Question about Vacuums
How do I replace the belt in my hoover empower
There's a plastic cover over the agitator. (the part that should spin, with tough bristles)
Unscrew it. Pull out the agitator. Put the new belt over the 'spinner' (the part that's connected to the motor) and the special pafrt of the agitator. Snap the agitator back into place, making sure it's secure on both sides.
Screw back on the plastic cover.
Wallah!
Posted on Apr 25, 2008
Hoover empower belt need replace
To gain access to the belt: remove 2 screws at the top rear cover, next remove 2 screws at the bottom front cover. This will allow the cover to be removed. Then remove 3 or 4 screws that hold the roller in place (from the top). you will be able to see the belt and replace it.
Apr 18, 2010 | Vacuums
Does not vacum
You may have a broken or stretched belt. The machine could also be clogged. Here is a link that will take you to a site that will show you how to open up your vacuum to look for clogs and to change belt.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Hope this helps.
Jan 29, 2010 | Hoover U5262-900 / U5260-900 / U5266-900 /...
My vacuum doesn't seem to be picking up debris
That means that you need to replace the belt. Here is the belt you need and the manual:
Hoover EmPower Belt and Manual
Jan 08, 2010 | Hoover U5262-900 / U5260-900 / U5266-900 /...
The beater bar doesn't move when you push the vacuum. If you lift the vacuum while it's running, it's going like crazy!
replace the belt, it is so stretched that it is slipping on the beater bar when it comes in contact with the carpet. it takes the 38528-040 belt. i think its 5 screws on the bottom to gain access to beater bar and belt.
Jan 05, 2010 | Hoover U5262-900 / U5260-900 / U5266-900 /...
Need to know how to replace belt on a hoover empower model # U5262-910
Here is a link to the belt you need and to a manual you can view with instructions:
Hoover Empower Belt and Manual
Nov 28, 2009 | Vacuums
How do you change a burnt belt for hoover u5269
If you go to this link you will find the belt you are looking for and you can also view the manual, which has step by step instructions on how to change the belt. Good luck!
Hoover EmPower U5269910 Belt and Manual
Oct 26, 2009 | Hoover U5269910 Bagless Upright Vacuum
Hoover Empower Widepath Vacuum Doesn't ****
This model requires the lower end of the hose to be installed into the base unit to pick up the dirt. If it is properly installed, I would check the belt and also look for a blockage. The normal life span of a belt is about 9-12 months. your belt # 40201190 2 pk
Mar 11, 2009 | Hoover U5172900 Fold Away Widepath Bagless...
Have the empower upright cleaner. belt broke. can not find part #36528-040belt. can find a lot of hoover belts but not this #.Is there another hoover belt that will work on this vac?
No. if the wrong belt you will have problems. This is a common belt for Hoover, it used to be 36528027, but the number changed to the 36528040, also 40201190 is the newest number for this belt. Most repair vacuum repair shops should have this belt. You order it online at http://vacuumsuperstore.com/hoover_belts.html
Jul 13, 2008 | Vacuums
Hoover empower
Don't ignore your instincts. If you think it smells like a scorching belt, you're probably right. Check that the pulley the belt is meant to spin is free to turn. If it isn't, find out why and then sort that out. A.
Feb 24, 2007 | Hoover U5262-900 / U5260-900 / U5266-900 /...
Vacuums Logo
238 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
