Question about Nikon COOLPIX L3 Digital Camera
Lens error with a slight twist
I get the lens error if i turn it on and do nothing because the lens doesn't come out all the way. But if i tap it with the lens facing down while turning it on, the lens goes all the way out and is ready to operate BUT the twist...all the pictures that i take are very blurry. whether it is with the flash or not. I do not know what is causing the blurriness.
If anybody has any ideas, I'm ready to troubleshoot. Thanks for your time.
  • 797 Answers
See my posts on this problem.. This may be that the lens is off track. You can try to force it in and out as you turn it on and off. You can damage the camera, but if you know that it is already damaged, may be worth a try.
Posted on Jun 21, 2008
Error code 032
Error 32 can be a stuck lens. Try the following:
1: Turn on the camera while you hold the shutter button and connect it to the AC adapter or to the USB cable at the same time.
2: Now by default the lens should get properly aligned if not try to twist them slightly by holding down the camera lens with soft hands.
3: Just push and pull the lens slightly as it extends automatically.
4: Now when the lens is in the hard surface power on your camera.
5: Try to hit the camera softly beside the lens which might solve the issue.
Mar 23, 2014 | Canon Cameras
Lumix digital camera lens won't open all the way. I live in Orange county Califonia. Please give me a place to get it repaired it might be the battery charger. Help need telephone number...
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Sep 16, 2011 | Cameras
I keep getting a error code on my screen saying lens error 0x01110000 and it will not let my do anything i can press the power button screen comes on then the lens error code comes up and then it turns its...
Sep 16, 2011 | Pentax Optio E60 Digital Camera
Lens error.....restart camera. Tried over and over again. Nothing works. HELP!
Went to the beach yesterday, by the end of the night my camera gave me this error: "lens error, restart camera". The lens would no longer come out.
I figured sand got stuck within the lens, so I did the following:
1. Turn camera up-side-down (with lens facing down)
2. Gently tap the sides of the camera (to loosen particles in lens)
3. Turn camera on
4. The lens will eventually come out
5. Gently tap the sides of the lens
6. Turn camera off (continue tapping side of lens as it retracts)
I turned the camera on and off a couple of times to ensure I removed all sand particles from the camera.
Now the camera works...thank god....
thanks.
Apr 11, 2011 | Canon PowerShot SX10 IS Digital Camera
My nikon coolpix s210 shows lens error
Hey digi_5
This is a common problem with Nikon and it isn't covered under warranty since Nikon sees it as an error resulting from usage. Apparently, the Coolpix is pretty delicate and any slight bump can cause a lens error.
Some people have tried gently twisting the camera lens back into place or gently tapping/bumping the side of camera.
If neither of those work, I'd say try getting the camera repaired professionally - if it isn't covered by Nikon, they'll charge you heavily. I've used Teleplan Camera Repair before and they're cheap compared to other places.
I've heard that once the camera is fixed, turn it to the Playback mode before turning it off - it apparently helps avoid the problem altogether.
Apr 16, 2010 | Nikon Coolpix S210 Digital Camera
Coolpx S51 lens error report. How to access pictures and turn off the error message
it is a pretty major problem for the Coolpix it seems. The internal coupling of the zoom lens is somewhat fragile, and a slight tap at the wrong time can mess up the system. It could have been something as small as a bump while it was being carried in your pocket. The problem is that you'll have to pay for repairs on it since technically it's not a camera error but something that Nikon says happened during usage.
Some owners seem to have been able to solve the problem with a gentle bump to the side of the camera, or some gentle twisting on the lens itself. I don't necessarily recommend that- or, at least I would call Nikon first and see what they have to say about cost of repairs. Other people say that once you do get it fixed, put the camera in Playback mode before you switch it off so that the problem doesn't happen again.
Jul 03, 2009 | Nikon COOLPIX L10 Digital Camera
I turn my camera on and without coming out all the way the lens goes back in. Then "lens error" pops up on the screen.
It is a pretty major problem for the Coolpix it seems. The internal coupling of the zoom lens is somewhat fragile, and a slight tap at the wrong time can mess up the system. It could have been something as small as a bump while it was being carried in your pocket. The problem is that you'll have to pay for repairs on it since technically it's not a camera error but something that Nikon says happened during usage.
Jun 29, 2009 | Nikon Coolpix S210 Digital Camera
No shutter release
It turns out that supporting the camera while taking a shot can impart a slight twist on the seated lens. This twist is just enough to cause the camera to think that there is no lens installed .. hence the error message. Solution (provided my Henry's Camera experts) was to reseat the lens by reversing the twist. It has since happenned twice and each time recovery was effective .... Keith
May 25, 2009 | Nikon D80 Digital Camera with 18-135mm...
Camera wont turn on due to lens problem....
Same problem. I applied pressure to the extended lens by slightly twisting it from side to side. Hit the power button and the lens retracted and then extended again. The camera seems to be working properly.
Jan 26, 2009 | Kodak Easyshare C813 Digital Camera
A210 zoom error
When you first turn the camera on, grab the lens, pull on it slightly. Turn the camera off and try it again. If it doesn"t work the first time , pull on the lens slightly again. It worked on mine
Dec 23, 2007 | Fuji FinePix A205 Digital Camera
Nikon COOLPIX L3 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
