Question about Canon PIXMA MP520 InkJet Printer
Error code 5700 - Canon PIXMA MP520 InkJet Printer
    Scholar:
  • 126 Answers
The error code you have supplied does not provide enough information to resolve this issue.
download and install this small repair utility from Canon for your printer-
http://software.canon-europe.com/software/0038012_0010487.asp?model=
follow the on-screen instructions and it will diagnose your issue and provide a solution.
if this does not resolve your problem reply to this post with the result of the software's diagnosis.
//javaftper
Posted on Aug 01, 2010
What is error code 5700?
I have seen this error a few times through the use of our inklink products.
The error 5700 is as follows:
This error takes place when feeding paper
from the ASF after an error occurred in the
ASF cam sensor.
Make sure that there is no paper jammed in the printer and nothing is blocking the paper path.
Oct 15, 2013 | Canon PIXMA MP520 InkJet Printer
Error code 5700 turned off and unplugged. wont let me do anything
ASF sensor error or Error Code 5700
An error occurred in the ASF cam sensor.
Problems and Solutions:
Replace one of the following:
- ASF unit
- PE sensor board unit
- Logic board
This is hardware error and you need to show it service center. Following things you have to do.
- ASF unit
- Logic board
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 24, 2010 | Canon MX700 Office All-In-One InkJet...
Error 5700 impresora MX700
"Printer died after 1 1/2 years, error code 5700." on May 1, 2009 by danmc7777 (2 reviews)
Pros: This is a pretty decent product as far as ink jets go.
Nice to be able to use the feeder to scan multi-page documents and even cover two sides by running two passes and then the software interleaves the pages to make a seamless pdf file.
Cons: Ink jet technology. It worked very nicely for a year and then a few jets plugged up and wouldn't clear out even with cleaning.
Today the unit is dead, reporting error code 5700 and refusing to do anything after a paper jam.
Cartridges with chips.
Summary: I was pretty happy with this printer until one day it decided to grab about 30 sheets of paper at one time from the top feeder. This created a pretty major jam, and it reported the error code 5700. This jam must have stripped something in the gearing since now all it will do is report this error even after power cycling. Web search reveals that this is a serious fault that requires it to be sent in for repair. Yea, right. This unit is designed to be never disassembled since everything snaps together and opening it up is a major puzzle.
This is only reader review which i found in the web. this may tell you what is the error is all about..
Nov 10, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Error code 5700.. already checked for jams, none, unpluging won't do it... none of the buttons respond... what else ??
Error 5700 is ASF sensor error.Check first the sheet feeder.If not have a jams the problem is in purge station.You can't fix it by yourself and your printer need repair.
Nov 04, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Cannon pixma ip 4600 error code 5700 - paper jam
The error code 5700 is the sensor error.Replace the sheet
feed unit and then adjust the timing of the paper feed gears.
Sep 02, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
5700 in mp520
Canon is fairly standard with their error codes no matter the model. Error Code 5700 basically means the paper sensor is not working properly. If this is the case then you will need to buy another printer. Most repair shops will charge more to fix the old one then you would spend on a new one. Sorry for the bad news. Although, I would strongly suggest you contact Canon Tech Support to validate this information. You can reach them at the number below between 8AM and 12 Midnight EST. Good Luck!
Canon Tech Support: 800-828-4040
Jun 08, 2009 | Canon MP520 All-In-One InkJet Photo...
Sharp FO5700
I have never seen this error code on a sharp FO 5700 are you sure that is the right model # or error code. I even did a search in the FO5700 service manual(no luck). I believe I have seen this code before on a sharp copier.
Sep 05, 2008 | Sharp FO 5700 Plain Paper Laser Fax
ERROR CODE ON KENWOOD DVD PLAYER
According to manual:
http://inform3.kenwoodusa.com/manuals/DV5700.pdf
see page 73, end of 1st column to second column, 2nd papgraph.
Jan 27, 2008 | Kenwood DV-5700 Multi-disc DVD Player
Canon PIXMA MP520 InkJet Printer Logo
221 people viewed this question
old marine
old marine
