Question about Bosch 24 in. SHU53 Built-in Dishwasher
Water sitting on the bottom of the dishwasher
My dishwasher has water constantly sitting on the bottom and even after a vinegar rinse with tang the smell is still there. Any idea how to fix this?
  • Anonymous Apr 26, 2008
    I ahve a bosch shu5305 and I notice that at the end of the cycle there is dirty water at the bottom. I tried taking the filter out and cleaning it. no luck with drainage.
    Afraid to run it in case something is blocking the drain and it floods. Any ideas ?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
Disconnect it from you drain and put it into a bucket. Then start a program and then cancel it, the begining should start with a drain anyway. Then you will see if any water comes out. You can also take a shop vac after to get the water out to see if there is any stuck there.
Sgt 48
Posted on Jun 18, 2008
The rinse aid is not emptying into the dishwasher. How can I fix it?
Not sure about the rinse agent but the film is caused by hard water.
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Jan 13, 2013 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
The machine does not seem to rinse properly. We have checked the water fill level, water temperature, spray arms are not clogged, have determined it is not a hard water problem and have tried Glass Magic...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is toadd some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Sep 23, 2010 | Whirlpool GU2700XTSS / GU2700XTSY Built-in...
Our ten year old kitchenaid dishwasher doesn't get the dishes clean. there is food particles left on dishes if we don't completely rinse our dishes. is there a cleanout filter that needs to be emptied?
Locate your dishwasher's filter. It is typically on the floor of the dishwasher. Pull out the bottom rack and look along the bottom of the dishwasher until you find it.
Use a paper towel or sponge to remove any residue or debris that has accumulated on the outside of the filter once you locate it. On some dishwashers, the filter area does not detach or open, so your hand cleaning will stop here. On other models, you can unscrew the filter housing to access the inside and clean any debris from the filter area. Simply wash out the filter using soap and water, then reassemble once cleaning is complete.
Further clean the filter area by pouring a quart of white vinegar into the bottom of the empty dishwasher. Turn to a wash cycle and allow the dishwasher to run with the vinegar cleaning the mechanisms, including the filter.
To deep-clean your dishwasher and the filter periodically, mix the following ingredients together in a bowl, then pour into the bottom of the dishwasher: 1/2 cup salt, 1/2 cup baking soda and 1 cup bleach. Let the mixture sit in the bottom of the empty dishwasher overnight. The next morning run a wash cycle, letting the bleach mixture clean and disinfect the dishwasher thoroughly.
Aug 29, 2010 | KitchenAid Dishwashers
I would like to clean off the calcium deposits that are in the dishwasher. How can I do this or what product should I use.
there are few things you can do to remove the calcium deposits.....
Change the detergent you use. Powdered dishwasher detergent is more efficient in removing grease and oil than gels. Decreasing the gunk left on surfaces may help slow lime scale buildup.
Put a quart of vinegar or lemon juice in the bottom of an empty dishwasher and run it up to the "dry" cycle once a month to keep up with accumulating scale. Extended exposure to mild acid and hot water dissolves most scale.
Clean circulator arms with vinegar or lemon juice and a vegetable brush or toothbrush. Let the acid sit on the scale before scrubbing. Use a needle or hat pin to pierce clogged holes, then rinse by running a cycle with vinegar.
Use plain salt or baking soda to scour surfaces with a sponge or rag. Rinse with boiling water or run a cycle with an empty dishwasher. Do not run the dry cycle.
  • 2 Put a quart of vinegar or lemon juice in the bottom of an empty dishwasher and run it up to the "dry" cycle once a month to keep up with accumulating scale. Extended exposure to mild acid and hot water dissolves most scale.
  • 3 Clean circulator arms with vinegar or lemon juice and a vegetable brush or toothbrush. Let the acid sit on the scale before scrubbing. Use a needle or hat pin to pierce clogged holes, then rinse by running a cycle with vinegar.
  • 4 Use plain salt or baking soda to scour surfaces with a sponge or rag. Rinse with boiling water or run a cycle with an empty dishwasher. Do not run the dry cycle.
  • Read more: How to Remove Lime Deposits in Dishwashers | eHow.com http://www.ehow.com/how_5611602_remove-lime-deposits-dishwashers.html#ixzz0wtABvYq2
    Aug 17, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
    My GE Adora dishwasher is not cleaning well and the detergent isn't completely disolving. What could be the problem?
    Mine has been doing the same thing for about 2 months now.. I tried Finnish brand diswasher cleaner, but to no avail. Try this:
    1) Empty your dishwasher, then take out the lower rack.
    2) Start a regular cycle. Wait until you hear the jets turning, then open the door. Make sure there is enough water in the bottom - It should be just UNDER the heating element.
    3) If your dishwasher is getting enough water, Reset your washer and allow it to drain.
    4) Go to the store and get a gallon jug of white vinegar. Start your dishwasher on a regular cycle.
    5) Once you hear the jets turning, Open the door and add FOUR CUPS (liquid measure) of white vinegar to the water in the bottom. Let the wash cycle complete.
    6) When the wash cycle drains, the rinse cycle will fill. Once the rinse cycle starts, add ANOTHER FOUR CUPS of white vinegar to the first rinse cycle.
    7) Allow the first rinse cycle to drain. Let the second rinse cycle complete normally.
    I know this sounds too good to be true, but it REALLY DID work for me, this evening as a matter of fact! I also bought some hard water/soap film detergent additive from the store. It was kind of expensive, but I'm using it for a while just in case.
    I hope this helps. Like I said, I couldnt believe it when my dishes came out clear again! Also, I turned OFF the heated dry cycle, and just opened the door and pulled out the racks when it was done.
    Good Luck!
    Mar 30, 2010 | GE Adora GHDA654LBG Dishwasher
    Our dishwasher appears to be clogged - suggestions?
    clogged - water not coming in? draining out?
    no water draining out.. you may need to clean out the bottom area of the dishwasher... ick.. but it works. we often use more detergent than needed and it cakes and builds up - along with other "stuff"
    if it's really caked up solid... pour hot water from a pitcher into the dishwasher and add 1-2 cups of white vinegar and let it sit and soak for a few hours...
    After soaking - turn on the cycle to drain and rinse.
    Mar 29, 2010 | Gibson 24 in. MDB632XF Built-in Dishwasher
    Cloudy glasses My dishes are not being cleaned. There is a white residue on my glasses and in the dishwasher itself.
    You may have hard water. Are you using a rinse aid, you always need to use one. Buy some Tang drink crystals and empty a package into the soap dispenser and run the dishwasher through empty. If you can't buy Tang use about 4-6 cups of white vinegar thrown in the bottom of the machine and run the cycle. Sometimes the white residue on the glasses is there permanently and can't be removed it is called "etching" right in the glass.
    Jan 26, 2010 | Kenmore Elite 45986 Front Load Washer
    We have the Whirlpool Gold quiet partner III dishwasher and lately have noticed residue on the dishes after the cleaning cycle is complete. Where is the trap to clean?
    Make sure your water is hot, at least 120deg f. Also, use least amount of soap you can get away with. Usually around 2 tablespoons for soft water. Use powdered soap not gel. Gel leaves a tiny residue each load and will clog up plumbing in dw after 4,5,or 6 years. Rinse agent such as Jet Dry is highly recommended.
    Try the "Tang" trick. Orange Tang drink mix is mildly acidic. With an empty dishwasher, start and fill, then normal drain. On second fill, add a full jar of Tang then let the dishwasher run for a few minutes. Crack the door to stop the dishwasher and let it sit for several hours or overnight. Then close the door, push start and let the dw run through the remaining cycle. This will sometimes clean out the crud in the water lines.
    Hope this helps! Ken
    Jan 06, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
    Major calcium build up. what will cut through it?
    Hello there and happy new year as well
    How to Clean a Dishwasher Dishwasher manufactures tell us that the inside of dishwashers should not need cleaning---after all, it is constantly being cleaned as you wash your dishes. You know better. There is a slimy feeling on the walls or door gasket of your dishwasher---or there is something black "growing" at the bottom of the dishwasher by the drain---or it doesn't smell very nice---or there is a white coating on the heating element (even manufacturers acknowledge this one as common). What do you do? The first thing is to try to prevent as much of this as possible: 1) Be sure your water is coming into the dishwasher at a minimum of 120°; 140° is even better. If your water heater is a long ways from your dishwasher, before you turn on the dishwasher you may need to run the water into the sink until the required temperature is reached. If the water is not hot enough, the detergent (even gel detergents) won't completely dissolve, and you get the slimy feeling on the walls and gasket of your dishwasher. You also foster the growth of bacteria and mold or mildew in your dishwasher. 2) Be sure you are using the right kind of dishwashing detergent. Manufacturers usually recommend using certain brands. That is because they have tested those brands in their machines, so they know they will work. Others may do fine, but they haven't been tested. 3) Be sure you are using the right amount of dishwashing detergent. Ironically using either too much or too little can cause similar problems. The amount you need depends on the hardness of your water, not the amount of food left on your dishes. Okay, you've got all that under control. Now, how do you clean the dishwasher? Problem 1: Slimy feeling on walls and gasket ---Use good old soap and water (yes, soap to clean soap residue!) and clean away. Be sure to rinse well. If you don't you may have suds coming out from around the door the next time you use the dishwasher! Problem 2: Something black "growing" by the grates at the bottom of the dishwasher ---You have a mold problem. This is also what causes a bad odor to "grow" in the dishwasher. The mold is caused by food particles not getting fully pushed through the drain hose when the dishwasher drains. The drain hose is corrugated, and bits of food particles can sometimes collect on the ridges and in the valleys of the corrugation. Given the right circumstances, this can cause a gradual buildup inside the hose, just like cholesterol in our arteries. The presence of moisture and lack of sunlight in the hose allows mold to grow on these food particles. You will want to remove the grates at the bottom or back of your dishwasher (usually removing just a couple of screws will do it) and clean with bleach water (a cup of bleach in a gallon of water) as far down as you can reach. After you have done that, replace the grate, put the rest of the bleach water in the bottom of the dishwasher and run a regular cycle (no dishes, please!). Why not just put the bleach water in and run the cycle? Because that will kill the mold, but will not remove its build-up. You want to remove the build-up first, as far as you can reach---it's easier to remove when it's live. Then kill what's left in the drain. If your problem was serious enough, you may want to replace your drain hose, too. Problem 3: Brown spots on the door gasket ---This is mildew. Mildew can also cause a stale odor in the dishwasher. Use the bleach water recipe to clean the gasket, and then run the rest of the bleach water through a cycle, just as for Problem 2. Problem 4: White coating on the heating element ---This is a build up of minerals, mostly from your water. You may have heard people recommend putting TANG® Drink Mix in the dishwasher and running it through a cycle. This does work to help remove the calcium from the heating element. That is because there is citric acid in TANG®. However, the sugar in it may contribute to other problems you have been trying to clear up. So why not just use plain citric acid---what an idea! You can often buy the crystals in a drug store or in the canning section of the grocery store---it is used for making jelly with a fruit that does not have enough acid in it to allow it to jell. Fill the dispenser cup with the crystals (3--4 ounces), and run a cycle. If the build-up is unusually thick, you may need to do this a second time. So, now you have a clean dishwasher! How do you keep it that way? After all, who wants to have to go through all of those steps every so often? The best thing to do is occasionally run it empty with a cup of white vinegar and a cup of baking soda. How often depends on your water quality, how often you use your dishwasher, how much food you leave on your plates, etc.o there and happy new year as well
    Jan 01, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
    Bosch dishwasher shu3032uc-14 doesn't clean very well tried different things but no help sometimes i can catch top spinner not working all the holes are clean where is the water level supposed to be and...
    Pour a gallon of white vinegar in bottom run halfway thru wash cycle turn off let unit sit overnight to properly soak-then run a couple of times to rinse out vinegar(vinegar dissolves calcium which causes unit to not function properly) also check unit inlet for contaminates and clean as neccesary install inline filter if not one there..(the hot water tank will tell if you have a calcium problem(hard water problem)shut off unit undo relief valve on tank hook up hose to bottom then drain check for white chunks),calcium wreaks havoc on all household appliances and shortens there lifespan!!! :)
    Jul 05, 2009 | Dishwashers
    Bosch 24 in. SHU53 Built-in Dishwasher Logo
    195 people viewed this question
    Top Bosch Dishwashers Experts
    Gerry Harvey
    Gerry Harvey
    Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
