Question about Nikon Coolpix 5000 Digital Camera
Camera fell to the ground and now the lens wont retract. Screen says Lens error
  • 3,083 Answers
Can be damage to lens assembly gears and bad news, but maybe not. There's an excellent blog about this problem of things you can try. Some of them don't apply to your problem, but are good to know. Here's the site:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Aside from getting lucky, it will have to be disassembled to be fixed. It's quite a process, but can be done with patience and a good process or memory. If you have a shop repair it, get an estimate first. Some are more reasonable than others, and chances are this repair will run a bit.
Good luck, and join the millions of others who have had this happen, due to the construction and demand of zoom lenses.
Posted on Aug 01, 2010
It fell on ground lens wont fully retract grating sound
the sound ,becsz of damage of the parts of the lens mechanism,such as gears,guides and guide-pins,so get it serviced,replacing the damaged parts.
Mar 07, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
Lens Error!
In My case, the lens was coming out part way a start up and pulling back in without camera coming on. Some times the screen would stay a dark blue and could not be shut off. Ensure batteries are new or remove and replace existing. Lens will come out part way and retract when the battery door is opoened and closed. Press "on" button and as the lens comes out touch and hold the lens, with a finger placing pressure on the side of the lens. The lens will stay out. With camera upside down blow into the sliding mechanisms of the lens. Grip the furthest most extened lens with two fingers and pull the lens all the way out with steading pressure. The pressure should be equivalent to lifting one to two pounds of bread with two fingers. Perform this with the camera upside down so that any dirt particles can fall out. A slight rocking (side to side motion) of the lens may help. Once fully extended, open and close the battery door. The lens should retract. Turn on the camera. A couple of ideas relatd to this problem 1) If the concentric circles of the lens are not even, this could indicate a large grain of sand. After lens is extended or partialy extended push the lens on the side where the largest gap is while the camera is upside down. This may provide a larger gap for the grain to fall out. 2) Dirty camera case. I turned my camera case upside down over a piece of white paper and was amazed at the particles of sand that fell out. I turned the case inside out and completely brushed and vacuumed the case.
Jul 13, 2009 | Nikon COOLPIX P60 Digital Camera
Camera lens wont open or close after being dropped. it won't turn on and take pictures
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Jul 06, 2009 | Kodak EASYSHARE M1063 Digital Camera
Camera felled to floor lens tries but cannot retract camera turns on and off fine, error message "lens error, restart camera" it appears that until lens can function properly and error message is resolved...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jun 29, 2009 | Canon PowerShot A630 Digital Camera
Lens will not retract. orange and green lights come on, but preview screen remains dark and lens will not retract when I trun it off.
May 02, 2009 | Cameras
Fawabi
0013 indicates that your camera has a hardware (related to Lens) defect.When dirt gets into the lens mechanism the lens wont retract properly.. You wont believe what i have suggested for a similar problem and it worked! Its a similar lens stuck error..
http://www.fixya.com/support/t240817-camera_error_e45
Mar 21, 2008 | Nikon Coolpix 3200 Digital Camera
System error
hi the problem that causing this is: there is some pressure to the lens did it fell? probebly there is a fault in the lens sorry cant help good luck
Mar 20, 2006 | Panasonic Lumix DMC-LC43 Digital Camera
Nikon Coolpix 5000 Digital Camera Logo
85 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
