Question about Hotpoint Dryers
Dryer model number DLB2450BEL, My timer quit timing, but the dryer is still usable. Timer is NLA, is there a later timer that will work?
    President:
  • 3,773 Answers
Try Marcone.com if they don't have it then it is unavailable
Please rate me if this was helpful
Thanks
Imufo2
imufo2@sbcglobal.net
Posted on Aug 01, 2010
Testimonial: "Thanks for the quick reply. Unfortunately Marcone doesn't have it, nor does anyone else. Will have to just wait and see how long my wife will tolerate"
I have a maytag dryer mdg 6460aww. timer is not working I I exchanged-timer. , temp switch, cycling th'st, high limit th.st My question is why does not operate on a timer
It's none of the above. The part your dryer requires is the dryness control board part #33002905. Unfortunately they are NLA. If you are really good, you can study the wiring diagram, unplug the board from the system and send power directly to the timer from the motor to run the timer when the unit is running. This will only work properly for the timed dry selection as the dryness sensing is eliminated.
Beats replacing the dryer and the part MAY be remanufactured by Whirlpool. So it might be available in the near future.
May 01, 2014 | Maytag Atlantis MDG8400AW Gas Dryer
Need to replace my dryer timer M460-G
The problem is that the new M460-G timer does not have the same terminal letters as the old one (because there seem to be a variety of sub-models under the M460-G name providing varying options such as an "air dry" function). However, I've at least been able to provide the basic timed heat function using a different M460-G on my old Frigidaire Crown Gas Dryer M/N FDGB23RGS2 . To do this, figure out the terminal functions by rotating the M460-G switch and measure with ohm meter and also inspect wiring diagram (mine was at appliance pros dot com).
On Frigidaire Crown FBGB23RGS2 Gas Dryer:
The original M460-G is wired:
Terminal / Function / Color
A / Gas / Org
B / Line voltage / Red
C / Motor / Wh
Timer wired between TM and C
AD / Auto Dry / Pink
TD / Start Switch and Motor / Tan
On other M460-G Gas Dryer timer (from mystery Dryer), I wired it to into my Crown dryer as follows:
Terminal / Function / Crown Dryer Wire color
BU / Line Voltage / Red
BK / Motor / Wh
R / Gas / Org
V / ? / No Connection
Timer wired between TM and BK
WB / switched on while Motor & Gas / Tan
OR / ? / Pink (figured it was safe)6b1460b2-ed5e-4c5d-b06b-c654e59e7487.jpg
Nov 19, 2013 | Whirlpool Dryers
Dryer dries but the timer is not working on either the timing cycle or moisture cycle, what should I check?
nothing to check your timer is just bad,to look for a timer on line the model number is inside the dryer door and the part number is on the timer
May 02, 2010 | Kenmore 700 6972 Dryer
I have a Whirlpool Estate dryer Model TGDS840PQ0. During auto sense, the timer will not move. But during a "time dry" session, the timer seemse to work just fine. Any ideas?
in auto the timer will not move if there is no heat,when the heat stops the timer moves,heat comes on timer doesn't move,when it's on auto make sure power is going down to the heating system,next time send model number and if it's gas or electric,good luck
Jan 27, 2010 | Kenmore 63942 Dryer
Kenmore Electric Dryer Model 110.6972110 timer motor NG
hi,
maybe call a generic appiance store other than sears, try maytag store. the knob pulls staight off and the timer nut is below. then take off the back cover off the control panel, sometimes those screws are on the front corners, sometimes hidden. take a picture of the timer wiring and tape and label all the wires before you remove it. unplug it first!!
jm
Nov 29, 2009 | Kenmore 62602 Electric Dryer
When u turn on my gas whirlpool dryer it runs as normal. when u check on it a little later (on automatic dry) the timer has not moved, and the dryer has quit producing heat
Hi, the timer control the heating commands and, if its not moving(rotating), this will confirm timer failuer. replace it asap.
Jun 18, 2009 | Dryers
Timer Continues to run when dryer is shut off
the timer keeps on going even if you open the door this is normal
Feb 18, 2009 | Dryers
Dryers Logo
65 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
