Question about Nokia N70 Cellular Phone
Lock probmolm - Nokia N70 Cellular Phone
  • 55 Answers
please visit below website
http://www.foneszone.co.uk/
then on right side enter mobile name & model no.
& than click on GO
you find a application form to unlock your form & than fill the form
thanks
Posted on Aug 02, 2010
Where are the fuses for the power dock locks on a 2006 montecarlo06ss
DR/LCK fuse 25 amp . located in the I/P block
Fuse Block - I/P
In the right front kick panel
Power Door Locks System Components
The power lock system consists of the following components:
• Body control module (BCM)
• Driver door lock cylinder switch
• Front passenger door lock cylinder switch
• Driver door lock switch
• Front passenger door lock switch
• Door lock actuators in each of the doors
• DR LK Fuse 20-amp
Door Lock System Controls
The Power Door Lock System is controlled by the body control module (BCM) and can be activated by any one of the following:
• A door lock switch lock or unlock actuation
• A door lock cylinder switch unlock actuation
• A keyless entry transmitter actuation
• An automatic door lock actuation (Personalization function)
• An automatic door unlock actuation (Personalization function)
Door Lock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the lock position, it switches the door lock actuator lock control circuit to voltage. Since the lock actuator unlock control circuits are at ground potential within the BCM, the door lock actuator motors transition to the lock position.
Driver Door Unlock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the unlock position, it switches the driver door lock actuator unlock control circuit to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the left front (LF) door lock actuator motor transitions to the Unlock position.
The driver door lock actuator unlock control circuit is a dedicated control circuit used only for the driver door lock actuator motor. This is done so that the driver door may be unlocked by itself using a keyless entry transmitter or an automatic door unlock function (if programmed).
Passenger Door Unlock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the unlock position, it switches the door lock actuator unlock control circuits to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the passenger door lock actuator motors transition to the unlock position.
The door lock actuator unlock control circuits are dedicated control circuits used only for the passenger door lock actuator motors. This is done so that the driver door may be unlocked separate from the passenger doors using a keyless entry transmitter or an automatic door unlock function (if programmed).
Mar 23, 2017 | 2006 Chevrolet Monte Carlo
Mobile phone unlocking codes
*7465625*638*Code# = Enables Network lock
#7465625*638*Code# = Disables Network lock
*7465625*782*Code# = Enables Subset lock
#7465625*782*Code# = Disables Subset lock
*7465625*77*Code# = Enables SP lock
#7465625*77*Code# = Disables SP lock
*7465625*27*Code# = Enables CP lock
#7465625*27*Code# = Disables CP lock
*7465625*746*Code# = Enables SIM lock
#7465625*746*Code# = Disables SIM lock
*7465625*228# = Activa lock ON
#7465625*228# = Activa lock OFF
*7465625*28638# = Auto Network lock ON
#7465625*28638# = Auto Network lock OFF
*7465625*28782# = Auto subset lock ON
#7465625*28782# = Auto subset lock OFF
*7465625*2877# = Auto SP lock ON
#7465625*2877# = Auto SP lock OFF
*7465625*2827# = Auto CP lock ON
#7465625*2827# = Auto CP lock OFF
*7465625*28746# = Auto SIM lock ON
#7465625*28746# = Auto SIM lock OFF
Jun 08, 2010 | Cell Phones
Keypad numbers are locked on, how do i unlock??
Boot to your Bios and look in advanced for num lock and disable.
or
go to run in the start menu.
typ: regedit.
Go to: HKEY_USERS\.Default\Control Panel\Keyboard
Then String value- InitialKeyboardIndicators right click click modify then choose a number below.
Explaination numbers.
0= Truns Off, Num Lock, Caps Lock, Scroll Lock
1= Turns On Caps Lock,
2= Turns ON Num Lock,
3= Turns On Caps Lock, and Num Lock
4= Turns ON Scroll Lock
5= Turns on Caps Lock, and Scroll Lock
6= Turns On Num Lock, and Scroll Lock
7= Turns On Caps Lock, Num Lock, and Scroll Lock
Hope this helps.
Feb 07, 2010 | Acer TravelMate 4230-6499 Notebook
Need unlocking code of Samsung SCH- w339
hi i am using rel connection can i buy sch-w339 and use the phone for rel connection with unlocking code given by u
Dec 31, 2008 | Cell Phones
Reformat sgh t509
*7465625*638*00000000*00000000#
NEXT ENTER
#7465625*638*00000000#
AND THEN *#7465625# to check the locks....all locks are inactive...these are all the locks...
network lock - inactive
subset lock - inactive
sp lock - inactive
cp lock - inactive
sim lock - inactive
activa lock - inactive
phone lock - inactive
auto network - inactive
auto subset lock - inactive
auto sp lock - inactive
auto cp lock - inactive
auto sim lock - inactive
Sep 08, 2008 | Samsung T509 Cellular Phone
Need unlock code for my samsung vodafone
Try this it work for me
1- Enter code *7465625*28782# without a sim in the phone
2- Phone will display "Auto Subset Lock: Activated!"
3- Enter code *7465625*28638# without a sim again
3- Phone will display "Auto Network Lock: Activated!"
4- Now insert the sim and enjoy! Phone is Unlocked!
(NOTE: When you change sim to other operator repeat this process to unlock it for that operator also)
I found this in another thread. All credits for the solution to Morfeus of the FuriousTeam!
I myself haven't got a locked Z500 so i cannot try this. But other people confirmed this as working. I'd like to hear more results on this!
I also found a list of service codes. I guess you could use some of them to enter your unlock codes manually(that you read out with WinIMEI).
Check Versions of h/w s/w f/w:
*#1111# S/W Version
*#1234# Firmware Version
*#2222# H/W Version
*#8999*8376263# All Versions Together
Locks:
*#7465625# = Check Locks
*7465625*638*Code# = Enables Network Lock
#7465625*638*Code# = Disables Network Lock
*7465625*782*Code# = Enables Subset Lock
#7465625*782*Code# = Disables Subset Lock
*7465625*77*Code# = Enables SP Lock
#7465625*77*Code# = Disables SP Lock
*7465625*27*Code# = Enables CP Lock
#7465625*27*Code# = Disables CP Lock
*7465625*746*Code# = Enables SIM Lock
#7465625*746*Code# = Disables SIM Lock
*7465625*28638# = Auto Network Lock ON
#7465625*28638# = Auto Network Lock OFF
*7465625*28782# = Auto Subset Lock ON
#7465625*28782# = Auto Subset Lock OFF
*7465625*2877# = Auto SP Lock ON
#7465625*2877# = Auto SP Lock OFF
*7465625*2827# = Auto CP Lock ON
#7465625*2827# = Auto CP Lock OFF
*7465625*28746# = Auto SIM Lock ON
#7465625*28746# = Auto SIM Lock OFF
May 03, 2008 | Lands Phones
As you asked
ok, so all the locks are off on the phone.
The imei code is valid no one has changed it.
Its possible that the phone has been reported stolen?
Apr 27, 2008 | Samsung SGH-E370 Cellular Phone
Codes
Samsung Secret Codes
*2767*688# = Unlocking Code
*#8999*8378# = All in one Code
*#7465625# = Check the locks
*2767*3855# = E2P Full Reset
*2767*2878# = E2P Custom Reset
Mar 08, 2008 | Samsung Blackjack SGH-I607 Smartphone
Nokia N70 Cellular Phone Logo
42 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
