Question about Car Audio & Video
How do I install my pioneer stereo?
I have a pioneer stereo, model ke-4535, and a pioneer graphic equalizer amplifier modelbp-880. i need to know how to install them into my car.
  • 975 Answers
This way should work : connect the OUTPUT of stereo ( ke-4535) to the INPUTS of GRAPHIC EQUALIZER ,then the speaker outputs of the GRAPHIC EQUALIZER to speakers , in this order you have control to adjust the sound coming from the PIONEER stereo . hope this helps
Posted on Apr 29, 2008
How do i wire a performance teknique ICBM-5EQ 5.1 channelparameteric equalizer to pioneer car stereo
The equalizer will need a +12, a switched +12, and a ground. Only wires for the radio are the rca jacks, if your headunit has pre-amp rca outputs!
Jun 07, 2016 | Pioneer Car Audio & Video
How to hook up a 7 band pioneer equalizer great 470 to a Kenwood kr-v6030 receiver
Connecting an Equalizer to a Receiver Before beginning, purchase RCA cables. In order to run the signal from a stereo receiver to the graphic equalizer and then on to the amplifier, two sets of RCA cables are needed. These are basic cables used to connect auxiliary components like record players and CD players. The length of the RCA cables should be about the same length as the distance between the receiver and equalizer.
1. Connect Graphic the Equalizer to the Receiver
The first step in this setup is to connect the graphic equalizer (EQ) to the receiver. Most receivers will have preamp-in and preamp-out connections. Some have tape monitor connections. It's preferable to connect the EQ to the preamp-in or preamp-out because the tape monitor won't allow for connection to the amplifier as well.
2. Connect the RCA Cables
The first set of RCA cables should connect the receiver and equalizer. Connect one pair to the preamp output channels and the other end to the left and right input channels on the EQ. These are on the back side of the equalizer. Usually, the colors will correspond to the RCA plugs. That means connect the red plug to the red jack and the white plug to the white jack. Then connect the second pair of RCA cables between the receiver and the amp. Match the colors in the same way.
3. Connect the Amp to the Receiver
Now the amp can be connected to the receiver via RCA cables in the amp inputs on the receiver. This will create a loop from the receiver through the EQ and amp and back to the receiver so that all three units are connected.
4. Test Graphic Equalizer
Turn on the receiver, amp and equalizer. Once they are powered up, try controlling the sound with the equalizer knobs. They should fine tune the music according to your preferences. It's easy to change the frequency response or tone of the music with the equalizer knobs.
May 09, 2016 | Pioneer Audio Players & Recorders
How do I connect a graphic equalizer to a Cambridge audio 851 amplifier?
I found only an 851A amp - I hope it is what you have or very similar. You can add an equalizer (or tape recorder for that matter) easily by making use of the amplifier's "Record In" & "Record Out" jacks. The amplifier's "Record Out" jacks should be patched to the equalizer's "In" jacks and the amplifier's "Record In" should be patched to the equalizer's "Out" jacks.
On the amp, select your source (1, 2, etc.) as usual. Press the "Rec In" button to divert the stereo source signals to the equalizer for customized shaping before being amplified - press again to bypass the equalizer and send the source stereo signals directly to the amplifier - and speakers.
https://techsupport.cambridgeaudio.com/hc/en-us/article_attachments/200291492/Azur_851A_User_Manual_English.pdf
Feb 25, 2015 | Cambridge Audio Azur 851A - Integrated...
Where can I get a free manual
go on panasonic website or google the manual you want.i use manuals lib
Jul 02, 2014 | Technics Audio Players & Recorders
I need data sheet or user manual for my pioneer graphic equaliser
If is a parametric equalizer is zero watts. ,pionner should have a front, rear and subwoofer connections. If i remenber correctly, a single rca going to your stereo and the rest from eq to amp or amps. Hope this helps ,hope you get WIRED.
May 15, 2013 | Pioneer EQ-6500 9-Band Car Equalizer
How to hook up equalizer to the amplifier
always remember source, amp, then speakers. ex: cd to eq to amp to speakers and it goes: out from cd player into eq, out from eq into amp, out from amp into speakers . hope this makes it easier for you.
Jun 23, 2009 | Sony TC WE435 Stereo Dual Cassette Deck...
In car graphic equalizer installation
035132ed-916f-4d02-8e5e-9fa428212a36.jpgPyramid stereo graphic equalizer model 9700g - Page 6
Mar 23, 2009 | Pyramid 801 10-Band Car Equalizer
Hook up pioneer stereo amplifier model SA-1270
for audio system always you have left and right channels.
get the output (left&right) from tuner---go to equalizer input left&right.---from equalizer output go to amplifier inputs.and certainly from amplifier output to speaker.
Oct 15, 2007 | Audio Players & Recorders
Car Audio & Video Logo
464 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
