Question about Ryobi Factory-Reconditioned 30cc 18" Gas Hedge Trimmer ZRRY30550
How do I take off the drum assembly to get to the pulley system.
Maytag pyg2200aww idler pulley spring replacement
You will have to dis assembly the dryer. UNPLUG, pop the top up with a putty knife, insert between the top and front panel about 2 inches in a press the clip so the top will come up. Remove the screws on each side holding the front on, each under the drum and remove the belt , now you came remove the drum, and get to the idler pulley spring. Re Assembly is opposite of removal.
Aug 27, 2014 | Maytag Dryers
Simpson Maxidry 362. Tips on putting back together....? Roller tensioner spring attached to...?
Here are the steps to get the belt and tension pulley and spring attached properly.
1. Remove the drum from the dryer housing
2. Fit the belt around the drum, secure the belt to the drum (grooved side towards the drum, flat side away from the drum) with small strips of masking tape. Leave a loop of about 10-15 cm's free to fit around the motor. (This was Hurdle #1, it was next to impossible to hold the belt on with one hand and attempt to work out the tension pulley thing at the same time)
3. Place the drum back in to the dryer housing and rotate it so that your belt loop is facing the motor.
4. (Hurdle #2) Attach the tension pulley to the motor assembly bracket. (There should be slots in the bracket for the pulley bracket to insert into. The pulley faces away from the motor, about a 45 degree angle.
5. (Hurdle #3) Feed the belt through (under) the pulley and then over the motor's drive wheel or nub, whatever it's called.
6. (Finaly Hurdle) Attach the spring to the pulley assembly. In the centre of the dryer housing floor, there should be a seam, in the centre of this seam there is a small hole where the other end of the spring attaches too. Stretch and insert the other end of the spring into this hole.
7. Remove the masking tape that's holding the belt down.
8. Re-assemble dryer and your done.
Jun 20, 2008 | Dryers
When the washer is spinning it is very loud.
you need to replance the drum bearings and water lip-seal behind the inner drum,it requires you to completely dis-assemble the machinesfront cover,then remove pulley from drum in rear,drum boot seal,then knockout bearings and seal and replace these then re-assemble the machine in reverse order
Jul 03, 2011 | Maytag Neptune MAH5500B Front Load Washer
We had a new serpentine belt replaced a couple of months ago and it just came off. How can I put it back on? Also the lug nuts seem to be stripped.
Click on the following free direct Link. It has the Serpentine Belt Diagram and Tensioner location for your 2000 Saturn SL.
http://www.2carpros.com/car_repair_information/year/2000/make/saturn/model/sl/2000_saturn_sl_drive_belt_routing_diagram.htm
Before we get to putting it the Belt back on...
Look at the alignment of the Pulleys. Most times the Tensioner or Idle Pulley are "canted" - meaning pitched or leaning forward, which causes the belt to "run off" the pulley - throwing the belt.
With the Belt off: check side-to side play for each one of the Pulleys by hand, especially for the Tensioner and Idle Pulleys. There should not be any side-to side play. If there is any other Pulleys that are canted - check if they are properly tightened. A new belt should not have come off on it's own without some other problem.
GENERAL/Standard Rules to Removal the Serpentine Belt with a Tensioner:
A. Find the Tensioner(s). (See Diagrams on Link)
B. Using a Serpentine Belt Tensioner Tool, Or Wrench OR Ratchet, Rotate/Move the Tensioner USING THE AVAILABLE NUT (on the Pulley or Arm Base) OR the OPENING (3/8ths or 1/2 inch square opening) rotating the Tensioner Pulley/Arm - moving it away from contact with the belt and towards the area where the belt is not in contact with the Tensioner Pulley. The Tensioner is spring loaded, and is hard to rotate/move.
C. Remove the loosened belt off one of the other more easily accessed Pulleys.
D. DO NOT quickly release the Tensioner, but gently allow the Tensioner to rest in its closed position.
Standard Rules for Installing the Serpentine Belt with Tensioners:
a. Pick a Pulley that is most easily accessed. This will usually be on top. This will be the last Pulley that the belt will go on.
b. Using the Diagram: Install the new Serpentine Belt on the remainder of the Pulleys....over, under, left right.
c. Using a Serpentine Belt Tensioner Tool or Wrench or Ratchet Tool: Rotate/Move the Tensioner Pulley/Arm "away" from Belt contact area on the Tensioner. This spring is pretty hard and with a new belt, it will be even harder to install. Rotate/Move this to as-close to the maximum allowed inorder to have enough slack in the belt to get it up and over the last pulley.
d. Using your other hand - Pull the Belt up and over the Last remaining Pulley.
e. Before releasing the pressure on the Tensioner, visually inspect the remainder Pulleys and the Belts' Positioning on them.
Regarding the Strip Lug -Studs.
Is this on the wheels with Rotors (Disc) or Drums? If the tire was not properly mounted, or the Lug Nuts were not properly Torqued; this will cause the Lug Studs (bolts) to be stripped.
With the vehicle raised and properly supported by jack stands:
For Rotors:
Remove the Tire, Brakes (Calipers/Pads) and Rotor, exposing the Wheel Hub (Bearing) Assembly with the Studs fully exposed. Rotate the Wheel Hub to a location where the Lug Studs can be clearly removed FROM THE REAR OF THE WHEEL HUB ASSEMBLY.
Using a impact hammer or mini sledge hammer: Hammer the Lug Studs back thru the Wheel Hub Assembly.
Remove the loosened Lug Studs.
For Drums:
Raise, support, remove the Tires.
Remove the Drums off the Wheel Assembly.
Using a impact hammer or mini sledge hammer: Hammer the Lugs back into the drum, removing from inside the Drum
Purchase the new, correct size and length Lug Studs and new Lug Nuts. If the Studs were stripped, most like the Nuts are too.
To reinstall the Lug Studs: Purchase an additional two (2) Lug Nut that fits that Lug Stud. Also purchase several Large Heavy Duty Washers that can fit on the the Lug Studs.
Place the Lug Stud back into the Wheel Assembly from the Rear (Rotors) or from inside (Drums). Use High Temp Grease for the area of the Lug Stud Splines that have to be "drawn" into the Wheel Assembly (with Rotors) or into the Drum.
After the Lug Studs are "IN" as far as they will go: on the outside place at least two (2) of the Washers on Lug Studs. Use a Lug Nut and tighten as far as possible down-on the Lug Stud as possible.
Next: Using an Impact Wrench tighten that Lug Nut down/on, drawing the Lug Stud into the Wheel Assembly/Drum. Check the rear of/inside the Wheel Hub Assembly/Drum. The Heads of the Lug Studs should be firmly against the Wheel Assembly/Drum.
If you do not have a Impact Wrench - use at least a 24-in Breaker Bar and Tighten the Lug Nut on, drawing the Lug Stud into the Wheel Hub Assembly/Drum. This takes longer and alot more work, compared to 10-seconds using the Impact Wrench.
Repeat as necessary.
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.Com!
Mar 31, 2010 | 2000 Saturn SL
Changing a dryer belt on a Maytag DE410
in some models you do it from the front the drum sits on 2 bogie wheels and the belt sits behind ,lift drum off bogie wheels and thread belt around pulley it should be on a spring tensioner and it allows you to swing pulley up or down try to thread belt around drum and replace drum back on bogie wheels.... in some dryers you may need to thread belt on drum and then onto pulley good luck
Dec 18, 2009 | Dryers
I have a kenmore 27 inch electric dryer that when you push the start button it sounds like it starts but the drum doesn't turn. What could this be?
A clear indication that your dryer belt is broken is when the dryer drive motor runs but the drum does not rotate. A new belt is relatively inexpensive from several online or a local parts vendor, but installing it can be a bit frustrating since the dryer drum usually needs to be remove to install a replacement belt. Access to the interior of the dryer is usually necessary. For Maytag (and some Kenmore) models, the front of the dryer can be easily removed (two screws below front contour) by pulling out on the bottom of the panel and rotating up to release the top clips. Once off, place to the side, then remove four machine screws from the front drum/lint filter assembly, then remove by pullling out. Once off, place aside. Remove drum by lifting up and pulling out on drum (since the belt is broken it will not provide any resistance). Once removed, inspect the motor pulley arrangement noting the belt routing path around the motor pulley, belt tensioner, and the drum. Inspect the drum for belt wear marks, noting approximate location on drum where belt rides. Install replacement belt by routing through pulley arrangement (ridged side of belt rides againt motor pulley), then "hang" the belt on the interior backside to enable reaching the belt after reinstalling the drum. After placing the drum edge on the rear rollers, lift the front of the drum up into position, working the belt around the drum into the drum groove. Once the belt is in the groove, the drum should stay in position without lifting from the front. Check for proper pulley routing, taking care to avoid routing the belt OVER the tensioner belt keeper, i.e., route the the belt under the belt keeper to avoid belt riding on the keeper and failing prematurely. Install the front/lint filter assembly. As you manually rotate the drum, reach along the top and side of the drum and gently pull the belt out of the groove and into its normal ride position. Install the front panel, plug the unit in, start and check for proper rotation of the drum.
Oct 04, 2009 | Kenmore Dryers
The belt fell off of the drum, i have the front off but i dont know where the disconnected pulley goes.
Unplug dryer or disconnect power.
Locate mounting slots in front of motor. (In some cabinets, there are two sets of slots for mounting the idler assembly. In this case, mount the idler assembly in the slots that line up under the grooves in the motor pulley.)
Install idler assembly into cabinet base by hooking mounting tab (A) into 1⁄4" wide mounting slots and setting mounting tabs (B) into the 3⁄16" wide mounting slot.
Make sure belt is around drum, with grooves down.
Route belt through the idler and around the motor pulley.
Sep 12, 2009 | Whirlpool Dryers
Installing drum belt on dryer trouble accessing pulley b/c blower
Hi, There are many different models/makes. Get me the model # and I can help you with this.
Vic
Jul 15, 2009 | Dryers
Drum belt assembly
take the belt and put it around the drum with the grooves touching the drum, then push a loop of the belt thru the idler pulley bracket and hook it onto the motor pulley. then the idler pulley and bracket will cause tension on the belt. if you need to see a picture then search your model number on google and it should show you a picture of how the belt goes around the motor.
by the way you dont have a good model number, or it is too new to be in most web sites.
Jan 22, 2009 | Kenmore 72802 Gas Dryer
Stainless steel drum loose
A loose inner drum usually indicates a failed rear tub bearing. The only solution is to replace the rear half of the tub. (which contains the bearing).... You can check if the pulley nut has come loose by removing the rear panel. There is a large nut that retains the belt pulley to the shaft of the basket.
Jun 04, 2008 | Kenmore Elite 45986 Front Load Washer
Ryobi Factory-Reconditioned  30cc 18" Gas Hedge Trimmer ZRRY30550 Logo
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Phil Walker
Phil Walker
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
