Question about Kenmore 24032\24036 Top Load Washer
I have a Kenmore 80 series limited edition. The fabric softener device that connects to my aggitator broke and I cannot find the replacement..help please
  • 714 Answers
Have you tried repairclinic.com?
Posted on Aug 01, 2010
My Kenmore 400 series washer does not seem to be releasing the fabric softener properly. It ends up all around the top if the barrel and spotted on my clothes as well. Anything I can do other than g
the dispencer can at times become plugged with old soap and farbic softener and should be cleaned every so often. if it cannot dispinse it will shoot out the dispenser all over when it goes into spin. the lines can even get plugged up and not allow fabric softerner to flow , u may want to remove fabric hoses and clean them
Nov 08, 2014 | Kenmore Washing Machines
Kenmore 600 series fabric softener dispenser clogged
How do I make the waher Kenmore drop the fabric softener
Aug 25, 2012 | Kenmore 600 3.5 cu. ft. Top Load 110-2962...
Series 80 Agitator top dosent work
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
I assume that your model number starts with a 110 instead of 100.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26842692
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Following is an illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
Jan 09, 2010 | Kenmore Washing Machines
Fabric softener dispenser
Have u made sure that the dispenser is click in properly
Oct 26, 2009 | Washing Machines
How do i clean the fabric softener dispenser in my kenmore 80 series washer? Does it come apart to clean the inside? It is full of gunk and the fabric softener won't come out.
If it's located at the top of the agitator. It pulls off. Pull straight up. After you have removed it. Run hot water through it. Take a old toothbrush and brush down inside it. You can use Mean Green to help cut the goo. Now rinse and shake over and over. Pop it back on.
Please rate solution
Aug 27, 2009 | Kenmore 24902 Top Load Washer
Kenmore 80 series washer will not spin
you have a bad coupler, it's a $20 plastic and rubber part the connects the motor to the transmission.
Mar 31, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag Quiet Plus 2 cloths washer - aggitator drain plugged up
Ok grab hold of the top of agitator about 4 inches from the top and just pull that top right off.Hit it at an angle and it will pop right off .Dont be shy ,its just plastic that is snapped onto plastic.To put it back on just line it up on top and Smack It back on.Easy Ha???Youll be able to clean it alot easier now.If you dont use fabric softener your problem will be gone for ever .Try using less and mix water in it first.I'll help you if you need further help..
Feb 27, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore 24032\24036 Top Load Washer Logo
61 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
