Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Constant code 91! after only 1 week my first chlorinator was replaced due to this code. Have been using my replacement for approx 2.5 weeks and got my first code 91 - added 1 bag of high purity pool salt but still got the same alarm. cleaned the electrolytic cell as instructed by manual and still get code 91. am being shipped a replacement cell but wonder if it's unusual to get 2 electrolytic cell failures? i didn't run the filter for 24 hours after adding the salt, could this have caused this recent failur? please advise what i'm doing wrong....Krystal Clear system model CS8110
  • 297 Answers
A few things to do or you will create your own problems.
First and for most you must filter for at least 12 hours after adding salt to distribute the salt completly
You can not just blindly ad salt like you said you added a bag.
Although the manuals have an amount of salt for different size pools it is just a starting point. It is up to you tp fine tune
you must get a salt test kit
the kind that reads #'s not color
Get your salt as close to 3000ppm as possible
any lower than 2700 and you will get a low salt alarm and you will also not be producing enough chlorine
any higher than 3500 and you can go cloudy, trigger high alarm, and the water will taste nasty
you can even trigger low salt with too much salt content
So remember 3000ppm
If you are higher than the 3500 then drain 20% water and fill with fresh
continue this until you get to close to 3000
If low follow directions for low salt either on the test directions or bag of salt
I have had my system for this being the 4th season and have never cleaned the cells
any way, when you get the pool to around 3000 filter only for about 12 hours then turn on your generator
It should work fine
Posted on Aug 02, 2010
Testimonial: "thanks so much for your input-you're quite right about blindly putting in salt. i will do asyou suggest"
I have done everything the manual says, but my saltwater system will not stop blinking error code 91. The salt level is fine, and the cell is clean. Do I need to replace the cell. My pool is now green and...
Bummer!!! Looks like you checked both things that would cause the code 91 error for "Low Salt". Here's what I've done to solve my low salt "91 code in the past.. I overshoot by 1/2 bag = 20lbs of the recommended salt add quantity when the code appears. Calculate by using this formula..
.0067 X Pool Gallons. I have a 14,000 gallon pool and when I get the 91 code for low salt, I add about 110 lbs of salt. Manual says 93 lbs...let it circulate for 24 hours by running the pump only and then start the chlorination cycle.. Before doing this, you MUST make sure the cell in clean.. If any calcium buildup inside, it can give you a false "Low Salt" alarm.
I hope this helps!!
If this helps, please rate... Thanks
Jul 17, 2011 | Intex Automatic Salt Water System for ...
Chlorine generator not working(brand new)
Super shock your pool ... take it to around 20 ppm CL using liquid or powdered CL. Brush your pool daily for several days ... run your filter at least 16 hours a day ... 24/7 would be better. Maintain 5 ppm CL and brush weekly after you get the algae under control.
Jul 23, 2010 | Intex Automatic Salt Water System for ...
Have put 280 lbs of salt in my 9300 gaoole pool and still getting the low salt light. What is the next step? Just set up the pool last week but the chlorine converter is from late last year. It did not...
By my calculations you are about 50 lbs over the requirement. Which code are you getting? I'm guessing code 91. Have you removed and cleaned the electrolytic cell from the chlorinator? I get lots of calcium on mine from hard water from the well requiring a cleaning at least once per week. If you get this working and get a warning that you now have too much salt you'll need to drain off water and re-add to get the salt content correct.
Jun 04, 2010 | Intex Automatic Salt Water System for ...
TCS ABS lights on & alternator not fully charging
Alt shoud be putting out 14 to 15.2 volts.
Jul 02, 2009 | 2002 Hyundai Santa Fe
Leaks after a couple of weeks use
You may need to put a hartford loop in your plumbing between your chlorinator and the heater. The chloriene will back up in the line bad when the pump is off and corrode the exchanger. A hartford loop is simpley a loop than runs low then high above the top of the heater so it can trap gasses in the line and won't let them get back in the line. If all else fails you can use a floater. Be sure to check your PH also. Good luck.
May 30, 2009 | Hayward H Series Electronic Ignition...
DSC W55 Error code E:91:01
I've had the camera for about 2 years. Have had this problem twice. All I've done is follow the manual to reset/initialize the camera's original settings. After that it works pretty good.
Mar 24, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
1,907 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
