Question about Dell A940 All-In-One InkJet Printer
Dell printer is saying error 0502 - Dell A940 All-In-One InkJet Printer
  • 6,826 Answers
SOURCE: Error 0502
The printer head carrier had a sticking problem at the rest position.the steel bar was not sticking in the process of printing it was on the initial "take off" as indicated when the printer carrier first takes off to commence a print job. To test if this is your 0502 error report problem check that the printer carrier will slide along from rest position with no resistance if it does attempt clean of steel bar and lube with light mineral oil
Posted on Jan 26, 2007
SOURCE: Error 0502
Your solution to error 0502 was 100% correct. It fix the problem
Thanks, John
Posted on Dec 05, 2007
damanpreet_c
  • 69 Answers
SOURCE: hardware error:0502
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Posted on Nov 07, 2008
  • 547 Answers
SOURCE: how do i fix hardware error 0502 on my dell
There is a shiny steel bar inside the printer, and the ink cartridges move up and down this bar to print on the page. If this bar gets gunked up from stray ink or paper dust, then the motor strains to move the print heads back and forth, and you get this error.
Fixing it is simple. Take some kleenex, and with power unplugged, clean the bar very well. Then Spray some WD-40 on a Kleenex, and lubricate the bar by wiping the WD-40 kleenex on the bar.
If this helps, be sure to hit the "thumbs-up" for me!
Posted on Dec 27, 2009
pineworks
  • 4041 Answers
SOURCE: My dell A960 printer has hardware error 0502.How
Dell A960 All-In-One InkJet Printer
Error 0502 and 0504
Hi there
On the multi function machine seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a Kleenex and the problem seems to go away.
Somehow it presents a drag on the cartridges and causes an error.
Myself I would put a little bit of oil after on a cloth and wipe along the bar.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
Dell AIO A940 is giving me an error code 0502 and won't print. Says it is busy?
Check this out for the error. The trick here is to make sure the bar is cleaned and lubricated with furniture polish or cooking oil.
http://blog.forret.com/2006/02/lexmark-printers-with-hardware-error-0502/
May 24, 2010 | Dell A940 All-In-One InkJet Printer
My dell a940 printer has a 0502 error how do i fix it
Hi Remcountrybo,
You can fix this by following the instructions given in the following link.
Fix Error 0502 in A940 All In One InkJet.
-Rate if it helped you.
Apr 10, 2010 | Dell A940 All-In-One InkJet Printer
Error code 0502 hardware error on dell printer
i once fixed the hardware message by putting the tape back on the back of the cartridge...then fixed the perpetual paper jam message...
Feb 19, 2010 | Dell 922 All-In-One InkJet Printer
Error 0502 and 0504
Hi there
Feb 18, 2010 | Dell A960 All-In-One InkJet Printer
Wont finish print job hardware error 0502????
I found this:
Hope it helps!
Mar 28, 2009 | Dell A940 All-In-One InkJet Printer
Error 0502
hi!!!
try to remove the cartridge of your printer
and put back on!! properly!!
may be your printer cartridge
not in ilignement!!!
Sep 21, 2008 | Dell A940 All-In-One InkJet Printer
Lexmark error message hardware error 0502
Clean the rollers that the cartridges run on with a non-lint wipe (i use non scented baby wipes for all my printer work. The printer should now run fine. cheers lilacgerry xxx
Jan 21, 2008 | Lexmark X6170 All-In-One InkJet Printer
Error 0502
I did as suggested by another poster, clean the area of travel(ribbon,travel bar, etc) with a clean damp cloth and now it seems the problem has corrected it self
so far anyways ........
Dec 10, 2007 | Dell A940 All-In-One InkJet Printer
Dell A940 All-In-One InkJet Printer Logo
76 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
