Question about Jenn-Air Kitchen Ranges
How to replace an infinite control switch on jenn air model s160
4 Suggested Answers
  • 1073 Answers
SOURCE: Infinite control switch
they are as they are manufactured, but a small adjustmet in either direction will varry the temp greatly and can overheat the element
Posted on May 31, 2008
SOURCE: Jenn-Air S160
What is 15 year old Jenn air stove, model S 160 worth? It is in good shape and has just recently been checked by SEARS and operates fine. New racks, new knobs, and new broiler pan. Completely cleaned up. Looks like new!
Posted on Oct 17, 2008
  • 189 Answers
SOURCE: Just replaced infinite switch part # 12002125 ...
Hello- First of all, congratulations on getting it out, apart, and back together again! There are two types of switches for this cooktop. One for the dual, other three are single. Wires can be a trick sometimes. Replacement switches look different sometimes, but work the same. If part is correct, check wire connections at contact points. Lightly crimp any loose ones. Partselect.com has the wiring diagram for JED8430.  Let me know if this info helps- have more if needed. - Thanks- ED
Posted on Mar 06, 2010
My folks recently purchased a house with a Jenn-Air S160 electric grill-range/oven. The left hand side electric burner cartridge's back burner superheats on the low setting. I've switched the burner...
Sounds like the problem is in the control assy. especially if you switched the burnners and the problem remained. Go to the jenn-air website and see if they have a parts breakdown for your unit.
Record the model number of the unit before you search, you will need that info.
Apr 16, 2011 | Microwave Ovens
I have a Jenn Air S160 stove and the burners stopped working. Is there a reset button? The grill does work on one side but the burners do not. Thanks, Pam
Try switching the grill to the other side if it works the ceramic burner is bad replace the ceramic burner. burners and grill coils unplug when you pull them out. The left one pulls out from the front the right one pulls put from the rear. you can enterchange the burners on either side.
Oct 07, 2010 | Jenn-Air Kitchen Ranges
I have a Jenn-Air radiant cooktop, two of the burners run on high no matter where the control knob is set?
This is usually the infinite switch has failed. They are easy to check and inexpensive. Here is a video that will walk you thru testing an infinite switch. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
Oct 03, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Jenn-Air s160 exhaust fan squeals when the stove top is on
The only repair is to replace the fan motor.
Aug 25, 2009 | Jenn-Air Ovens
My Jenn air SVD48600P heating element dose not heat
Hi. I believe this info. may assist you in getting your bake and broil up and running:
When your heating element burns out, you have to replace it because they are not repairable. If, when the heating element burns out, the infinite switch that controls it also fails, you have to replace it too.
May 31, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Three of my Jenn Air burners (electric) only work on High - OLD
Hello
Welcome to Fixya
My name is Huum,
you can find the schematics, diagrams and parts here at this site . just enter the complete model number that is written on the stove sticker and access the info
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080204x00001a
Please remember to leave a rating before you leave
Dec 08, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air S160
I did it by mistake. I tried to move the lever over and of course, it didn't open but went to restart. I hit the cancel button and then tried the door again and it opened. Yup, we all here feel likes dorks!
Thank you!
Sep 06, 2008 | Kitchen Ranges
May 31, 2008 | Jenn-Air JES9750BAS Stainless Steel...
Infinite Switch Replacement
one switch cant affect them all check for a central power problem low voltage weak breaker loose wires on cord loose terminals in outlet box etc.
Feb 17, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Can't control temp of one element, is either high of off, nothing inbetween
- The infinite switch for the controller likely needs to be replaced, this part can be ordered from your nearest Jenn-air parts dealer
Mar 13, 2007 | Jenn-Air JED8230 Electric Cooktop
Kitchen Ranges Logo
71 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
