Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Mower barely moves forward or backwards with or without the blades turning,engine runs fine but can't seem to get mower to move
    Brigadier General:
  • 3,911 Answers
Well you have a fault with the belt which goes from the engine to the transmission being too loose or the transmission itself has failed. Get underneath it and, with the engine cold and not running, grab hold of the belt and see if there is any slack in it. This would be the topmost belt, it should not have any slack in it unless the clutch pedal is pressed down. Don't try this with the engine running unless you have an extra set of fingers and a surgeon at hand. If the belt is good then your transmission has failed and you need another mower as the cost of the transmission will exceed the value of the mower. There are mower boneyards around and used trannys for sale on ebay, but most likely you will be looking for another mower.
Posted on Aug 02, 2010
I drove my mower into my shed after the last use and now I cannot get it to move either forward or backward, even pushing it
Lift left hand foot pedal to full extent with top of foot may find that it is not engaging idle pulley, may be time for a new drive belt
May 30, 2015 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Craftsman LT2000 Does not move (wheels do not move). blade engages and works finr
I would lower the deck to the lowes setting and look between the frame and the deck toward rear wheels and check the drive belt it sounds like it is slipping or busted.
May 19, 2014 | Craftsman Garden
24 hp LA165 mower. While mowing the mower stopped moving. Engine runs, blades turning but won't move forward or backward (the side lock has been released and the pin at the back is pushed in) 11...
check the connecting rod to the tranny. follow the gear handle and you should find a rod connecting the handle to the axle make sure you're in neutral and adjust the rod until the handle starts to move
Jul 17, 2011 | John Deere 24HP VTwin Hydrostatic 48"...
Won,t move
Check the pump.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 20, 2010 | Husqvarna Zero Turn Mower Z5426
Will not move
The transmission is shot. A common problem. Mine died after 3 years and 200 hours of use. Estimate to fix was almost $2000. I scapped it and bought a better mower. There was a rtransmission design defect in the RZT series.
Jun 01, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Mtd model series 790 mower wont move, belts are fine and transmission wont go in nuetral
mtd 1993 riding mower model 828 I was mowing then tractor stopped and wont go forward or backward It runs fine, and blades
seem fine. Drive belt looks fine.
Sep 17, 2009 | Mtd Garden
Ariens Yard Tractor 935 Series - initially drives, then stops moving as it gets warm
Is it a hydrostatic tranmission? If so, sounds like the fluid might be old or not the right viscosity. Recommend changing the trans fluid, and use recommended viscosity of fluid.
Sep 12, 2008 | Garden
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
303 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
