Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
I have a HP LAserJEt M1522nf. It will not print, fax or copy...it will not respond to either the computer or when I press the 'copy' button on the machine to make a manual photocopy. The numeric keypad on the fax is unresponsive....the machine is 'on' and shows no error messsage on the machine itself, but the machine is completely useless. When I startup my computer I the the following message: " HP ToolboxFX has encountered an error and cannot recover. Please re-start HP ToolboxFX, or restart the PC....." "Windows version: Win32NT - 5.12600.196608 HP toolboxFX version: 004.009.00140" I have restarted my computer, and re-started the printer(complete power shutdown", nothing seems to work. What should I do?
  • 31 Answers
This is an official known issue by HP. Call HP Tech Support (800 334 5144 )and claim your warranty. Good customer service!
Posted on Aug 10, 2010
Fax Manual for HP LaserJet M1522nf I need a copy of the Fax manual
Hi absenio45! I found a manual on your HPlaserjet M1522nf. It is on PDF format.click the link below to direct you to the manual.
HPM1522nf Manual(Click here)
Rate 4 THUMBS if i helped you!
Sep 26, 2011 | Office Equipment & Supplies
My HP Laserjet M1522nf does not print a confirmation page after I send a fax. Please help!
Hello, if you go to the reports menu from the control pnel, then to the fax reports sub menu.
From there you cn setup all of the confirmations required.
Jan 07, 2011 | HP LaserJet M1522nf Multifunction Printer...
I get an error 49 message as soon as I try to fax. Then the printer switches itself off and back on again.
Try the following: got to the menu (the wrench) and with the arrows look for service, press ok and look for restore defaults. After that unplug the fax line (this is very important). Go to the hp website and download the firmware update and run it (while updating dont to anything to the printer, no print, copy, fax.) when that is completed try to fax again this should resolve it. If the error persist the formatter (the motherboard) is defective. I think HP repair formatter issues with 2 years from the original purchase.
Sep 07, 2010 | HP LaserJet M1522nf Multifunction Printer...
How do you remove black lines from fax copies?
the glass need to be clean. Even though the glass look clean lines in the copies or faxes can appear. And its normally when using the document feeder. Lift the lit and clean both glasses. The big one and the narrow one at the very left. Use windex or something like that to clean it and try again. If the lines also appear when printing from the pc the issue can be other (fuser, toner, or rollers) try running a couple of cleaning pages from the service menu: press the wrench and with the arrows look for service, press ok and look for cleaning page and press ok again. Good luck
Aug 24, 2010 | HP LaserJet M1522nf Multifunction Printer...
How do i change the ink cartrage on my HP LaserJet M1522nf printer?
Just press a black button underneath the keypad and adjacent to collecting paper tray, then whole keypad component will move upwards,and then you will see deep downwards a print catridge and pull it outward and then replace with the new one.
Aug 18, 2010 | HP LaserJet M1522nf Multifunction Printer...
I cannot Fax in and out...error 49 turn off and on. After i turn on the printer another error show that "power failed to recover Fax setting restore"....please Help~
Jul 25, 2010 | HP LaserJet M1522nf Multifunction Printer...
How to Reset HP Laserjet M1522nf security password
Hi the easiest way is a nv ram
1. Turn the printer off
2. Hold down the down arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
This reset will clear all of your saved settings and contacts, if networked print out a configuration report after resetting the printer to view the ip address (IPV4). If the IP address has changed you will need to update the print driver's port tab and update the port.
Good Luck
Al,
Eliteprintersolutions@gmail.com
Jun 16, 2010 | HP LaserJet M1522nf Multifunction Printer...
No printing, printer says ready, will test print from menu button
Go to my computer, click on control panel, click on printer/fax and see what is set for default. What ever printer icon that says ready, right click and set as default.
Mar 11, 2010 | HP LaserJet 4 plus Printer
Can I send a fax from my computer via the HP LaserJet M1522nf?
Yes you can send fax from computer.You need one dialup connection with Fax modem. then you need fax software. there are many software availble on the net . One is Mighty Fax. you can download it from the internet and many other you can search in google.
Sep 17, 2009 | HP Hewlett Packard LaserJet 3000dn Printer
Printed confirmation on faxes sent form HP Laser Jet Fax M1522nf
To get confirmation page do this:
1. On the control panel, press Setup ( ).
2. Use the arrow buttons to select Reports, and then press OK.
3. Use the arrow buttons to select Fax Reports, and then press OK.
4. Use the arrow buttons to select Fax Confirmation, and then press OK.
5. Use the arrow buttons to select the option for when you want the fax error reports to be printed.
6. Press OK to save the selection.
To iclude first page with report:
4. Use the arrow buttons to select Include 1st page, and then press OK.
5. Use the arrow buttons to select On, and then press OK to confirm the selection.
Mar 25, 2009 | HP LaserJet 4 plus Printer
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
1,102 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
