When I connect my Laptop to my Sony Bravia TV thru HDMI, I get "Unsupported signal" message for past 10 days. It used to work fine for almost a year. I don't know why it happens like this offlate. I haven't downloaded anything at all...
    President:
  • 1,194 Answers
"Unsupported Signal" means that your laptop is probably set to a resolution or refresh rate that yoru TV doesn't support. You will need to go into your Laptops video settings to make them match what your tv will display.
Right click on your desktop, choose properties then settings you can change the screen resolution there. Windows will change back in 15 seconds to the old resolution. Try the different resolutions availbe to you.
If the problem is still there then you may need to go into setting on your tv and click the hdmi to on
Thanks for using Fixya.Good luck and have a nice day.
Posted on Aug 01, 2010
  • narennath Aug 01, 2010
    well, I tried all the options one could every ask for with the sony technical support guy on the phone.
    I tried different cables, different screen resolutions, different refresh rate etc. I also did several things what the guy(s) asked me to do. I was on the phone with 3-4 different sony technical people. Nothing worked.
    Just FYI...The ones which you sent is the basic stuff that I tried long back. Thanks anyways
  • Ranglo
    Ranglo Aug 01, 2010
    This problem can also cause due to the cable box.
    It can be due to internal circuit problem (signal processing in cable box) or its getting distorted signal from cable company.
    Change cable box just to confirm it.
I hooked up my tv,a sony bravia bx3 to my laptop using an hdmi cable which i disconnected from myps3 while it was still on,it worked perfect.suddenly the ps3 switched off.I re-connected my ps3 to the tv...
ok you have to reset the ps3 by turning of backswitch wait 10 seconds turn on the backswitch then press and hold down the front power button for 10 seconds you should hear 2-3 beeps that does it just wait and the video settings have automatically detected your tv settings and are going to ask you to save hit x to save display settings on ps3 remote problem solved. If you still get problem message me cause its technically bad.
Dec 15, 2010 | Video Game Consoles & Games
I bought an hp laptop and a sony hdmi cabel so i could be able to use my laptop on the lcd sony bravia tv. i connect my ps3 as well on the hdmi ports. at first everything was fine. no it doesnt work. i...
if you constantly change between one type of unit to another. say between your ps3 and another type of device then you could have worn the connector on the hdmi socket. it may need to be replaced. thats the best I can do. we have a bravia but dont change connections at all because it can cause many issues over extend use especially if youre changing devices whilst the set is on, as this can interfere and damage the internal circutry which may have shorted out the hdmi circuits.
Sep 11, 2010 | Televison & Video
Message of Unsupported video signal after attaching laptop to TV.
it sounds like the resolution the laptop is trying to send is not one of the resolutions that the television can display. TVs can display a range of resolutions, so try changing the laptop resolution, either increasing it (make the pixels smaller) or lower the resolution, try a variety of resolutions, one should work.
Jul 11, 2010 | Dell Latitude D420 Notebook
BRAVIA KLV-37U300A 37 in. LCD TV: I have a HDMI cable attached to my Sony Bravia and...
t con is not working is t con is repairbale or can i get ic becouse here in pakistan is not available.
May 17, 2010 | Sony BRAVIA KLV-37U300A 37 in. LCD TV
KDL-40V5100 TV HDMI Issue
I have the same problem did you ever find a solution
Jan 07, 2010 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
HDMI problems with 40'' bravia
The HDMI reciever board in the TV is bad and will need to be replaced. You should have a technician look at it so they can get the correct part number using the model number and the TV's serial number too.
Nov 11, 2009 | Televison & Video
Hdmi port stopped working on sony bravia KDL-32L4000, when I connect my ps3 or direct tv trhough hdmi cables I will just get a blank screen that will say no signal.
I have a Sony Bravia model KDL-46s5100 that had the same problem. All HDMI ports stopped working. I don't know why this works but unplug the TV for about 30 sec, then plug it back in and hold down the power button on the tv for 10 seconds. Like I said I don't know why this works but it worked for me. Good luck.
Oct 07, 2009 | Sony Televison & Video
Sony Bravia does not recognize my Dell Inspiron 1525
I have the 1525 and you have to do extra steps each time you want the HDMI to be recognized by the Bravia - too bad it is not automatic as it is with some. Anyway what you have to do is have the HDMI cable connected from laptop to TV then go to your desktop - right click on an open area (away from icons), a menu will appear, let the cursor hover over Graphics Options - you'll then see Output To...then you'll see Intel Dual Display Clone...hover over that and you'll then see Notebook + Digital Television...left click on that and you should see your desktop on the TV in a few seconds. If it does not work the first time...get your movie or whatever you want to show up and ready and go thru these steps again...stupidly complicated aye? when it should automatically detect and show...are other TVs like this?
Jun 24, 2009 | LG 42LC2D 42 in. LCD HDTV
Pc setting for sony bravia
'Unsupported Signal' Error indicates that TV is accepting the signals for Video but not able to display because resolution doesn't matches. Else the message would be 'No Signal'.
Follow the steps-
NOTE- Make sure cable is 15 pin(at both ends) VGA cable, working fine between PC & Monitor.
1.The standard resolution of laptop(any) which would support is 1024*768.
2. Toggle the display output from Laptop Fn Keys depending on Laptop Brand.
3. Connect the cable after settings made.
Also PC Settings will not be highlighted until connection is made.
Jan 20, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
I have a 37" Sony Bravia KDL-37XBR6 that I purchased in July 2008. I also have a Time Warner HD cable box that also has a built in DVR. The HD cable has been connected to the HDMI 1 port. It worked just...
Hello, There is an update for your TV at Sony Support and I would strongly  recommend to call Sony Support to update your TV as firmware updating firmware is risky job for novice and TV firmware can be damaged and TV will shut down.
Jan 10, 2009 | Onkyo TX-SR605 Receiver
Computers & Internet Logo
91 people viewed this question
Alun Cox
David Payne
David Payne
