I have a fan piece left over from reassembly. the fan is mounted on a bent 90 degree piece of metal that is perforated and probably goes on the chassis somewhere. I am stumped. Here is the piece
  • 3 Answers
HI Joe, The piece you are referring to slides into the top of the chassis. if you are sitting in back of the television and the chassis is removed, the piece with the fan slides in from the top. The perforated piece slides in between the left support bracket and signal board. The fan will cover the top of the signal board, DM module and Fmt board. Once it is in place you will then plug in the usb and firewire cable at the top of the chassis. The connector for that fan is connected to the wire harness that is coming from the chassis near the dvi connection. Does this help?
Posted on Aug 11, 2010
Taillights won't go off when car not running. 1987
Probably not your tail lights but your brake lights. What commonly happens is that the switch either goes bad and sticks closed or it gets knocked out of position.
The switch should be mounted under the dash up around the steering column where it can contact the brake pedal arm. When not applying the brakes the switch has a piston-like piece that rides against the steel arm going up from the brake pedal. In this depressed position the brake lights are off. When you press the brake pedal the piston extends and the brake lights come on.
The switch is typically about 2-3" long and 1-1/2" height and width with one or two wires attached to it. It will be attached to normally an unpainted metal plate bent at 90 degrees and mounted where the switch will be directly in front (towards the firewall) of the brake pedal arm. If its been knocked out of position you'll need to get it remounted and positioned where the piston is depressed with the brake pedal in its normal position and the piston comes free of the brake arm when the pedal is depressed. It's a two person job. Ti check to see if the switch works just press the plunger in and the lights should go off. If not replace the switch.
Good Luck!
Sep 01, 2014 | 1987 Nissan Maxima
Tip
I would hear it when going over speed-bumps or hitting potholes, anything that...
I would hear it when going over speed-bumps or hitting potholes, anything that made the bed move towards or away from the frame. I figured a leaf spring had lost its insulator and was squeaking, no big deal. Just use some J.B Weld and a plastic disk to break the metal-to-metal contact. I would eventually have to buy a kit that would do the job better, but a plastic disk would work for a few days - - until I got paid, anyway.
I took a knee by the passenger side rear wheel and was looking at the leaf springs. All insulators were in place. Drivers side looked the same. Then it hit me. Glaringly obvious. Shock was approximately fifteen degrees off-axis. Half the mount was still on the bed, half was attached to the shock that was rubbing in an odd place. The squeak was coming from a busted shock mount, rusted through.
I bought a 4.5" Black and Decker grinder/sander and set about to get the remaining shock housing off of the truck. Had to grind out three bolts and punch them out of the frame. Then I used the grinder to cut up several pieces of a twin-sized bed frame. Any good, thick metal will work. There was not much left to the original shock mount after I had sanded away the rust. I also used the grinder to get rid of any thin, flexible, sub-par metal remaining on the mount.
I bent pieces of metal and welded them to the small portion of mount that had not rusted away. Like I said, I was using twin-size bed frame angle-iron. Tough stuff. If it were not for the bench-mounted vise,it would not have been possible to get much done. Looking at the mount from the passenger side as a template was the easiest way to see how best to restore the drivers side.
The twin-sized bedframe was very difficult to bend, what we did was grind the corner off, so there were two individual flat pieces. We left these individual strips very long in length, often three or four foot long. Insert a small amount of it into the vice and pull down on the rest of it like a handle. This proved to be the quickest and easiest way to put the right bend to the metal. Of course we perfected the bends with a small ball-peen hammer and larger three pound mallet.
It took us most of the first day to get every thing ready. Removing the shock, grinding bolt heads off, punching the bolts from frame, sanding/grinding mount down to good metal, determining which filler metal would be best/quickest/easiest. The next day was spent welding.
We used a cheap 75amp arc welder with a 6018 rod and things went very smoothly. It was the perfect setup for such thick, heavy metal. Piece by piece went on with small tack welds, to hold the pieces in place, and the mount went together perfectly. Since then I have hauled an 860 pound Plymouth neon in the bed as well as various other trips to the scrapyard. I have deliberately hit speed-bumps much harder than I should have-- trying to break the mount-- to no avail. It is rock-steady and will probably outlast the rest of the vehicle.
Total project cost: $35 grinder (which I needed anyway), $10 sanding pads/wire brush, and a small tube of welding rods for about $20( and I still have about half). All - in - all, a good decision to re-fabricate instead of buying another mount. Now I have additional tools and supplies for future projects.
on Jun 02, 2010 | Motorcycles
Kenmore quick touck microwave, door latch hard to open & shut
If your want to start the easy path, get a Q-tip and some light weight grease and lightly grease the door-switch levers inside the door latch holes and see if that solves your problem. If not, then you will have to remove the cover, and likely you will find the door switch assembly and it's metal mounting support are bent on something of an angle - the switch assembly should be at 90 degrees to the front of the microwave oven so that he door latch fingers can slip in and activate the control switches easily all at the same time - straighten the switch frame which may require you to remove the switch bank temporarily. The little bit of grease still doesn't hurt to do it.
Reassemble.
May 11, 2014 | Microwave Ovens
How do I replace the oil pump on my 2004 aveo 1.6
first drain oil from pan to prevent making mess ion floor.
Then remove all oil pan screws and pry pan off making sure it does not get bent.
If bent lightly tap with hammer on flat surface like workbench.
Some models are designed so that getting at all the screws is impossible. In that case you might have to remove engine mounts at the engine block and lift with a floor jack.
safest jack is a transmission jack.
the engine should be tied off with some heavy wire to prevent falling on you with a 4x4 or wood fence post.
Remove the metal baffle, should be only one screw.
Baffle is metal rectangular piece and in the middle.
The oil pump uses 2 screws and might have to tap lightly with hammer to remove.
Clean out the oil passage where the pump came off with a rag and thin screwdriver.
Clean baffle with some solvent and make sure it reseals properly when reassembling.
Remember to clean all parts to prevent leakage when reassembling.
Feb 07, 2013 | 2005 Chevrolet Aveo
Rearview mirror repair-The mirror just came off in my hand yesterday, leaving a circle of black film attached to the glass. In the past, I've repaired one with a small metal piece that hold the entire...
The small metal piece is just glued to the glass , and is probably still in the mirror assembly. You can buy the "special " glue at any auto parts store.
Glue the metal piece on , then after it has fully dried you can slide the mirror back on.
Nov 08, 2009 | 2002 Audi A4
Non-Stop Noise from Inner Ceiling of the Microwaveoven
It sounds like the 'stirrer' which is a metal fan-like device with a plastic bearing that is mounted in the wave guide above the cavity. Pull the plug, then the case. Remove the waveguide above the cavity which should expose the stirrer. Spin it and check for any up and down motion--straighten the axle part so that it turns true. The blower system turns the stirrer--no extra motor. If this part was bent, someone may have handled it roughly. Reassemble the waveguide and test without the case on, but a cup of water in the cavity.
Aug 24, 2009 | GE Advantium SCA1000H Convection /...
How do i perfor a system reset on a toshiba
hi, try this....
the back part of your laptop where your memory card goes to and then remove the memory card look for the word jopen1. you will see a metal letter U and letter T. Use a metal paper clip on the metal letter U and then put the other end of metal paper clip on any metal part of the main board for a few seconds. And then after that put everything back together and see if it works. From there you will be asked for a new password (any password that you would like to use), save and then restart.
note: there's a plastic piece on the metal letters U and T. don't pull it all the way off from it. Hope this will help.
Jun 27, 2009 | Toshiba Satellite A135-S2326 Notebook
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
