Question about Dishwashers
Dishwaher was inoperable for 2 weeks waitng for part, now theres a horrible smell like old water that perhapl leaked into the wall-the repair man did not take the whole unit out--i've put bleach, disinfectant, in the under the counter sink next to the unit nothing works--is there any moisture absorbing chemical i can use
    Scholar:
  • 59 Answers
You should take out the filters in the base of the sump and clean them. also clean the sump. Then take off the door outer liner and clean along the bottom of the door seal. The bottom of the door seal is the worst place whaer a build up of greas forms. Once the lower door area is clean and the sump is clean get som descaler and run it through without dishes. You can buy dishwasher descaler or dishwasher cleaner from the supermarket. Keep the lower door seal clean regularly. dont put dishes i the machine with food on them. Dishwashers are not able to dispose of garbage, just grease from dishes. Good luckPS vinegar may help too.....
Posted on Aug 01, 2010
Dryer smelled like smoke and hose filled with water
Something is plugged dryers vaporize wetness not create water
make sure all ventilation is clear
Apr 02, 2014 | Samsung Dryers
Bad smell from fridge (not mouldy food)?
There is no danger if there is a leak, but the refrigerator will quit cooling. I suspect perhaps you have a dead something underneath or behind the refrigerator. I hope this helps... but I also suspect you have cleared the problem by now.
Mar 25, 2014 | Freezers
My dryer had a horrible smell when in use, had the lint filter cleaned by a repair man and now it throws it's breaker when not in use. What is going on?
The repair man should have done a safety check. Call a different one. Clean your filter after each load.
Nov 22, 2013 | Hammering
I have a Kenmore 80 series about 4 years old and it is leaking. Had a repair man over 3 months ago and it did not leak. However, I see my baseboard behind the washer pulling away and ran a small load...
check to make sure the drain hose is all the way in the drain pipe in your wall. there should be a strap, or tie wrap holding it in place to keep the water pressure from pushing the pipe out of the drain during the drain cycle. if not, the water pressure will cause the drain hose to rise up and allow water to leak down the wall. use a flashlight. you should be able to see a trail of water residue leaking down the wall. slide the washer out a bit and run it. see if the water is coming from the wall, or leaking out of the washer itself. let me know and we can go from there.
Nov 20, 2010 | Kenmore 24902 Top Load Washer
Heavy exhaust smell from A/C Solve For the past week and a half I have had a very heavy exhaust smell in my apartment, which seems to... (More) For the past week and a half I have had a very heavy exhaust...
if you see oil "oozing from the copper lines (fittings) you can verify if refrigerant is leaking out of the lines using a solution of dish soap and water, spray or wipe the solution on the suspected leak, and if it is leaking it will bubble. if it is indeed leaking the smell of refrigerant could be described as "exhaust" usually the smell is described as "chemical" by clients that I have served in the past. I have never heard of refrigerant causing headaches, as refrigerant is considered as non-toxic. It will dispalce oxygen in large enough concentrations, but it would take considerably more than a standard system holds to displace enough oxygen to cause issues, unless it was all released at the same time. hope this helps
Jul 27, 2009 | Heating & Cooling
I'm having a similar problem but with a home a/c unit. I had every appliance in the house checked, first, including furnace, but no problems were found. I get similar symptoms, many people can't smell anything, a few can. Someone visiting asked me in September if my furnace was on because it was a slight mechanical/ozone-y smell. I'm about to drop a lot of money on a VOC test because this has been going on for 8 months with no solutions.
It's cold comfort, because I have no solution, but if I figure out what my problem is, I'll post it here, too.
Jul 27, 2009 | Whirlwind FH-778 Air Conditioner
I have a coleman spa about 4 years old that is leaking, should this be repaired by a plumber or would it take a spa repair person. it is a 6 to 7 person tub coleman horizion
this has to do with where the water is coming from.
1. wall fittitng. just remove it, reseal and replace
2. pump leaking, usually means shaft seal.
3. plumbing fitting. usually just replace the fitting.
4. fiberglass cracked. get a boat repair man and have him fix it. these guys are usually pretty good.
David
May 18, 2009 | Pool & Spa
Electrical smell
did you recently screw or nail something to the wall?do you have the old fabric coated wires?
Feb 26, 2009 | Honeywell Electronic Programmable...
Error code e4 on kenwood kdw243a any ideas????
Error code E4......I have the definitive answer.
All the recommendations to tilt the machine are totally wrong!!!!! It may work in the short term but is a bodge-fix and covers up the "real" problem - you have a water leak- its as plain as that.
There is nothing wrong with the Kenwood and it has a 'Flood Sensor' that is filling with your leaked water.
I too was suckered into this quick fix but it didnt work for me; then I spoke to a neighbour who is also a dishwaher repair man.
We removed the machine , removed both side-panels (yes its easy for a DIY), dried out the water from the bottom pan (the sensor sits in a small recess right in the middle of the bottom pan). The machine was switched on and we checked for a leak; now there are many pipes and you need to observe just where the leak is. In my case the water was pouring from a broken pipe, but worse still it was leaking right onto the mains electricity !!!!!!!
So DONT mess with bodge fixes - they may kill you!!!
Aug 03, 2008 | Dishwashers
Dishwashers Logo
91 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
