2001 Jeep Grand Cherokee Logo
Posted on Aug 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We are trying to clear a clog a/c in a 1995 jeep grand cherokee
Duane Wong
Level 3:
  • Jeep Master 6,826 Answers
  • Posted on Aug 01, 2010
Duane Wong
Jeep Master
Level 3:
Answers
6826
Questions
6
Helped
2861768
Points
20234
Do you mean a clogged orifice tube in the a/c system?
How do i change an ignition switch for my 95 jeep grand cherokee
Try here
https://www.2carpros.com/questions/1995-jeep-cherokee-1995-jeep-cherokee-ignition-switch-replacement
2helpful
Is a 1995 jeep grand cherokee limited v8 vs. inline 6 transmission interchangeable?
No sir they will not interchange. i worked at a transmission shop for 7 years. the inline 6 has a 500 trans in it and the v8 has a 518 trans in it. the bellhousings are different.
95 jeep grand V8 overheats cold upper radiator hose and cold heater
clogged radiator or bad water pump or both
google grand cherokee forums and join one or more and post this and future ques there
1995 Jeep Grand Cherokee has a leaking sun roof. How do i repair this?
recommend cking the drain holes,should be 4 drains in the corners, sometimes you have to clean out all drains, usually they clog in the bottom.dirt,trash,etc.builds up and restricts or stops the flow then it backs up and leaks into cockpit area.
1995 jeep grand cherokee with 4.0 engine back fires through air fliter box when driving and the vehicle loses power.
Possibilities can include:
Clogged catalytic converter - needs replacement or removal.
engine timing off - adjust the camshaft position sensor.
distributor cap & rotor - replace along with new spark plugs and wires
1995 Jeep Grand Cherokee Laredo - sunroof leak
lift rubber edges and apply clear silicon sealant under edges let cure hose with water to test, if leak then seal edges of glass with eurothane sealant, not silicon will rot in sun within year
1helpful
How to clear the diagnostic codes on my 1993 jeep cherokee?
To clear codes on these, you can disconnect the battery, then re-connect. The only code remaining will be one indicating battery power was interuppted. This will not work on 98 and newer vehicles.
1995 jeep grande cherokee starts out like nothing is wrong but want shift out except sometimes .changed fluids and filter
I had the same problem with mine you had to let off accelerator to get it to shift .I am assuming u do the same? I changed the filter and fluid and it cleared up. ???is it leaking trans fluid?
Top Jeep Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Jeep Expert? Answer questions, earn points and help others
