Question about Singer 7444 Mechanical Sewing Machine
I have a brother xl 3022 sewing machine. when i put the buttonhole attatchment on and set it up correctly, it still doesnt work. it stitches in one spot and wont move. i cannot solve the problem.HELPPP
Trifect7
  • 57 Answers
SOURCE: How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Posted on Mar 08, 2008
rizla
  • 1463 Answers
SOURCE: I need instrutions on how
hi hrkids
will anything thing here be of help XL-2600/2600i/2610:
riz.
Posted on Apr 21, 2008
  • 1027 Answers
The brother website has a users manual for it that can be downloaded. Use this link to get it:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_ls2125eus&type2=5&flang=English&dlid=
Posted on Jul 10, 2008
keemo68
  • 1263 Answers
SOURCE: Singer 7462 buttonholer
generally most sewing problems are due to sticking parts because of non usage as =you have stated or because the tension has been not set right. what I suggest is that you take the time to do some cleaning of the machine like what bis pointed out in your manual use a light weight mineral oil to wipe the moving parts with, but not too much. also adjust the tension of the foot so there is pressure on the material as to move it while sewing. after all the cleaning and adjusting rethread the bobbin and make sure it is seated properly also rethread the need and make sure the thread moves freely from the spool. this should do the trick. please rate this
Posted on Sep 29, 2008
Michaelle
  • 65 Answers
SOURCE: MAQUINA DE COSER BROTHER
Vérifiez cet emplacement. Il y a des images de chaque machine là. Tout le Q& ; Réponses dans la langue simple, aussi bien qu'un GRAND cust. appui. (son un frère après tous !) J'ai trouvé des manuels de téléchargement là aussi bien.
http://welcome.solutions.brother.com/bsc/public/Model_list.aspx?reg=us&c=us&lang=en&titleid=36
J'espère que ceci aide ! Couture heureuse !
Posted on Jan 24, 2009
I don't know how to change needle postion when changing the foot to another one my machine is a brother xl 3022
Here's a manual for your machine:
Brother XL 3010 Operation Manual
It appears that your machine does not have the ability for the user to change the needle position. Instead, it seems that the selection of the specific stitch pattern determines where the needle is positioned, ie #1 appears to set the needle in the left position but other stitch and width selection will move the needle position.
Oct 16, 2017 | Brother Sewing Machines
How do I drop the feed dogs on my Brother sewing machine?
Altho I don't have your model, most of the Brother sewing machines have a slider kind of button on the back of the machine right in back of the needle assembly. So you push it to one side and voil? ! the feed dogs are dropped down. Don't forget to put them back up when you need them again :-)
Oct 14, 2014 | Brother Sewing Machines
E1 flashes on the message window of my brother sewing machine
Brother Computer Codes
  • E1: Make sure the presser foot is lowered before sewing.
    E2: You chose a stitch other than a buttonhole stitch or a bar tack stitch and you tried to sew with the buttonhole lever in the lowered position. Raise the buttonhole lever.
    E3: If you selected the buttonhole or tack bar stitch and start to sew with the buttonhole lever raised, you will get the E3 code. Lower the buttonhole lever.
    E4: You hit the reverse button while the bobbin winder shaft was moved over to the right. Move the bobbin winder shaft to the left.
    E5: On automatic sewing machines, the start/stop button was pressed while the foot controller was plugged in. Unplug the foot controller if you are using the automatic function.
    E6: This code tells you that the motor locked up because the thread is tangled. Untangle the thread, make sure the machine is threaded properly and that the proper tension is set before continuing.
Oct 03, 2012 | Brother CS-6000
Will the Brother ES2000 sew a buttonhole without the buttonhole attachment installed. If so, what do I do. I have set the style number plus length and width as shown on machine. It does not sew the...
Have you made sure the buttonhole lever is in the buttonhole tab?
This tutorial will show you how to make a zig-zag buttonhole - http://www.ehow.com/video_4433258_making-hole-using-zigzag-stitch.html
The demo is a little sloppy. I stitch into the ends and I set the stitch length to zero when making the bar tacks across the ends. It takes a little practice.
I hope this helps.
Mar 07, 2010 | Brother ES2000 Computerized Sewing Machine
How do I adjust the bobbin settings on my Brother XL-3022
Well is your machine skipping stitches? "Not looping" does that mean not creating a stitch? To adjust your bottom stitch you usually adjust the top tension regulator. I can try to help you more in detail check out my forums http://www.sewingmachineryrepair.com/forums/index.php
Feb 28, 2010 | Brother LS-2125 Mechanical Sewing Machine
Buttonholes
First be sure to follow the steps described in the manual for attaching the buttonholer.
Second, check that the buttonhole lever is pushed because it returns to it's unpushed state after a buttonhole is completed and therefore it will stitch in the same spot.
Also, try adjusting the stitch length. I've found that I can't make buttonholes while on the satin stich setting ( that little rectangle) but if I move it just a bit towards 1 it will manage to make the right stitches.
Feb 11, 2009 | Brother XL-5700 Mechanical Sewing Machine
Threading and operation
http://www.devicemanuals.com/guide/Sewing%20Machine/Brother/Brother-XL-3022-Sewing-Machine-Owner%27s-Manual-T0RNeE5qUT.html
or i could photocopy pages from my manual and post them too you if that would help. (can't scan as my scanner doesnt work for some reason).
if not than nevermind.
Feb 10, 2009 | Brother LS-1217 Mechanical Sewing Machine
Brother Super Galaxie 2100 Buttonhole lever not working
I have a problem with my CS 8150 which sometimes tells me to lower the pressure foot even though I had already did it. What clears the problem for me is that I eject the thread cassette and re-install and I can go ahead and sew. Try that to see if it will quit telling you to pull down the lever.
Sep 03, 2008 | Brother CS-8150 Computerized Sewing...
Singer 7444 Mechanical Sewing Machine Logo
61 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
