Question about Car Audio & Video
My 1994 e150 sound system sounds puny compared to what I believe stock should be. All the speaker work there just isnt much volume, bass, or treble. Is there an amp that boost the sound? where is it?
  • 70 Answers
Well first i would change all the mid speakers out to kenwood speakers and not the cheap ones cause the cheap ones are like stock speakers the more higher priced ones like the 80 dollar ones are equal to 300 dollar speakers then you should get a 2 channel or 4 channel MTX amp each speaker can take 150watts. your system would be alot better than stock. if anything look on crutchfield.com that would be the best place if you dont want to go to a car stereo shop in your area. if you plan to keep the deck stock then you need a hi-lo adapter which will hook up to the right or left rear speaker and the remote wire needs to go to the ignition wire behind the deck
Posted on Aug 03, 2010
I have a samsung LHB655NW surround sound system. The four corner speakers are double units with one above the other.the top ones work but no sound comes out of the lower ones.
If you are talking about the driver cones in each of the units, then it's odd that they should have gone, unless they have driven too hard or damaged (say by a child poking them). Double unit speakers have a crossover built into that separates the sound into treble and midrange or bass.
If the sound coming out is "treble" the high frequency that shows the bass units are not working.
Make certain all the wiring is good to the speakers and if you can see the bass speaker check it is not damaged.
If you need to, go inside the units and connect a 1.5 battery across each speaker terminal for a second. If it "pops" then it's working.
May 07, 2018 | Samsung Audio Players & Recorders
How do i find out what sound card my p.c is using? i'm on windows vista, and need to change the bass and treble level ?
Most laptop sound card do not have a setting for bass and treble.
You can use external powered speakers that have bass and treble settings and connect these speakers to the headphone socket on your laptop.
Jun 26, 2012 | Computers & Internet
Sub woofer far too basey relative to treble- appears to have no means of adjustment
You can adjust the bass (and treble) of all sounds coming from the program you are using. For example: WinAmp; Click View -> Equalizer and adjustments can be made from there. I believe the lower frequencies (your bass) starts on the left and continues to get more treble and less bass the higher the frequency gets (farther to the right).
But most programs should have some form of an equalizer. Which can be accessed slightly differently in all of them.
Without more specific knowledge on this one it is hard to give more detailed instructions on this. If need please let me know and I will follow up with a how-to for your operating system and/or specific program you are using.
Jun 08, 2011 | Altec Lansing 221 Computer Speakers
What are good settings to have to make the music sound clear for a jvc KD-R310 deck?
you will need to access the bass and treble setting on the unit.
If you have stnadard speaker then dont put the bass to high as you can not turn the volume up high.
The same for the treble.
Set them at about the same and turn the volume up until it sounds good.
If it is to quiet then turn the treble and bass down and then the volume up more
Mar 02, 2011 | JVC AM FM CD DET FACE CAR STEREO
I have set up a BOSE Accustimass System with my STR de485 receiver. How do I adjust the treble/bass?
hi,
if u are using bose speaker system then remember one thing. go to speaker setup and select all the speakers as large not small. then only u will get a good tone. bose speakers will handle the output power of ur amplifier.
u can only adjust the bass and treble of ur frond Channel speakers. for that
select multi channel surround sound and the increase and decrease the bass and treble
ok
Dec 31, 2010 | Sony STR-DE485 Receiver
I have a 2005 scion tc, everything stock. My bass just stopped working, the treble still works but there is no bass. Does that mean i blew my speakers? They still sound fine. Is there anything I can do...
check your fuse box and find which fuses go to your radio/audio system it may have a built in subwoofer and amp in the vehicle -check those out and hopefully it will solve it.good luck.
Dec 10, 2010 | Car Audio & Video
No sound
If you know your speakers are working and there is nothing wrong with them go on your computer and go to sound settings in control panel and adjust treble bass and volume.
May 30, 2010 | Insignia 2.0 Speaker System (2-Piece)
NAD C370 Right channel distortion
Sounds like you have lost the power amp transistor(s) or IC for this channel.
Aug 29, 2008 | NAD C370 2-Channel Amplifier
My speakers sound flat with no highs at all
I am trying to work out if you have damaged the speakers and amp too.
Have you tried a pair of headphones on the amp? If they sound ok then your amp is fine.
Assuming it is, then speakers have what's called crossover units in side each of them. This splits the sound into three parts. Bass, midrange, treble. The bass is handled by the woofer's, the midrange by a middle sized speaker or or it's combined with a tweeter, which of course handles the treble.
Connecting a 1.5 volt battery across any of the individual speakers will cause it to pop if working. If the speaker then is not getting sound then the crossover unit is to blame.
When you look at the crossover unit, it will have coils and capacitors (non polarised) on it. The bigger ones deal with the bass and the smaller ones treble. If you find a fault say on the crossover of the speaker, for example no treble comes out of it. Then start by replacing the capacitors. Use the same value as on the capacitor and remember they fit any way round.
Apr 14, 2017 | Paradigm Audio Players & Recorders
Car Audio & Video Logo
82 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
