Question about Acer Aspire 3000 Notebook
My acer computer has an error when i start it. It says I don't have a bootable device
  • Acer Master
  • 11,800 Answers
That means that the hard disk has died. Junk it, buy a new one, put it inside your laptop and reinstall Windows.
Posted on Aug 01, 2010
No bootable device acer aspire 5250
This error message means that the computer is not seeing the hard drive or there is no operating system on the hard drive. In the bios does the computer see the hard drive? The unit may have to have the hard drive replaced.
Nov 05, 2012 | Acer Aspire 5250-Bz873 Amd Dual Core C-50...
Help!! I have an Acer Aspire Laptop. It wont boot up!!
Hello, "Suzy Irwin".
You wrote that this is the error message:
"Check cable connection! PXE-MOF : Exiting Intel PXE ROM No bootable device -- insert boot disk and press any key".
Is that correct?
IF so, 1st, Good Job!
Most people miss the mess., then we don't have the info we need.
OK, "PXE ROM" indicates that the POST can't find the hard drive.
"No bootable device" usually indicates the connection to the hard drive, or the drive itself, has failed.
When it says; "Check cable connection",
that's another indication of the same problem.
So, do you feel comfortable taking your "Acer Aspire" apart?
IF its in warranty, or if you don't think you can take it apart,
AND put it back together again,
then you will need to take it to a shop or store that does repairs,
or buy another computer.
But IF you feel up to it, check the company's website,
and google the instructions for disassembly/reassembly for your particular model.
Your description of the problem didn't include the model info, or any additional info to further ID your particular Aspire.
They are NOT all alike.
Hopefully helpful,
sl0j0n.
Jul 27, 2012 | Acer Aspire One PC Notebook
Screen reads no bootable device
Your hard drive has an error, it has either lost it's boot sector or the drive has failed, If you don't have much technical computer experience i would advise getting a computer tech to look at it.
Mar 11, 2012 | Computers & Internet
Acer aspire 5253 error message no botable device after laptop was dropped on carpet
No bootable device suggests that your Acer Aspire hard disk may have been damaged when the computer was dropped.
You should try opening the cover on the base of the laptop where the hard drive is fitted and check to make sure that the drive is seated firmly and has not come loose with the drop. See the Acer Aspire 5253 Quick Start Guide for the location of the drive cover.
If reseating the drive does not help, then you would need to find any recovery discs that you may have made or received with the laptop plus need to buy and install a replacement hard drive.
Jan 10, 2012 | Acer Computers & Internet
How i can boot up win xp on bootable usb on acer travelmate 2413lc
1st of all plug in the usb bootable device. Then:
When you start up your computer it should say something like press f2 or f8 or something for setup. Hold down that key when the computer is starting up then:
1. Search through the BIOS with the arrow keys and enter for the setting to change the boot sequence.
2. Change the boot sequence to have your computer boot from the device first.
3. Then save the changes and reboot your computer.
May 10, 2011 | Acer TravelMate 2300 Notebook
Well, my computer doesn't start up and the screen says "Media test failure, check cable", "No bootable device -- insert boot disk and press any key". I don't know what the cable is and...
The uProcessor can't find a bootable device and presumes your hard drive is no longer plugged in. Standard error message.
Check your BIOS for the hard drive listing. If it is listed there is no problem with the cables.
You will need your restore disc to boot from and repair your boot sector on the drive.
Feb 21, 2011 | Acer Computers & Internet
Unable to boot from CD: acer 5740
Dear user,
You did not mention the make and model of your computer which is required for the best help.
To change the bootable device you need to go to bios setting. Depending on your computer make and model the way to go to bios could be different though generally you can go to bios by continuously tapping on F1 or F2 or F9 or F10 or F11 etc The moment you press the power button and you see flashing brand scree like dell, hp etc. start tapping on F1 or F2 or F9 or F10 or F11 only one key at a time.
The best option is to install any version of windows is to use Wintobootic search and download it on a computer. Use any storage device like external hard disk or pen drive. make sure the storage device is completely blank when you make it bootable. insert your windows CD and Open wintobootic, select source and make bootable storage device.
Feb 23, 2018 | Acer Computers & Internet
WIndows doesn't load ,frozen, internet connection problems
For that when you power up the computer press F1 or F2 or del or ALt+F2 key to enter in bios.
Then go to boot menu and set first boot device as your harddrive.
Also disable boot from lan in advanced menu.
Disable SATA in bios.
Then save settings and exit then check.
Let me know if you need further assistance.
Thanks for using FixYa.
May 14, 2010 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire one will not start. I get a error while initializing the NIC, No bootable device-- insert boot disk and press any key...There is no boot disk.. Any suggestions please..
Its possible the computer is trying to boot from another device, as the computer starts up hit the F12 key, this should bring up boot options, select HDD if it's in the list.
If not hit F2 as it starts and enter the BIOS, look for the boot option and set the HDD as the first boot device, hit F10, save the changes and exit.
The computer will restart and hopefully boot into the operating system
Please post back if you need anymore assistance.
Regards.
Aug 06, 2009 | Acer Aspire One PC Notebook
Laptop will not fully start
This could be a device failure. However, try flashing the bios. Do this by going to Acer's support site and creating a bootable disc with the bios or updated bios, if there is any, on it. Then run this in your machine. You will have to use a different computer to do this, apparently. If this doesn't fix the problem, then you will need to take it in and have a tech run down the device that failed.
Jun 26, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 3000 Notebook Logo
44 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
