Question about Biostar P4M800-M7A Motherboard
Motherboard Won't Take 2 Sticks of RAM
I bought a second stick of RAM but the motherboard only computes one stick at a time. I have tested both sticks individually and it works with both, it just won't take the full 2GB of ram.
  • Fapiko Apr 29, 2008
    Already done all of that.
  • Anonymous May 30, 2008
    I have same problem, I try to install another RAM, it does not support that.
I go to the website and download the bios upgrade. But when I start the program in my WIN XP PRO system, it does not response. Also, it seems that if I plug only one ram in second slot, it does does notwork as well. what could be the reason? Thanks for your help.
Posted on May 31, 2008
    President:
  • 2,351 Answers
Test both slots with 1 GB of memory, than switch to second bank of memory & test in both slots again.
You may need a bios upgrade. Click on this link.
http://www.biostar.com.tw/app/en-us/mb/bios.php?S_ID=93
If I can be of more service, just post & let me know how thing go.
Mike
Posted on Apr 29, 2008
I have a motherboard called d102ggc2 with max 2 GB capacity. I recently tried upgrading from 1 GB ram to 2 GB ram by adding another 1 GB stick. The problem is that both the sticks are not working together...
Sounds like the second RAM stick was placed in the wrong slot. I would suggest checking your motherboard manual to determine this. Some motherboard designs have unusual slot arrangements.
Dec 17, 2010 | Intel D102GGC2 Motherboard
Conflicts of RAM and motherboard
well unfortunetly it seems as though your RAM may be bad or not compatible. My suggestion is to go to crucial.com and use their easy memory finder to see what is best for your system. Then look for it else where like newegg.com or tiger direct, etc. There isn't a whole lot that you can do to fix RAM like that to make it work with a system predefined by the maker.
May 06, 2010 | ASUS P5V800-MX Motherboard
Problems with memory sticks and motherboard
see my website theit is solution www.techyardsolution.com
Apr 13, 2010 | ASUS P5V800-MX Motherboard
A7s333 motherboard with 3 dimm ram slots 2 x 1GB pc2700
That board type does not show on the ASUS web site. I think that your problem may be incompatibility of the RAM with the board specs. Placing faster RAM on the board will not make it go faster.
Oct 24, 2009 | ASUS A7S333 Motherboard
Total amount of RAM not recognized by computer
are the modules the same specs? you may have some incompatibality between them. the board may be reading the ram right it may be you have four 256 sticks instead of 2 of each. read the motherboard manual it might shed some light here.
Jul 13, 2009 | Computers & Internet
My computer keeps booting every 2 seconds and I just can see motherboards first screen during 1 second then cant see anything else
I am almost positive it is the ram, because it gets to windows but crashes after loading windows partially. I once had a similar problem. Just make sure all the Power Supply connectors are properly connected.
Try these steps too:
1. Full power down. Unplug the power cord from the Power supply. Then hold down the pc power button (this discharges any residual power in the capacitors).
2. Open the case and reseat the graphics card, hard drive, and RAM.
3. Take out one of the RAM sticks if there is 2 or more. Swap the RAM sticks in different RAM slots. Try one stick at a time to see if you can get the PC to boot. If this works, then the remaining ram sticks are damaged.
4. Set the Cmos jumper to clear. Power up the pc. Power down the PC. Set the Cmos jumper back to normal position, power up the PC.
5. Unplug and replug all the power supply cables.
6. Check the powersupply function. Either by a powersupply voltage checker (20-25 dollars at local PC shop), get the supply tested at a PC shop (usually a free service), put the powersupply in a different pc, or try a different powersupply in the problem computer.
If the Powersupply checks out ok, then you will have to do a process of elimination to find out what part or parts are the culprit of the No-Boot.
Start by pulling all the ram sticks if you have not already. This is the easiest components to check and usually a culprit.
Jul 07, 2009 | Intel D865GBF Motherboard
Two rams stopped working in intel d101ggc from today
You've got either mismatched RAM memory or 1 of your sticks are bad. You can isolate this by booting 1 stick at a time. If the machine boots fine with both sticks (one at a time) then they are mismatched or your motherboard isn't configure to handle the 2 sticks together (not very likely but a possibility) Hope this clarifies your problem All the best!
Greg
May 12, 2009 | Intel D101GGC Motherboard
Two 1 gb ram sticks not working together!
may be frequency is different of RAM,just check it
Mar 05, 2008 | Intel D102GGC2 Motherboard
Motherboard not recognizing RAM
Is it exactly 3gig of ram?
You may have 4 sticks in but your onboard peripherals share the memory.
as such my 512mg stick is in but it shows me only 482mg.
Take into account your onboards.
Hope this Helps
Nov 27, 2007 | Mach Speed MS945G-GLV Motherboard
Unaible to upgrade RAM
It will only support up to 2GB Ram and the same memory specification
Nov 23, 2007 | ASUS M2N-MX Motherboard
Biostar P4M800-M7A Motherboard Logo
119 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
