Question about Magellan MAESTRO 3100 98083401 GPS Device
3100 gps magellan maestro w/ not power up , had it plugged in to car chrgr all day
    President:
  • 1,111 Answers
The following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
bill
EX 3100 gps magellan maestro w/ not power up - f31817b.gif
Posted on Aug 02, 2010
My Magellan Maestro 31100 won't power on
You could have a defective power connection in your Magellan Maestro 3100 which will not allow you to charge the internal battery or power on your unit.
You may try to contact Magellangps.com or Autonav2000.com to see if they can provide you with repair service.
Might be cheaper to purhcase another Magellan Maestro than spend the money on repairs.
Good Luck
Apr 03, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
The stinger from my car charger has broken off
this is very common problem with this and many model of magellans.
disregard the test for charging if you know your power port is broken and go to the bottom for further help
try the car charger2_bing.gif.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
the following magellan 2000, 2200t, 2500, 3000, 3100, 3140, 4000, 4040, 4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get help to repair it here
or buy the power port here
if you need further help, just let me know.
Dec 13, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan maestro 3100 will not hold a charge
this is very common problem with this and many model magellans.
try the car charger.
you can get it repaired, here
or buy the port here
Dec 02, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
My Magellan Maestro 3100 GPS unit won't charge anymore. I've seen 2 possible explanations for this problem. #1: The DC power port is broken #2: The battery won't hold a charge any longer How do I determine...
if it starts, you can verifiy if its charging by going to the system settings then power options. the green indicator should be moving left to right. this indicates its charging.
if you disconnect the battery, your magellan should still work while plugged in if the power port is ok.
Oct 15, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Unable to charge the 3100. If charged via car
the Magellan Maestro can not be charged using the USB connection.
make sure green light is on if using the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
The following Magellan 800,860,2000,2200t,2500,3000,3050,3100,3140,4000,4040,4050 and the 6000t are known to have faulty dc connectors...if your Magellan gps is not charging or will not power up, its most likely the dc power port.
you can get it repaired here
Sep 09, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Gps will not turn on
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (upto ten seconds) until it starts..if that fails
the following magellan 2000,2200t,2500,3000,3100,3140,4000 and the 4050 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...i sell these power ports and will repair them for anyone thats not able to do it them selves
you can email me through here or email to.... wmetz@comcast.net
Jul 18, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan maestro screen not coming on
if you have a 3100 or 3140 as you have pictured..they cant be charged via USB..you need a home or car charger
May 10, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan maestro 3100 turns itself off
Try using the RESET button . Make sure the battery is holding its charge
Jan 20, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
have you updated the maps on it? if no try and update the maps also do a firmware check to see if you need an update.
Nov 25, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan GPS
Online at Magellan website you can update your magellan maestro 3100
Mar 25, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan MAESTRO 3100 98083401 GPS Device Logo
103 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
