Question about Dometic RM2193 Compact Refrigerator With Ice Box
HOW CAN I MAKE 12 VOLT RUN OFF OF ELECTRIC AT THE CAMP SITE, MY CAMPER HAS A SWITCH FOR PRO AND 12 VOLT BUT NOT ELECTRIC, SHOULD IT KEEP COOLING WHEN ITS PLUGED INTO SITE ELEC?
  • Dometic Master
  • 5,568 Answers
If this box is part of an RV, the factory has probably also provided a transformer and rectifier to supply ~12 VDC when connected to standard AC mains. Switching it to the twelve volt setting should be all you need to do. If it isn't cooling, check your breaker box to see if it has tripped the breaker circuit it is on. If you find no tripped breakers, it is possible that the rectifier has failed or possibly the lousy wiring one finds mostly in RVs.
If there is outside access to the area of the fridge, open it and check for a good-sized transformer in that general area. If you can locate it, you should be able to make some measurements with a cheap digital multimeter to locate the problem.
Posted on Aug 01, 2010
Plugged camper into 120 volt everything works electrically except ceiling lights dont work
* Check 12 volt DC system (may be camper battery or car battery, though most only use the camper battery.)
* Camper may be using 12 volt DC lights so it can be turned on while your on the road or not hooked up to an 120 VAC or 240 VAC outlet.
* If you are using 120 VAC lights then check the neutral line (note; HIGH voltage here. Get help from an electrician or at least the RV park handyman.) The problem may be at the outlet (the RV site's problem) or more likely in your plug or cable (the big cord) as it does get abused, run over, kinked, etc. Need to have it checked by an electrician.
* Check the light bulbs; is it seated properly? Replace if burnt out. Have electrician test if there is power at the socket.
* Final; Be safe and have a qualified electrician service your camper.
Aloha, ukeboy57
May 11, 2018 | Electrical Supplies
Question: I have a trailer camper it has a Dometic Rm 2652 Ameri. refrig.
If I remember right on those, the system works off 12 volt--120 volt-- or propane (LP gas). have you tried one of the other power source to run it off of?? If you get the same type cooling results the problem is probably a small leak in the freon system. Those use special internal gas. When I worked for GE the only way to fix them was to replace the complete cooling system which came pre-charged with the special internal gas. Quite expensive after the warranty. Now if you switch power source and one of the other sources make it work the problem will be with the type power you were using when it failed to cool properly. Many people that had system problems with those camper type refrigerators removed them and installed a small regular dorm style refrigerator that could only be run off a 120 volt power system. You would need a 12 volt to 120 converter to run it while on the road if thats what you want to do.
May 01, 2015 | Dometic Refrigerators
Electric heater problems.
Plug in a ceramic 120 volt or oil type space heater to keep trailer warm. Most travel trailers are propane only, they do not have electric heat strips. I would bet that is why it only blows cold air.
Jan 28, 2014 | Open Range 2011 Mesa Ridge MR243F
Our Dometic refridgerator in our 1992 camper
I would start there before replacing any parts. The circuit boards require 12volts to operate the refrigerator. If you have a good 12 volts and the LP tanks are full and the flame lights but the unit does not cool then you probably have a bad cooling unit. But start with the obvious issues first.
Sep 03, 2013 | Dometic RM2620 Refrigerator
What's a camp cupboard?
Camp cupboard will allow you to keep items safe and well organized, what should make the searching process very short. Camp cupboards are advised to be used only for trip with a car or a RV.
Sep 04, 2012 | Bass Pro Shops Camping, Backpacking &...
Looking for manual or information my 1988 TravelAire Camper van. It is on a Ford e-250 chassis. Need to know how the 120 Volt system works; i.e. does it operate all lights (including 12 volt); does it...
Typically, the 110 Volt will go into a power center which should include a small amp battery recharger. Your 12 volt lights should run off a 'house' battery which should be isolated from the truck battery, yet, the truck alternator should charge the "house" battery on the road. The device that allows this is called a Isolator. You may find a manual switch instead. You definitely don't want the house and truck battery to both run yourf coach with no recharge capability. Some systems have a 'emergency start" switch which allows you to use the house battery to start the engine. All 12 volt house stuff should run off the house battery and the battery should be recharged by the truck or the small battery charger. Do you have an evap frig? Runs on propane or electricity? It needs 12 volts whether it is running on gas or 110 Volts. The 12 volts runs the control panel and the heat to make it work is supplied by the gas or by a electric calrod if 110 is available.
I am pretty familiar with these electrical systems ... I seriously doubt you will find any information on your 20+ year old motor home. Typically, the printed specs and equipment and the data is obsolete before the ink is dry because the manufacturers use what is available as they build. If you have additional questions simply click on the "add comment" or the "reply" link and I will take a look-see.
I hope this answers your current question. Thanks for your interest in FixYa.com
Sep 07, 2011 | Ford E-250 Cars & Trucks
Can i run a camper off a power inverter
A 12 volt camper can be run off an inverter if the inverter has the capacity. The camper must be 12 volt right, just bulbs and such?
Jun 18, 2010 | Eliminator MotoMaster Mobile Power...
How can i get electricity inside my slide in truck camper
carry an extra altenator just in case for your truck
Mar 12, 2010 | 2003 Chevrolet Silverado 2500HD
My tent is unsafe, I have no idea how to make completely safe. I like to go camping in the northern woods, bears like to sniff and bump my tent.
Are you keeping food inside the tent?
Bears usually will not come near humans unless there is food smell coming from within the tent.
I also camp in the north woods and generally its the coyotes that are daring enough to come into a campsite. Also they use coon dogs for hunting bear which falls in public camp season and they roam about to track bear. My personnal best defense is to keep my chainsaw just inside the door as being a camp host I find myself being alone in site untill my guests arrive. The chain saw noise is a good defense to scare off anything because its very loud .And yes Ive actually had to run it one night in Particular when my site was surrounded by a pack of coyotes and they were right outside. KEEP ALL FOOD AWAY FROM TENT AT ALL TIMES. Raccoons also are very daring and will come on site even when your there if they smell food and are smart enough to open water jugs with their paws the trick to keep them out of your food is to put the coolers under the bench part of the picnic tables so the lids cant be opened.Im a very ex. camper and can give tips all day long
Nov 05, 2009 | Wenzel 18'x10' Sycamore 3 Room Tent
Dometic RM2193 Compact Refrigerator With Ice Box Logo
134 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
