Question about JVC KW-XG700 CD Player
Power button will not turn on JVC XG-700. Checked fuses...all good. Checked wiring...all good. It was working fine until the other day. I turned off my truck, went shopping, started my truck to leave and it did not come on. Still accepts and ejects CD's and shows time?lights up when you press DISPLAY. Is it something in the radio that failed ????
GARYDALE
  • 15 Answers
SOURCE: JVC KD -S680 needs help
all radios like your has two power inlets one is battery and the other is Acc or Ing. The battery line keeps power in the radio after you turn off your car both lines must work for the radio to turn on it sounds like a resister burn out thats why your face plate was warm.
Posted on Sep 25, 2006
  • 3 Answers
SOURCE: JVC KD-LHX500 has power, but won't turn on!
Replace the 15 amp spade fuse in the back of the unit. See if that get you going again. If that doesn't do it then check your wirin Black goes to ground, Yellow is a constant hot, Red is a hot trough the fuse box, Blue is for your power antenna if you have one, the Orange with a White Stripe is to the Illumination and is also hot.
Posted on Nov 12, 2008
SOURCE: JVC CD player won't turn on, but will eject CD and display time.
Make sure the red wire is still connected or make sure the red wire hasn't been severed. Also, check the fuses located in the engine compartment. The red wire connects accessory terminal in the fuse block. Also check the fuses in the cabin. This fuse box is typically located on the driver's side, at knee level, next to the door panel, and underneath the dashboard. As a last resort, the unit can be taken to an authorized or factory service center.
Posted on Feb 01, 2009
  • 3 Answers
SOURCE: JVC KD-G340 Power Problem
yellow wire is another power wire that goes directly to batt.,red goes to acc. or fuse box & black is ground
Posted on Mar 04, 2009
Lando93
  • 8 Answers
SOURCE: JVC KD-R200 won't power up for more than 5 seconds
Check your wires they might be touching steel around your car mostly look at your yellow and red wires those are the 1' that give it power and light to your radio also check your radio fuse in the back.
Posted on Jun 10, 2009
Jvc kdr431 wont turn on
Check all of your fuses and make sure you are getting power to the red wire. It sounds like you are getting power to the yellow wire already. Both the red and yellow wires have to have power going to them in order for the radio to work.
Mar 13, 2013 | Car Audio & Video
My jvc kd-r520 will not turn on. It's as if
make sure the fuse in the fuse box is good then check the relay to the radio is good ( factory relay ) if all thats ok, check the fuse on the backside of the head unit.....
then while the head unit is out check the wires to make sure a mouse did not bite any wires...
Feb 24, 2012 | JVC Car Audio & Video
JVC KD-SH 1000, light comes on round power button but unit doesnt power up
Hmmmm. Could be the detachable panel itself. Call customer relations.
Feb 12, 2012 | JVC Car Audio & Video
Installing KD-HDR20 and I get a red power light but nothing works
I have had the same issue and I tried until I found the problem.
1) I had no power to my remote wire.
(The wire that only allows the radio to work when the care ignition is on.)
2) The radio has a fuse or maybe two.
But the auto mobile may have blown its fuse.
In my case it was the remote fuse.
3) I have had a bad ground and only need to find a good place.
4) I have even found insufficient power to my radio because too many devices were also using that power.
5) Heck I have even forgot to start the care or at least turn the ignition.
6) My battery was so dead it couldnt even power my radio.
Mar 16, 2010 | JVC KD-HDR20 Car CD/ MP3 Player
I have a Sharp Projector model XG-E3000U that won't power on. Nothing happens at all when you turn it on. No lights, no fan, nothing. I opened it up and checked the fuse and that's good. Is there a reset...
the powersupply is failed
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jan 18, 2010 | Sharp (CLMPF0046DE01) Projector Lamp for...
JVC KD-G200 won't power up any more.
Have you checked the fuse-box to make sure that you didn't blow the fuse for the radio? Also try removing the radio and checking the wiring to ensure that it is tight. There is also a fuse on the back of most radios to check!!
Nov 16, 2008 | JVC KD-G200 CD Player
XG-91D (Black) 19 in. Flat Panel LCD Monitor
Partition shows up as a MS-DOS partition This utility is designed save information you may be working on when it goes into sleep mode or when your battery becomes low on power.
Computer questions and answers listing 700 - 800 CH000735, How do I disable the power, sleep, or wake buttons in Windows?
Good Luck, please dont for get to Vote, Thank You.
Aug 03, 2007 | Xerox XG-91D 19" LCD Monitor
JVC TH-M505 powers off right away
The unit is going in to shutdown. My guess is a failed output. Service is going to be required.
Sep 20, 2006 | JVC TH-M505 System
JVC KW-XG700 CD Player Logo
48 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
