Question about MA Audio M1889I Car Audio Amplifier
Amp is randomally shutting off
A friend of mine has a legacy amp i think its the 4000 watt version and has 8 gauge running to it with 2 12 in cadence super tx subs and the subs are bridged to 4 ohm on the amp and the amp will shut off all of a sudden when he changes songs or just in the middle of the song any ideas
  • 631 Answers
If the amp shuts down with no pattern, you need to measure the DC voltage on the power terminals.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Since there is no pattern, you will have to watch the meter for a while so you can see the meter drop when the amp shuts off. If the meter never drops on either the remote or B+ terminals (when the amp shuts off), the amp may have an internal fault.
Posted on Apr 26, 2008
Onan 4000 Microquiet shuts down after running for 20-30 minutes. If I direct 2 high power (400+ CFM) fans to the underside of it -it will keep running indefinitely.
check the current draw from the machine
being a 4000 watt machine if you are drawing 4000 watts it is overloaded as that is the surge power available not constant power which is around 3500 watts
that would account for the requirement of fans to keep it cool
even if It is not 4000 watt what ever capacity it is it is running in an overload situation
Jul 10, 2016 | Onan Microquiet 3600 & 4000 Generator
I have a 2000 w volfenhag amp and a 15 in cadence 350/600 rms watt sub, what gauge wire should i use?
I would use a 4 gauge wire for the power supply to the amp and a 4 gauge neg of the amp
Jun 25, 2016 | Volfenhag Car Audio & Video
I got a cadence q 4000 and i what a the bass to sound louder
the Q4000 only funs 400 max and thats at 4ohms bridged 2x200 if you need high powered amps i would look at soundstream or MTX and you would need atleast 1 secondary battery cause to max a amp out you need to have constant 14.4 volts going to power the amp.
Jul 31, 2010 | Cadence Q200 2 CHANNEL POWER AMPLIFIER...
Capacitor not working properly
the power side has to be in line with the battery power side! The ground side to ground! The power that ran from battery (fused) to the amp power is used and cap is tapped in line, on that power lead! that way your amp gets power with cap charging and stable voltage to amp! taking stress off your charging system and better sound! good luck!
Jun 09, 2017 | Pyle BZDBP212 Car Subwoofer
SHOULD I GO AHEAD AND BUY A 400 WATT AMP?
All amps aren't created equal. More exspense amps put out "cleaner" power. You need to know what the RMS power rating is for the amp at 8 ohms and 4 ohms. Also, is the speaker an 8 or 4 ohm speaker? How you wire a speaker or speakers (series or paralell) can change the ohms (resistence) which will change the power put out of the amp. Also, I'm assuming you are setting it up in mono?
Jun 22, 2009 | Pyle 2 Channel 4000 Watt High Power MOSFET...
220 watt car amp -- 8 or 10 gauge amp kit?
when in doubt go bigger, you might want to get a bigger amp down the road, so its better to not have to buy another wiring kit later.
and the bigger the wire the less line loss you will have so your amp will sound and perform better.
Apr 03, 2009 | Car Audio & Video
Help me...
If you had 4 single voice coil speakers you can create either of those 2 ohm or 4 ohm setups. If you run 2 of them in parallel you will get the 4 ohms. If you run 4 of them in parallel you will get the 2 ohms. In parallel I mean that you connect the positives together and run them to the positive on the amp and the connect the negatives together and run them to the negative on the amp. Let me know if you need more help. Good Luck.
-Andrew Hawkins
Jun 24, 2008 | Cadence TXA 6004 4 Channel High Power...
Confused about system
If what you're telling me is correct you're trying to drive a stereo sub -woofer with a mono amplifier. If so, that could be a bad situation for the amp, if the voice coils are not wired together correctly. Before we go too far, I have some questions I need answered.
1. Is the MA unit an M1889i?
2. Do you have the 4 terminals of sub-woofer tied together. For example the 2 positive terminals are tied together & the 2 negative terminals are tied together?
3.How do you supply 12VDC to the amp?
While I'm waiting to hear back from you, I'll try to draw a schematic (wiring diagram) of the way it should be wired for your particular setup that I'll send to you.
Mar 06, 2008 | MA Audio M1889I Car Audio Amplifier
Amp dosnt hit hard
what is the rms and ohms fro the amp and what type of subs and how many
Dec 07, 2007 | Legacy Audio American Legacy II LA290 Car...
Cadence FX500
The FX500 is 4 x 75 watts clean and 1 x 500 watts RMS @2 ohm mono. What subs are you running and what are the ohms per voice coil. Single or dual voice coil. By what you said (not getting hot) sounds to me like the load istoo much. Let me know.
I was/am a Cdence daler and I sold many of those amps without a problem Never had a bad one!
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Dec 05, 2006 | Cadence Z9000 Car Audio Amplifier
MA Audio M1889I Car Audio Amplifier Logo
120 people viewed this question
Top MA Audio Car Audio & Video Experts
Mark Skinner
jamie suver
Level 1 Expert
Robert Rankin
Are you a MA Audio Car Audio and Video Expert? Answer questions, earn points and help others
