Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
I have a Maytag model MFI2568AES french door bottom freezer refrigerator. I have had problems with the control panel not working. We have been able to get ice but could not switch to water. Now i cannot get it to make ice. I have changed the filter but no luck any suggestions? I have called repairman and his suggestion was to get a new refrigerator. It is only 4 yrs. old is he right?
    President:
  • 1,891 Answers
Don't think you need a new unit . and most of use like the service . the filter does not prevent the ice maker from working . but the water valve does and the tempt in freezer must be 15 deg or lower . ck your fan inside and underneath. both muts be going . hope this helps mm .. and ck with another service theat will be helpfull. mm
Posted on Aug 11, 2010
HOW DO I ACCESS THE CONTROL PANEL ON MY MF12568AES
You probably need a new control panel - need to call your home warranty (if you have one) or call Maytag. Can only get one thru them.
Jun 08, 2014 | Maytag MFI2568AES Stainless Steel Bottom...
CONTROL PANEL NOT WORKING NO LIGHTS NO CONTROLS
Check the power socket its plugged into by plugging something else into it. Thenuse a multimeter to check that power is reaching the board
Dec 21, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
Thermostat location ed2fhgx
Your model does not have the old style thermostat. It uses a=> 12002355 Thermistor
and located inside the control panel and freezer compartment. The thermistors connect to the control board. Here is a parts list and the list shows the thermistors=> MFI2568AES.pdf I am here should you have questions, Sea Breeze
Nov 27, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MFI2568aes:none of the keypad controls work. Is it the control board that is no good?
Check the harness up at the top of the door. Remove the cover and be sure everything is plugged in correctly. Sometimes the harness will work loose do to door movement.
Aug 18, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
Our frig ice cube door chute keeps slaming and the lights are going crazy on the push button board. model MFI2568AES SER 10967637JR
Your control board is bad. Unplug refrigerator and replace it, follow instructions on board to reprogram and you should be good. It's on the back outside of refrigerator under panel. Or, call a repairman to do it for 400.00 plus. Hope this helps,
Oct 24, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag Bottom Freezer Fridge 25 cubic ft. Model-MF 12568AES Code- 0302 Serial #- 10040844JN Problem- Control panel not responding and no water and ice through dispenser.
the control panel is a p c board . maytag call's it a jazz board . and will need to be replaced . not a uncommon problem. also the water will work after tempts a stablized . with the new board . one board fits all but has to be programed for your model . this is a job for your appliance tec . the board comes with very good instructions . . if handy with electronics its not hard .. **** hope this helped ..
Apr 04, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
No control panel
It needs at lest 120 volt feeding the TV its a problem with your plug or breaker panel
Aug 25, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Ice maker is not working anymore. Water doesn't fill the tub. Water dispenser out of the door is still working
I need you to double check the model number. Maytag has a service library at this link. http://www.servicematters.com/maytag_library/html/index.html
By placing the first 3 letters in the search feature it will take you to models like yours. Chose the correct model that you have and enter the number in the search. I believe that the water control valve on back of your refrigerator is the problem. Maytag is very good about helping their customers. Let me know if you have problems gettting the information you need, Thanks, Sea Breeze
May 26, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
What is wrong with my Maytag refrigerator
You have a bad high voltage board call the manufacturer, if the unit is under 2 yrs old they may help cover the repair with the problem your having.
Jul 30, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
237 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
