Question about Compaq A1500 All-In-One InkJet Printer
Printer wont print anything
I just have got my power cord replaced and my computer. My computer has just been in repair. My printer was working eversince i got my computer back. Now my printer wont print or scan anything. I have tried setting it to online and unpausing it but that wasnt wrong. I need help!!
  • Anonymous Mar 31, 2014
    wont print from computer
    Sergeant:
  • 390 Answers
Did you mean just the cord was repaired or did you get a new pc??? Many times, once a computer is unhooked and transported to be repaired, sensitive settings and drivers can be upset by the move. Sounds bizarre but i know it happens because it even happens to me. The other thing is did anything get done to the internals of your pc, or the software changed. This is really important too. ie, did the repairer have to change any settings in the pc, in windows or any where. Please post exact changes if any. If no settings were touched and it was just the cord, i suggest completely uninstalling the printer from the pc. If you do not know how to do this, post back. Once all traces are removed, reinstall it. Make sure printer is completely uninstalled and new installation is smoothe and no hiccups. Now connect back up correctly and turn on. Your pc should recognise new hardware and configure it for you and away you go.
Posted on Apr 26, 2008
My printer is not printing
Without knowing any more, all I can do is take you through a tedious set of steps:
  1. Is it plugged in? Unplug the power cord at both ends, then plug it back in.
  2. Is it connected to your computer? Unplug the cord at both ends, then plug it back in.
  3. Is it turned on? Press the power button. Do any lights change (go on or off, change color, flash, etc.)?
  4. Send a print job to the printer. Does the printer show any signs of realizing it's been asked to print something (an indicator light or something moving inside)?
  5. Open the print queue. Delete all the jobs that are in there. Shut down the printer. Restart the computer. Turn the printer back on. Try printing.
  6. Are you getting error messages?
  7. What happened before it stopped working? Did you install new software? Move anything?
May 01, 2015 | HP DeskJet F380 All-In-One InkJet Printer
I changed the ink of my printer and now it wont print anything just keeps flashing a red light. Ive tried turning the computer on and off but nothing is fixing it. Please help
Please perform the steps below and check..
1. Make sure the product is on, and then disconnect the power cord from the product.
2. Disconnect the USB cable from the product, and then disconnect it from the computer.
3. Reconnect the USB cable to the computer, and then reconnect it securely to the product.
4. Disconnect the power cord from the wall outlet, and then reconnect it to the wall outlet.
5. Reconnect the power cord to the product.
6. Press the Power button to turn on the product.
If the issue still persists please get back to me with the Printer name and model number
May 18, 2010 | Office Equipment & Supplies
MY PRINTER WONT PRINT THE BLACK
If the black ink wont print, you will have to try cleaning the print head.
Press the "ink" button and select "cleaning".
You can do up to a maximum of 5 cleanings, anything more then that is a waste.
If that still doesn't work then the print head is not working properly.
You will need ot have the machine repaired or just replace it.
Given the price for repair Vs a new printer, it's better to just replace the printer.
Thanks,
Pat
Mar 31, 2010 | Brother MFC-3240C All-In-One InkJet...
My printer wont work. Its on and everything is plugged in correctly why wont it print it was just fine yesturday.
Turn the printer off. Disconnect the power-cord from the wall-outlet.
Turn the computer off.
Reconnect the power-cord & turn the printer on.
Turn your computer on, and try again.
Nov 30, 2009 | HP Photosmart C6180 All-In-One InkJet...
I had a paper jam this morning, cleared the paper jam, and now the printer will not power up. I tried to remove the usb cable, and the power cable, reboot the computer, and replug in the usb and power...
First, Make sure that the printer is properly plugged in to a working electrical outlet and that it is hooked up to the computer as indicated. There should be two separate cables running out of your Dell 924, a power cord and a USB cable that communicates with the computer. If both of these aren't plugged in, then the machine will not function properly.
If the lights on your printer aren't working then it means one of two different things:
  • Printer has an internal electrical problem and needs repair or
  • Printer isn't receiving power from the outlet or power cord
Check whether, are you getting power from the socket by connecting some other component..If it works check whether the Power cord is propwerly connected, try pressing the power cord once..
If not the circuit may be damaged, Which cant be repaired inhome, you have to return to DELL service center and make it repaired
Please leave me comment, if you need further assistance
RNJ VINODKUMAR
Oct 09, 2009 | Dell Photo 964 All-In-One InkJet Printer
HP deskjet F380 - 'status: paper jam'. There is no paper jam!
Unplug the power cord and while doing that make sure printer is powered on i mean do not turn off the printer using the power button. When you unplug the power cord than press and hold the power button for 30 seconds. Than release the power button and connect the power cord and then try to print.
Jul 21, 2009 | HP DeskJet F380 All-In-One Printer
Printer stopped printing durring project "Assert Error b52b00b4"
From the HP website:
ISSUE: The printer displays an assert error code. Assert error codes indicate that the printer has an internal condition that may respond to a hard reset of the printer. Beyond that, service may be required. This document applies to the following products:
  • HP Photosmart p1000/1000, p1000xi printers
  • HP Photosmart p1100, p1100xi printers
  • HP Photosmart 1115 Printer
  • HP Photosmart 1215, 1215vm, 1218, and 1218xi printers
  • HP Photosmart 1315 Printer
SOLUTION: Hard reset of the printer A hard reset of the printer may clear the error. Here is how to perform the hard reset:
  1. Shut down the computer.
  2. Open the top cover of the printer and remove the print cartridges.
  3. Close the top cover of the printer.
  4. Press the power button on the printer to turn the printer off.
  5. Disconnect the communications, (USB or Parallel), cable from the back of the printer.
  6. Disconnect the power cord from the back of the printer for one minute.
  7. Reconnect the communications cable to the printer.
  8. Reconnect the power cable to the printer.
  9. Press the printer power button to turn the printer on.
  10. Open the top cover and reinsert the print cartridges.
  11. Close the top cover and print the calibration page.
  12. Restart the computer.
Mar 18, 2009 | HP PhotoSmart 1115 InkJet Printer
TONER WAS LOW STARTED PRINTING ENDLESS PAGES OF STRANGE CHARACTER
hi!!!
ok try to re-installed the printer driver
or replaced the usb cord
Nov 10, 2008 | HP LaserJet 1320 Printer
Recognizes printer, won't print
What i'm getting at is if the printer was not used for a long time the cartridges may have dried out.
Robert
Aug 30, 2008 | HP Photosmart 8250 InkJet Printer
Printer won't print
paper start to feed but after some time not working
Nov 15, 2007 | HP LaserJet 1100 Printer
Compaq A1500 All-In-One InkJet Printer Logo
41 people viewed this question
Top Compaq Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Tony
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
