibitive. Seeing as several similarly (or progressive) laptops are being sold for as much as the repair parts.
I can imagine this isn't an answer you would like, but I have run into far too often. At least its worth pondering. Plus, there are several software fixes out there that will let you get your information off the old drive as well (so you can migrate it to your new laptop).
Hope this helps...
Oct 11, 2010 | Toshiba Satellite Laptop with Intel...
Fixing DC Jack for Toshiba Satellite L35 cost how
I believe the L35 uses what is considered a satellite power jack which means the actual jack is not soldered to the motherboard but uses a cable and plug, therefore is the easiest of the power jack repairs. The cable can be found on ebay for around 30 bucks or less. I usually charge 50 bucks for the labor plus the part, the laptop has to be disassembled to complete the repair. Below is a link for disassembly if you want to use it as a reference and perfrom the work yourself.....
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L35/taking-apart-laptop-1.htm
Jan 04, 2010 | Toshiba Satellite L35-S2366 Notebook
I opened my Toshiba satellite laptop to fix the DC Jack. Now it wont power on. Any ideas why
when you fixed the jack did U accidently solder anything else to the connector , sounds like a short, causing a ground fault.
Jul 08, 2009 | Toshiba Satellite A105 Notebook
Wont power up
Ouch! Well it depends on a lot of factors, such as did the fluid make it all the way to the motherboard, how long ago it happened. If you are not getting any power at all, no fan, no lights, etc. then the motherboard is probably shorted out. The best thing you can do it take it to a pc repair shop and ask for an estimate only..don't let them fix anything right away. The cost of fixing it may not be worth it, versus just getting a new computer. Also lay your notebook on a towel with the lid open and on its side so it can dry out. Let me know if you have any questions. Pls rate this solution with 4 stars before logging off.
Mar 29, 2009 | Toshiba Satellite A130-ST1311 Notebook
Garmin 205w wont find satellites
Hi, Please check to make sure the GPS is set to USA and your time zone etc do this in the tools menu, then see if it will load the map.
check for updates @ "my.garmin.com"
you can also download a manual at garmin.com if needed.
Make sure you are clear nearby buildings, depends on satellites currently visible, and the length of time your GPS has been on.these may have an affect on getting a satellite signal but mostly they are suppose work just fine.
You may need a car adapter with a reciever in it.they cost about $119.00 at bestbuy. ouch! e know if this helped at all.
I would try to exchange it for a new one, it hasnt been that long that you have it.
Hope this helps, let me know what happened. good luck!
Jan 14, 2009 | Garmin nuvi 205W GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
100 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
