Question about Kenmore 23822 Top Load Washer
How do you get the top of the cabinet off of a Sears heavy duty washer series 80, model #11092283800? It vibrates excessively w/o a load.
  • 714 Answers
Should be 2 screws in the control panel ,some panels you need to remove the end caps to remove them,then just flip the control panel back it has plastic hinges so be careful,then you unplug the lid switch,pop off the 2 gold clips holding the back panel to the housing.then just reach inside the lid tilt slightly towards you and lift off the frame.
Posted on Aug 01, 2010
Testimonial: "Thank U dirt1dobber, the top of the unit is off. Now what do I look for that wud make it vibrate w/o a load in it? "
I have a Kenmore Ultra Fabric Care Heavy Duty 80 Series, Model # 92588210, Stock # 25882 that is off balance on every load. After the last few loads the bucket is leaning toward the front. What could be...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11092588210/0582/0153200?pathTaken=
and you'll see a list of major sub-components with diagrams and parts.
If you look at the section on "Machine Base Parts" you'll see a number of springs and vibration pads.
It's possible that one or more of the springs or pads has come loose or broken.
In order to get to them you have to remove the cabinet.
Here is a description of how to do it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=90fdc122f6335c7c64f46f2ea1b1c887
Also see the Whirlpool Service Manual for top load washers. It has a troubleshooting section that describes the reasons for excessive walking or vibration.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Jan 05, 2011 | Kenmore Washing Machines
My kenmore series 80 heavy duty washer it making a knocking noise like it is off balance,,,, we replaced dog agits and cupler today and it is still doing it just on the spin cycle.... this is with no...
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
If it's not the springs or pads, you may consider that the "Agitator Cams" in the transmission are not raising the Agitator Gear high enough (about 1/16" ) when the washer goes into spin mode.
See the description of what the Cams do in the Service Manual.
We had the same problem, excessive vibration and noise during the spin cycle.
In order to solve that problem, :
Assuming that you know how to remove the cabinet, agitator (you don't need to remove the tub), pump, motor and transmission the agitator cam and follower use the same whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
Pull the transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
It sounds a bit complicated but it really isn't too bad and (For a $15 part, saved buying a $170 transmission.)
Following is the Whirlpool parts list for their commercial washers although the consumer models use the same part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Nov 19, 2010 | Kenmore 24032\24036 Top Load Washer
I have a kenmore heavy duty series 80 that vibrates excessively w/no no load in it. It does not hit the cabinet but shakes like crazy. It is level in all directions.
It's most likely that one or more of the springs or pads has come loose or broken.
Aug 04, 2010 | Kenmore 23822 Top Load Washer
Kenmore Heavy Duty 70 Series Model 110.26722693 is easily unbalanced in spin cycle.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26722693
Jan 25, 2010 | Kenmore 24032\24036 Top Load Washer
How many cubic feet are in the Kenmore Washer Model 110 80 series
The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches.
Oct 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Won't spin or drain
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore 22422 Top Load Washer
80 Series top loader excessive vibration and noise on spin
check the screw feet, on the front corners, one may be not screwed down far enough to be 'tight' to the floor allowing a small movement that makes a lot of noise, halting under pressure suggests this is the case
May 26, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer out of balance
go to sears.com and find the parts listing for the 110 model number you have listed above .http://www.searspartsdirect.com/partsdirect/retrieveModelActionHome!retrieve.action;jsessionid=8mJfynqZfmsdSyTnd9kaQw**.shcapp3005?modelNumber=110.16502694+&pop=flush
You might need one of the springs. unplug the washer and take the cabinet off first. look around for broken or missing parts
May 12, 2008 | Washing Machines
Kenmore 23822 Top Load Washer Logo
170 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
