Question about Maytag DWU9962 Dishwasher
I am looking for a manual to remove the bottom sprayer on a Maytag DWC 8240 AAW dishwasher. This is a portable unit that has chipped the crockery since we bought it. Now during only the drying phase there is a grinding noise that sounds like the glass chips are being ground up. There are some screws that I can remove to find what I think is the filter. How do I get to the filter?And where can I find an exploded parts diagram? Thanks
    Master:
  • 186 Answers
Most likely the noise is coming from something getting into the pump
Posted on Jul 05, 2017
SOURCE: Maytag dishwasher legacy 300 quiet series
FYI... I followed Miss Midget's steps... and there it was... a piece of plastic... actually one of the end caps from the rack. Poor design if you ask me. So for all you "grinders" out there, it's an easy fix... just need the appropriate star screwdriver. It went back together easier than it did taking it apart. Thanks.
Posted on Nov 28, 2007
  • 3 Answers
SOURCE: loud noise maytag dishwasher quiet series 100
Hi All,
I have had a Maytag Quite Series 300 for some years now and have done basttle with it on may occasions. I now consider myself somewhat of a veteran, although by no means a repair expert!
Grinding Noise: From either a clogged/blocked impeller or not enough water getting to the impeller.
For a clogged impeller, it is fairly easy to disassemble the washer to get at the impeller to remove any debris or blockages.
For not enough water it can be a number of things. First of all, you will notice that the noise lessens if you add a jug or two of extra water. This is because if the water level is too low, the pump impeller will get some air mixed with the water & this is LOUD! Now for the causes:
Float – If the float gets stuck in the wrong position (debris or water deposits), it will not fill enough.
Float Set Wrong – Seems thats some of these dishwashers have the float set a little too low to let the dishwasher perform without grinding. A few pennies attached to the float with a rubber band seems to help here. Don't go too far or you'll flood your kitchen!
Timer – Some folks have mentioned that dishwashers that fill on a timer will not fill enough in the allotted time, if the water pressure is low. While this is true, I have looked over the electrical & parts diagrams for the QS300 and I do not see a timer listed anywhere. Also, the wiring diagram appears to show that this dishwasher only uses the float to achieve the correct water volume. I could be mistaken here.
Note that in VERY hard water areas (like mine – TDS of 850 hardness or 49 Grains), the plastic fins on the cover of the impeller get very choked up with water salts and this can impede flow, leading to a low-water symptom, when in fact, there is plenty of water.
Dishes Not Cleaning:
Poor Water Flow – See above, all the above items will negatively impact dish cleaning.
Poor Q uality Detergent – After trying them all – Yes, all – Do not use cheap detergent. Buy the brand names: Cascade or Electrasol work well. I have found that by far, the little packs work the best. We found that the liquid works second best and the dry stuff really isn't up to the task at all, no matter which brand.
Spray Wands Catching – We found that our lower spray wand was catching on the bottom of lower dish tray, so I very slightly bent down the legs that the wheels mount to in order to lift the dish tray/basket a little and give the wand a little more room. This worked well.
Spray Wand Nut Too Tight – The factory seems to send the dishwasher out with the nut on the bottom spray wand tightened a little too far. Loosening this a little bit lets the bottom wand rotate much more easily.
Top Spray Wand Not Meeting Receptacle – The top spray wand is attached to a pipe that mates with a port (well, one of two ports, depending on if you have the top rack in the “Upper or “Lower” position). The pipe seems to have a tendency of missing the port. A well placed elastic band will help here. Note that on our dishwasher, by the time the first elastic band wore out, the pipe had been permanently moved to the correct position by the gentle pressure.
Tines/Dish Holders On Top Rack Falling Over – The tines (metal spikes) that hold dishes on the top rack fold down by design. Issue here is that they do it sometimes during the wash, causing the dishes to fall over and block the spray. A few well placed rubber bands help here as well.
Water Salt Buildup – If you live in a very hard water area, you can still get clean dishes from yor dishwasher. We do and we have VERY hard water. Buy a gallon of vinegar once a month. Pour this into a clean dishwasher. Turn it on so that it runs for 2 minutes to circulate the vinegar. Open the door & let stand over night. Close door & finish cycle. This will cut down significantly on the hard water salt buildup in the washer.
It's A Maytag – Sorry folks, it's true. I have learned (after purchasing the dishwasher) that Maytag has run into financial difficulty in recent years and has reduced build quality to save money. If you got suckered into buying one of these, you will very likely never buy one again. My opinion is “Do not by Maytag.”
Hope this helps someone!
Posted on Feb 10, 2009
rylee_smith
  • 8619 Answers
SOURCE: maytag dishwasher has a grinding sound during the
Hi
Many times a complaint of noises ( grinding or scraping ) can be traced to a cracked impeller in many of the common motor and pump assemblies used today. Sometimes a poor washing complaint is common after this wash impeller has cracked. Remove power first before investigating.
The motor shaft has started to rust and swells out and this swelling cracks the upper impeller. Most times a new seal and impeller kit can cure this complaint but sanding and cleaning of motor shaft is required before replacing the new seals and impellers.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jun 03, 2009
  • 35 Answers
SOURCE: dishwasher parts maytag mdb7100AW
http://www.partselect.com/ModelFrames.aspx?ModelID=121045&ModelNum=MDB7100AWS&mfgModelNum=&ManufactureID=1&Selected=52761&Position=0&mfg=Maytag&Type=&Mark=0
go to this website and you will have the parts diagram
Posted on Jun 14, 2009
caroldon
  • 17130 Answers
SOURCE: I have a maytag jetclean
Possible that the pump is not working well to spray and inject with good pressure so that the dishes are spot clean.
You will need to simulate the washer without any dish and checck the performance to understand the fault areas.
The middle section also must spray well another reason your dishes are not clean when kept low.
The entire system has to be taken out and the water flow sections must be cleaned. the pump must work and spray with high pressure or else it must be clogged , the reason for sluggish spray.
So check the inlets, the water lines and the pump.
The rest sems fine.
Posted on Sep 02, 2010
My maytag jetclean dishwasher quiet pack makes a grinding noise and the sprayer doesnt spin
Take apart the sump filter area and check to see if anything is stuck in the impellers for the wash motor.
Jan 01, 2015 | Maytag Dishwashers
Hello, I have a portable Moffat dishwasher Model: MRC3210SW159, Serial: AR608530A. We are getting small food bits stuck all over the dishes. Not sure what to take apart or do? Could you please give us some...
Your sprayer arms may be clogged.
The upper arm attaches to a tube in the back of the dishwasher. If the support clamps come loose, the upper spray tube will not be flush with the tube and can't carry water to the sprayer arms. Also the sprayer arms can become clogged with paper remnants, bone fragments, or pieces of peeling. You'll need to remove the sprayer arm and flush it at your sink. If there is a jet that is clogged, tweezers will help remove the residue.
Finally, the bottom of the door INSIDE the washer often get covered with gunk. Be sure and gently wash the bottom of the door INSIDE. You can open the door, spray some window cleaner on the bottom and then gently brush away the 'gunk.' Rinse with hot water from a pitcher or your sink sprayer and this can eliminate some of the residue that is showing on your dishes.
And of course, when you're loading the dishwasher, be sure none of the items are resting ON each other. This will prevent the water from circulating and cleaning.
I hope this helps. If it does, please come back to Fixya and rate my answer
Jun 12, 2011 | Dishwashers
Bottom Sprayer not spraying. does not look blocked
1)wash arm not spraying(or)rinse not spraying?
wash arm
1)remove the wash arm
2)switch on the machine all blockaged removed automatically.(remove the wash arm).
rinse arm
1)check any scaling in the boiler tank.
2)clean the boiler tank.
3)clean the rinse arm.
Jan 07, 2010 | Dishwashers
Lower spray arm siemens aquastop dishwasher doesn't rotate
Sprayers require water to pass through the jets to provide motion to the arms.
Suggestion;
Remove the sprayer from the machine and look for blockages. (Removal should be easy, at it is expected that the user will need to clean the jets occasionally; If you have any problems removing it, consult your manual).
Dec 14, 2009 | Siemens Dishwashers
Indesit idl 705, tablet not dissolving and crockery still dirty, was working fine. Sprayer arm seems to not rotate freely
Clean EVERYTHING and ensure it's assembled correctly.
The sprayer arms have an unlocking ring and can be rinsed, the filters must be washed and rinsed and properly reassembled.
Even cleaning the door seals can help.
Test again, clean again (as more muck can be circulated).
Sep 27, 2009 | Indesit 24 in. IDL700 Built-In Dishwasher
How do you remove the lower spray arm from a maytag mbd4100 dishw
go to managemyhome.com and type in your model # and get your manuals.
May 03, 2009 | Maytag 24 in. MDB4100 Built-in Dishwasher
I am looking for an instruction guide booklet
sorry but my sites arent finding a model mjd2000aaw. www.maytag there is section for cumsumer support wher eyou can download your manual with model info
Dec 02, 2008 | Maytag Dishwashers
Soap stuck in dispenser/dishes not getting clean
try and find a manual to assist you, pdfoo.com , but most ot the sprayers have clips that hold them on/in. just be carefull not to break any.
Jan 21, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
Maytag jet clean model#dwc7400aaw
Check to see in you have enough water in tank. The dishwasher fills then recirculates this water under pressure. If you have water in tank, listen to see if motor is running or not. If it is, you may have clogged jet holes in the wash arms.
Jul 31, 2007 | Maytag MDB9600A Jetclean II Built-in...
Dishwashers Logo
91 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
