Question about Gateway Computers & Internet
MY EJECT BUTTON IS BROKEN AND I WANT TO INSTALL ANOTHER CD DRIVE BUT I DONT KOW HOW TO TAKE THE TOP OFF ?
  • cherylwithac Jun 01, 2008
    My eject button on cd drive is broken and I would like to replace it, where can I find one?
    Thanks
    Cheryl
I DIDNT HAVE TO TAKE THE TOP COVER OFF THE ONLY THIG I HAD TO TAKE OFF WAS THE PIECE ON THE FRONT THANKS THOUGH
Posted on Apr 25, 2008
I dont kow how to use a flash drive
Easy put it in, drag files you want to it and eject. then insert to other comp and drag files you want out then eject.
Jan 27, 2014 | SanDisk Cruzer Electronics - Others
Cd dont eject
it sounds like the intake/ eject rubbers are not working this is almost always due to a broken drive belt take the top of the stereo and have a look for the intake wheel see if the belt is broken and then replace
Dec 31, 2010 | Car Audio & Video
How can I eject a cd from my dell
Try right clicking the CD drive in my computer and then click eject. If that doesn't work, look closely and you will see a tiny hole normally next to the eject button, sometimes there is just a grove. Take a straightened paper clip and insert it in that hole. This should open the drive. You may have to turn the computer off for this to work. If that does not work you will have to try prying it open with a butter knife. It may damage the drive but seems it is already damaged.
Aug 04, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
My dvd won't eject after playing.
What exactly do you mean? A DVD or CD will not automatically eject. You must tell it to.
If, however, you mean that when you press the eject button it doesn't come out, then the drive has a problem. You can push a paper clip in the little hole in the front and the drawer should come out. If you can eject it manually but not with the button, then your drive is bad--perhaps something broken in the button.
You can also go to "computer" or "my computer" and right-click on the CD/DVD drive and choose "eject" to see if it works by using software.
Jul 19, 2010 | HP Pavilion dv7-1130us laptop
When i press eject button cd drive is not
Sounds like the belt inside is broken or came off. Does te drive still sound like it is opening but does nothing? Also try using a small paper clip and push it into the small hole on te front of the CD-ROM that will at least open the drive manually and possible fix the problem if the device is stuck.
Apr 20, 2010 | LG GSA-H42N 18x DVD RW DL IDE Drive...
I just bought a car that has a kdc 516s and
You need to flip the front panel down first and there will be an eject button on the inside of the panel. If this is not working try pressing the tiny reset button which is left of the ATT button.
Dan
Nov 18, 2009 | Kenwood KDC-516S CD Player
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
CD drive button broken
You might try to remove front cover from you CDROm and checked whether button is not broken or stucked
Oct 07, 2009 | E-Machines emachines (emachinees) CD-ROM...
My car radio jvc won't eject my cd? an need to kow how to?
this is a common problem with this model radio. if it wont eject by pushing the eject button. you can do a hard reset by holdin the SEL button & the POWER button at the same time until the until ejects your disk. OR pushing the SEL button first, then the POWER and holding both until it resets.
hope this helps
Sep 14, 2009 | JVC AM FM CD DET FACE CAR STEREO
Ejecting cd dell studio 17
to save you time you dont have to right click on drive E: and press eject. you can just press the eject button on the hinge cover. this is an image of the hinge cover thumb_nu385.jpg on the hinge cover look for this ICONfinder-toolbar-eject-128x128.pngpress it to eject disc.
if this helps, please rate...
thanks.
PJBHOi
Mar 12, 2009 | Dell XPS M1530 Laptop
Computers & Internet Logo
101 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
