Question about Epson PowerLite 7300 Multimedia Projector
Pixel alignment problem with Epson Powerlite 7000 projector
I have an Epson Powerlite 7000 projector. There appears to be a pixel alignment problem. When looking at something simple like the "No Signal" screen, the green image of each letter appears to be about 1 character to the left of the red and blue images.
  • 27 Answers
SOURCE: epson powerlite 7700p video problems
could be, colour change is typical of a pj lamp expiring.
check first the connection lead between pc and pj
to make sure pj is seeing all signal pins on sub d lead.
check pj with video sig input, if thisis ok it's not the lamp failing
Posted on Feb 26, 2008
chilibball
  • 85 Answers
SOURCE: blue dots in the middle of the screen
The image processor must be getting old and worn out. Call Epson or go onto their website and see if it is  a dDIY project or if you will ned to send it in.
Posted on Apr 27, 2008
  • 110 Answers
SOURCE: Epson PowerLite S1+
You have not set the port on the back of the projector settings.
Go into the projector menu and go into the IMAGE area. Somewhere in here you should be able to select computer.
Posted on Aug 22, 2008
zabolyx
  • 38 Answers
SOURCE: epson powerlite s4 projector is pink
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the red color has gone out. The image is made up of red, green and blue images layered upon the screen. If the red panel has gone out then there is nothing filtering out the red light in the image. This causes a nice red hue to the whole screen.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
Posted on Apr 01, 2009
zabolyx
  • 38 Answers
SOURCE: images has a blue color across the center
Wow, 3 in a row. As described on 2 other projector issues this is very similar to those others. I'll repeat the info here.
This sounds like the LCD panel used for the blue color has gone out. The image is made up of red, green and blue images layered upon the screen. If the blue panel has gone out then there is nothing filtering out the red light in the image.
It looks like yours has just a secone of the panel dying or comming loose from it's connector.
Just noticed a yellow spot appearing on lower right side of screen. I this fixable, will it get worse?
This is most likely from a magnet coming near your screen if you have a speaker that is near your screen move it away and sometimes it will fix the problem if this doesn't fix the problem sometimes in your settings of the device there is a degaussing setting either way is most likely from a magnet coming near your screen
Sep 06, 2015 | Epson PowerLite 1261W Multimedia...
Epson 7800P projector?
Please dont use cheap alternative Lamp Bulbs in Epson. There are issues where the cheap Bulbs draw more current and damaging the circuit board.
Apr 22, 2014 | Office Equipment & Supplies
Changing the bulb on a epson powerlite
Original lamp USD110
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Apr 11, 2012 | Epson (V13H010L34) Projector Lamp for...
I have a problem with the picture on my Infocus IN1501. It has small squares on it and I see every pixel. How do I remove this?
Generally the screen is full of pixels, and thats a good thing.
It's a problem when you see the pixels that should be off, and don't see them when they should be visible.
So I presume that your pixel problem may be the first type where they appear when they should be hidden.
Now it would be good to know if the bad pixels are all one colour, or if you have chromatic pixelation problems.
Monochrome pixel problems are better than chromatic pixel problems. But alas all pixel problems come back to the DMD or the colour wheel.
Either way your machine is basically compost material for the garbage shredder, unless you want to pay big money to replace the faulty bits.
Ask the local serviceman or servicewoman to give you a quote to look inside the unit and see where the pixels have gone astray.
Mar 17, 2011 | InFocus IN1501 DLP Projector 3000 Lumens...
My Epson PowerLite 1725 projector has a wide green bar displayed in the middle of the screen with a purple shadow on its right. Do you think a bulb replacement would fix it?
im afraid that sounds like some dead pixels. and if thats the case then no a bulb wont fix it. call epson tech support and see if they will replace it for free.
Mar 05, 2011 | Canon LV-LP12 Projector Lamp for LV-S1,...
How do I reset the lamp hours on an epson powerlite 7250 projector after replacing the bulb?
EPSON PowerLite 7250
Reset the lamp counter hours in 3 steps
1. Make sure, your projector is ON
2. Hold down the Help and Menu buttons for 5 seconds.
The "A.S." screen will appear.
3. Hold down the Tracking and Tracking - buttons for 5 seconds.
Dec 05, 2009 | Epson Office Equipment & Supplies
I have an Epson powerlite s4 and a yellowish patch appears on the screen as I turn on the projector
The likely cause is either dirty optics inside the projector or some of the special mirrors inside the optics are burned. If the projector was used a lot then the special mirrors are probably burned. If it's just dust on the optics the unit could be opened and cleaned but you might have to take it in to a repair place to have that done.
Aug 25, 2009 | Epson PowerLite S3 Multimedia Projector
Small bright dot
Pixel Mapping is a feature of the camera to check and adjust the CCD and image processing functions. Locate Pixel Mapping in the camera's Mode Menu and select OK to activate it. Once Pixel Mapping is completed the Mode Menu displays. The bright dot should no longer appear in your downloaded images.
Sep 04, 2005 | Olympus C-7000 Zoom Digital Camera
Epson PowerLite 7300 Multimedia Projector Logo
183 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
