Question about Refrigerators
Rocker switch that controls inside light doesn't make contact properly..light won't come on...if I manually depress and release the switch the light works...what should I do?
  • Dave Jan 07, 2009
    How do you take out the rocker switch? Do you pry it out with a screwdriver?
  • 487 Answers
Yake out the switch ( power off) and clean it as far as you can. otherwise order a new one at sears and install it. Easy fix
Posted on Apr 25, 2008
2006 Yamaha YZF 600 R Thunder cat oil light comes on when depressing the starting button bike does not try to start oil light goes off after releasing the button neutral light is on all sensors are in...
Hi, Josh and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
http://www.r6messagenet.com/forums/welcome-center/161248-please-help-bike-wont-start-turn-over.html
YZF600R Forums View topic bike build won start
Yamaha YZF R6 2006 Service Manual
OEM parts for Yamaha
http://www.yamaha-motor.com/assets/service/manuals/2002/lit-11626-15-10_65.pdf
Feb 12, 2015 | 2006 Yamaha YZF 600R
Dryer has power but doesn't spin or heat up
Check to see if the door switch "clicks" when you push and release it. If the switch is bad, the dryer won't run. Here is the part in case you need it.
Oct 30, 2012 | Frigidaire FGQ332ES Gas Dryer
I have a Bosch SHU9955US/14 (Integra) dishwasher. There is currently a 0 with and asterisk showing on the display and the unit will not run.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 29, 2012 | Bosch Dishwashers
My Beko MW5104 is frozen and does not respond to any settings. It is permanently on at spin/end with the green light on. I can switch it on and off. I have unplugged it from the mains and switched it off...
Sep 28, 2012 | Dishwashers
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
Why won't 2003 pontiac grand prix. shifter come out of park?
Shift - interlock system problem .
Automatic Transmission Shift Lock Control System
The automatic transmission shift lock control system is a safety device that prevents an inadvertent shift out of PARK when the engine is running. The driver must press the brake pedal before moving the shift lever out of PARK position. The system consists of the following components:
• The automatic transmission shift lock control solenoid
• The automatic transmission park lock solenoid
• The automatic transmission shift lock control switch
• The transmission range switch
With the ignition in the ON position, battery voltage is supplied to the automatic transmission shift lock control switch. The circuit continues through the normally-closed switch to the automatic transmission shift lock control solenoid. The transmission range switch provides a path to ground for the automatic transmission shift lock control solenoid in the PARK position. With the automatic transmission shift lock control solenoid energized the shift lever is mechanically locked in the PARK position. When the driver presses the brake pedal, the contacts in the automatic transmission shift lock control switch open, de-energizing the automatic transmission shift lock control solenoid. This allows the shift lever to move from the PARK position. When the shift lever is out of the PARK position the controlled ground contacts in the transmission range switch open. This prevents the automatic transmission shift lock solenoid from energizing when the vehicle is out of the PARK position.
Jul 04, 2017 | Pontiac Grand Prix Cars & Trucks
Parking brake light won't go off after releasing brake lever
Park brake lights normally operate by a small plunger type switch the turns off when the level or pedal is placed in the off position. Over time the spring in the lever weakens and placing the lever in the off position no longer depresses the switch. The switch can sometimes be adjusted to make better contact, or the switch bracket can be bent so the lever and switch make proper contact.
Feb 17, 2012 | 1992 Toyota Pickup
My Whirlpool Dryer GEW9868KQS has power, but won't start when the button is depressed. The sensing light comes on, but the dryer doesn't start. Any ideas?
It's probably either the start switch or door switch. Try bypassing the switch and see if it starts. If it does,you can either replace the switch or try taking it apart and fixing the switch yourself. (I had a switch that simply required a copper contact to be readjusted and its worked perfectly for several years)
Oct 18, 2011 | Whirlpool LER4634J Electric Dryer
Have a 2011 Hyundai Sonata that is getting stuck in Park and I have to press the shift lock release to put in D everytime
No, that's wrong. The setup on the Sonata doesn't normally require messing with the shift lock release at all. I had the same problem tonight for the first time after owning the car for a year and a half, that's why I looked up this issue.
Jun 19, 2011 | Hyundai Sonata Cars & Trucks
My Cub Cadet 1782 will not start. When the ignition switch is turned the 'Disengage PTO" lamp illuminates. I have changed the interlock switch, but it did not correct the problem. Any ideas?
Is the lamp With the PTO control in the disengageed position.Manually operate rhe switch to determine if depresing or release will put he citcuit in the proper position for starting. Once determined mount the switch to be in that position when PTO conytol is in disengaged. The light should be out when PTO is disengagedm You can use the light when operating switch by hand. Remount switch so control is tripping the switch as neded, either depressed or no contact. Good Luck
May 26, 2010 | Oregon Scientific Electric PTO Clutch for...
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
