Question about Nikon Coolpix 7900 Digital Camera
I need a new battery cover as the plastic catch has broken
I need a new battery cover as the plastic catch has borken on the cover, any idea where I can get one from. I live near Newcastle upon Tyne so anyone near by would be useful.
Regards
Alan
    Sergeant:
    Champion:
  • 301 Answers
Sure , go to ebay or amazon
Posted on Aug 01, 2010
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
One possible source, in a choice of colors, is
http://uscamera.com/cp7900.htm
How do i replace the batteries in the remote for samsung series 7 7100 smart tv
You can replace battery's by lifting the cover by pulling the strap if it is showing if not use a plastic card or plastic knife rise the edge slightly then pull on covers notch with your fingernail to remove cover completely . 2) insert 2 AAA battery's making sure to align the positive & Negative ends correctly . 3) Align the battery cover and make sure you press all the catches .
Dec 26, 2015 | Samsung Televison & Video
Hinges broken, power supply borken, bottom case replace
And you question is? Sounds like you need a new laptop.
Feb 27, 2013 | Computers & Internet
Switch on 1987 toyota pickup cool to heat broken
Tear it apart and see what is borken is all the advice i can offer.
Nov 01, 2012 | Toyota Cars & Trucks
Car will not start.It turns over but will not fire.Remote key control is out.Fuelpump is OK. Battery is new.There must be some electrical short somewhere.Do not have access to a code scanner.75 miles away...
equipped with an SID (Saab Information Display) unit that displays various information about the amount of fuel left, the radio station you're listening to and the key's battery status. It is time to change your key batteries if the key stops working or responds slower than usual. The SID on your car will also say "Replace Key Battery." Saab keys use either a CR 2032 or a CR 1632 battery depending on key type. There are two types of keys. The first generation key has one key and a transponder and the second generation key is a one piece key with a built in transponder.
First Generation Key
  • 1 Loosen the single screw that is located by the key ring. Use the small Phillips screwdriver to remove the screw that is on top of the transponder.
  • 2 Lift the plastic top. Remove the old battery and insert the new CR 2032 battery.
  • 3 Put the transponder back together and tighten the screw using the Phillips screwdriver.
  • 4 Press the alarm five times to re-synchronize the transponder with your car.
  • Second Generation Key
  • 1 Push the plastic catch with the pushpin to open the cover latch. The transponder has a plastic catch that is hard to depress. The pushpin will separate it.
  • 2 Lift the plastic cover. Remove the old battery and replace it with the new CR 1632 battery. Position the battery properly.
  • 3 Put the cover back and press the plastic together.
  • 4 Test the transponder with your car to make sure it is working.
  • Dec 02, 2010 | Saab 9 5 Cars & Trucks
    How do I replace the battery and where is it located?
    Procedure:
    Remove battery cover located under the hood on the passenger side in the back. Simply pry the plastic catch in the front, open it like a lid and jiggle it loose and set it aside.
    Use the small flat screwdriver to pop up the center peg in the five peripheral fasteners holding down the plastic compartment cover that you just removed the battery cover from. Each of these has a small black plastic circular flat topped center peg inside a larger plastic circular disk which has 4 slots under which you can slide the screwdriver to pop up the center peg. When the peg pops up simply slide the screwdriver under the larger disk to remove the assembly and loosen that site of fixation. When all five fasteners are out you can remove the entire compartment cover.
    The battery terminals are removed with the 10mm wrench
    The black box in front of the battery can be lifted out of the way by pressing on the plastic catch in the front of the box to loosen it from the metal flange that it is attached to.
    The metal battery holder is removed with the 10 mm wrench. The nut is removed and the long bolt is slid out of the holder and then unhooked from it's bottom anchor. Jiggle the metal bar over the top of the battery to unhook the back hook from its bottom anchor. It may be necessary to lift the plastic over the back of the battery gently and lift out the soft clear plastic washer fluid tube from its guides to get at the back hook.
    Gently lift the battery out while holding the cables out of the way.
    Tools required:
    10mm wrench, small flat screwdriver
    Procedure:
    Tools required:
    Procedure:
    Tools required:
    Procedure:
    Apr 17, 2009 | 2004 Nissan 350Z
    Hood cable is borken can get hood open
    if its broken at the handle inside the car use a pair of pliers to pull the silver cable if it is broken outside the car there is a black plastic shield on the underside of the car, remove it and the lack will be visible use a screw driver to release latch
    Apr 13, 2009 | Buick Park Avenue Cars & Trucks
    Latch on batterey door is borken,
    here is Vivitar's USA number: (800) 592-9541. They should have what you need
    Jan 09, 2008 | Vivitar ViviCam 4100 Digital Camera
    Interior Door catch broken
    You should open machine's upper panel (release 2 screws in the machine's back and slide the cover out) and then you will have an access to it. You should buy a new door catch and replace the broken one. Be aware that you should disconnect machine's power cable before doing it. Good luck
    May 09, 2006 | Zanussi WJD1257S Front Load Washer
    Nikon Coolpix 7900 Digital Camera Logo
    96 people viewed this question
    Top Nikon Cameras Experts
    Steve
    Jeff Marcus
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
