Question about Maytag 21.7 Cu. Ft. Top-Mount Refrigerator - White
Ice maker is le
Top-mount freezer's ice maker is leaking into the bottom of refrigerator making all the food in the bottom wet. Any suggestions for repairs?
    President:
  • 1,099 Answers
Check the hose under your fridge that drains condensation and such into a catch tray. Make sure the hose is draining properly.
Blow air through the tube to make sure it is not clogged. A coat hanger wire can be inserted to break up clogs. An alternative method is to use a bicycle pump to force air through the drain hole to remove any obstruction. Vacuum dust bunnies from under the fridge to allow free flow of the air. Most refrigerators periodically blow warm air across the condensation tray. The warm air dries the condensation in the tray.
Good luck......
Posted on Aug 01, 2010
Why is the freezer not freezing and why is the ice maker making any ice?
I suggest that if you call a service representative and have someone come service your appliance.
May 12, 2017 | Refrigerators
I have a Kenmore Model 795 refrigerator with an ice maker in the bottom drawer. We purchased the refrigerator in August of 2008 (currently November of 2010) and finally hooked up the ice maker last week. ...
The 795 model you make reference to only tells me that this is and LG bottom mount Refrigerator. There are several numbers missing from the model number. This is and example of a good part number: 79577253602 The filter for bottom mount LG units is usually in the upper RH side of the fresh food compartment. See this link: http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fK0810366-00001.png (item 611E)
The weak chlorine taste should fade unless the source is from your house water supply. Let the ice catch bin fill completely once and then dump everything in it. After that your ice should be normal. I think you may be noticing the taste you get from unused plastic tubing / water carrying parts. Just so you know if anyone used bleach to clean the freezer compartment the ice maker will catch any bleach water drips and pass that immediately into the ice. (Have very long customer warranty story with repeated in home visits about how I learned about people using bleach to clean freezer compartments!)
I digressed... just dump the ice collection bin after it is full one time and then check the ice taste on any ice after that. If you think maybe the taste is originating from the freezer compartment get a box of Arm & Hammer Baking Soda, cut off the top of the box and leave it in your refrigerator freezer for 6 weeks then toss it in the trash.
Another note no manufacturer will tell you is if you install a cheap in line water filter before the refrigerator water connection you can make the EXPENSIVE ONE on inside of the fresh food compartment last a very very long time.
Thanks for choosing FixYa,
Kelly
Nov 15, 2010 | Refrigerators
Our Kenmore Elite (new last summer) bottom freezer double top doors, stopped making ice. The wire that seemingly controls the ice maker is hanging down in a way that is causing difficulty opening the...
Well, that wire is likely the cause of your issue, somebody probably bent it, and now it gets caught on the door or a basket or a food item or what have you, and since it cannot move, the ice maker will not make ice.
Aug 13, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My freezer isnt working
this may sound stupid but is the ice maker turned on? Does it say "ice" in the display? If it does, check to see if the ice level arm is jammed into the upper position also make sure that the ice bin is in place (it actuates the ice maker switch) make sure there is no ice stuck to the top of the ice maker
Jun 16, 2009 | Sub-Zero 700TC Bottom Freezer Refrigerator
Foul odor coming from freezer. Kenmore model w/ freezer on top.
Clean the refrigerator thoroughly fresh food and freezer under all drawers. Then place charcoal briquettes in each 8 or 10 total. 4 or 5 in the bottom of the fresh food section. leave the for several days. If that doesnt take away the smell consider if a mouse may have gotten into a fan blade and well that can create a really bad smell.
Jan 10, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker not making ice. Water disp inside frig disp water.
the line that gives water to the ice maker, every time the water comes down it lives a drip of water that turns to ice blocking the line, get some hot water and a towel and place the hot wet towel on top of the line intel it melts the ice in side the line. it happens to my frige at list once a year. if that is not the problem the valve that supplies water tho the ice maker needs replacing, it's behind the frige at the bottom, where the line coming from the house meets the frige.
Dec 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ice maker doesn't work
I have the same problem. I've had the freezer for 2 years & ice maker just stopped making ice this week. Freezer works O.K.
Jan 11, 2008 | Frigidaire 20.6 cu. ft. Top Freezer...
Maytag 21.7 Cu. Ft. Top-Mount Refrigerator - White Logo
118 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
