Question about Garden
BCS chipper...clutch won't engage, blades don't turn
I have a BCS chipper with an 8 hp Briggs and Stratton motor. The motor runs fine, but does not turn the chipper blades. There's some sort of clutch that does not engage..and does not turn the v-belt wheel and does not turn the belt. (I can move the belt by hand, by grabbing it and moving it, and that will turn the blades.) How does the clutch work? How can I fix it?
Thanks. Joel in Sonoma
wadembly
  • 513 Answers
SOURCE: Craftsman LT1000 tractor not moving
hello otto i would check the belt that runs to the rearend but the brakes could be also froze up i would try to jack it up & see if it will move then go from there
Posted on Jun 08, 2009
  • 188 Answers
SOURCE: Motor runs but blade does not move. sounds like
It sounds like the spocket gear is stripped, the smaller gear drive may be stripped also. You will need to replace these parts. You can order them online at www.masterparts.net. The part should be listed in your owner's manual. If you do not have an owner's manual you can give your model number and I can try to find a copy for you. They also may have a parts break down Master Parts website. I hope this helps you!
Posted on Jul 17, 2009
  • 5 Answers
SOURCE: Difficult to start chipper while gears engaged
The drive belt may be the wrong size if there is no play in the clutch. I have a 10 hp, but there is a common manual for the 10 and 8. My belt is a 4L380.
Posted on Aug 22, 2009
  • 138 Answers
SOURCE: engine cuts out when engaging clutch or engaging blades..
lift the seat and make sure the connector is firmly plugged into the seat switch
Posted on Aug 24, 2009
  • 468 Answers
SOURCE: 5 hp briggs & stratton on a chipper/shreader
if the starter rope fails to retract, then you need to either fix a broken spring, or put a new one in. You'll have to take the engine cover off, and you'll be able to see how to take apart the retractor assembly. Often times, just the end of the spring will break off, and if you have a grinder, you can grind the correct shape in it again, and reinstall it as is.
Posted on Feb 01, 2010
Starting problem
the blades stop when there isnt enough power to engage electric clutch sounds like a charging issue when the engine is running place a voltmeter to the battery there should be over 13 volts if not replace voltage regulator if that doesnt work replace stator
Jul 19, 2012 | Briggs & Stratton Briggs Stratton Intek V...
I have a craftsman mower with the B&S 21hp Intek OHV motor, it starts fine but when you go to engage the blade or go forward or backward or release the parking brake it will die unless you disengage...
Check the switch on the seat, of all places. There's a safety switch on the seat that will kill the engine if it's not engaged when do anything other than start and run the engine.
If the switch checks out, get back with me.
Jul 06, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Misplaced operation manual for Troy-Bilt Briggs & Stratton Super Tomahawk Chipper/Shredder 8 HP Can it be downloaded? What kind of oil does the chipper use?
Straight 30w NOT 10w-30
prefer air-cooled engine oil from mower dealers or some auto supply stores have air cooled engine oil.
Oct 07, 2009 | Troy-BiltĀ® Briggs and Stratton Chipper
I have rjdeing lawnmower with a BRIGGS&STRATTON 13.5 OHL WHEN YOU PUT IT IN GEAR AND ENGAGE THE BLADE IT LOSES POWER WQNT RUN. FAMLEY 4BSXS.3442VM 275943
if you mean that when you let off the clutch pedal and/or engage the blades, the engine dies, lift the seat and make sure the connector is firmly plugged into the switch attached to the seat.
Sep 28, 2009 | Briggs & Stratton Garden
My Poulan 13.5 hp runs until cluch is released
remove the drive belts from the motor. if it runs ok check your pulleys. one of them might be siezed.if it still dies chk the safety switch on the gear selecter and deck engage lever.
Sep 25, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Blades don't engage
Check the drive belt for the blades
Jul 22, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Jul 12, 2009 | Troy-Bilt Chipper Shredder
Garden Logo
133 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
