Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Need repair manual for Poulan P4018WT Chain saw
Need repair manual
Idaho_Biker
  • 32 Answers
SOURCE: 38 cc Poulan Chain Saw
Since You weren't Model Specific...I assumed you meant a Poulan Pro 38cc, here's a Contact Site for OEM Manuals:
http://www.poulan.com/poulanpro/manualSearchResultsAJAX.do
Posted on Jan 18, 2009
rowdy45176
  • 2176 Answers
SOURCE: locate exploded drawing of poulan chain saw
I tried a couple locations and found a site that might help go to psep.biz and it will direct you to the blowup. It also indicated that it needed a type number so have that handy. If this doesn't help let me know and I will research further.
  • 398 Answers
SOURCE: I NEEN A OWER MANUAL for a poulan chain saw 2150
its pretty easy to do with a file. first make sure you buy the right size file to fit right in the tooth. look closley at the chain and figure how to place the file on it. the point is to sharpen the side and top of the cutting part of the tooth .always file one way away from yourself. hold the file at an 45 DEGREE angle, and push forward. the trick is to push forward and up at the same time, and always go one direction. start on one side and mark your starting point with tape, go down one side then flip the saw and down the other. you dont have to push hard just enough to were you can see tiny metal fall off. lemme know if you have a problem
Posted on Mar 21, 2009
rowdy45176
  • 2176 Answers
SOURCE: I need an operating manual for the poulan pioneer
Go to Poulanpro.com and on the right side of site type in model 2050 appaarantly there might be a type number associated with this but I looked at the number 5 and viewed a manual for this saw. It is 18 pages long. Good luck and if I have helped would you please rate this information accordingly. Thank you
Posted on Apr 19, 2009
dontbother10
  • 2220 Answers
SOURCE: I need t find an air filter for poulan 306a chain saw
I got 1 hit for your filter, if you haven' already give them a try "Poulan air filter 530023046"
http://www.lawnmowerpros.com/Poulan-Parts-Search.asp
Lou
Posted on Sep 05, 2009
Having trouble putting on new chain.have no manual.the 2 mounting holes in bar what are they for
There should be some bolts that allow you to tighten the bar, and a slot that allows the bar to slide when you loosen the bolts.
Also, there should be some kind of adjusting screw that allows you to tighten the chain. To remove the old chain and install the new chain, you'll need to completely back off any tension on the adjuster, allowing the bar to move TOWARD the chain saw.
You should keep the chain oiled, and whenever it stretches, even a little, you should adjust the chain according to the owners manual too keep it at the right tension.
The two mounting slots are usually aligned with something that will keep the chain bar straight; such as a bolt or perhaps a pin in the motor assembly.
Mar 13, 2011 | Poulan P4018WT Wild Thing 18Inch 40cc...
Why would a drive sprocket on a poulan wild thing 18" chainsaw wear completely out in less than 35 hours use?
This will happen if your bearing goes out or if you install a chain that is damaged on your saw. If the chain is in bad shape, it puts extra stress on the sprocket, thus making it wear out quicker. Same goes for your bar. Although noone normally does, it is "best" to replace all 3 items at the same time. Usually, though, if there is no visible damage, it's ok to replace just the worn out piece.
You can find replace bars, chain & sprockets for your saw at partsbuggy.com.
Dec 21, 2010 | Poulan P4018WT Wild Thing 18Inch 40cc...
I have an 18" Poulan chain saw, 25th Anniversary
Yes there is.If you can get the broken pieces out of the tank.there should be a filter on one of the broken lines.you will have too buy some gas line 3/16.take some wd-40 and spray the line.this makes it easier to slide through the hole in tank.then loop it around to gas cap hole and reinstall filter.then make sure filter is at bottom of tank and hook back to carb.
Nov 24, 2010 | Poulan P4018WT Wild Thing 18Inch 40cc...
Need to replace the shaft that goes through the motor it broke on the clutch side.
The shaft you are talking about is the crank.I would suggest you replace the saw because by the time and money it will cost to fix it a new saw will probably be cheaper.
Nov 20, 2010 | Poulan P4018WT Wild Thing 18Inch 40cc...
Not starting lacks compression,what's cylinder compression psi
as i tell everyone on this site a poulan saw is cheap **** buy an echo hope this helps
May 25, 2010 | Poulan P4018WT Wild Thing 18Inch 40cc...
I have a poulon p4018wm chain saw that runns but after it gets hot you have to wait for 30-45 minutes before you can start it again
if it gets too hot say from dull blade or not enough lube on chain it can cause gasoline to change to a gas
May 18, 2010 | Poulan P4018WT Wild Thing 18Inch 40cc...
How do you replace spring on a poulan chainsaw
A Poulan "P4018WT Gas Saw Type 1" IPL follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/P4018WT-Gas-Saw-Type-1/75.P4018WT-Gas-Saw-Type-1.1.59.1.html
If yours is not a "Type 1" it can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If the spring is unwound:
Recoil Spring Rewind
I invert and secure the starter housing and rewind the spring large coil to small (need eye protection and both hands). I am right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely rewound. Then bend slightly the inner most part to engage the starter spool. The video explains how to tension the spring.
R² Starter Rope by SmallEng.com
http://www.youtube.com/watch?v=eRyy3MlsjVo
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 23, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chain and sprocket won't move. Poulan P4018WT
Poulan P4018WT Gas Saw Type 2 link below (may not be your saw - 5 to choose from):
It has an inboard clutch. If this is your saw remove the clutch cover, bar,
chain and inspect the chain brake linkage within. Is the brake band tight against the clutch drum? If yes grasp the forward most upper handle and pull it aft (may require some force at rear extreme) until it clicks (a keeper nests in a detent). Is there a little clearance between the brake band and clutch drum? Can you spin the clutch drum now? If yes reassemble your saw.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
If not post back please.
Poulan.com
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 19, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
389 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
