Question about HP D8597A Keyboard
Media controls not working hp computer - HP D8597A Keyboard
    President:
  • 2,571 Answers
Have you loaded the drivers for the extra functions
Posted on Aug 01, 2010
    Scholar:
  • 104 Answers
Try checking your keyboard with other computers whether its working there or not. If not, then go for a replacement of your keyboard if you want those media controls to function properly.
Use of crescent key above escape key in model HP 5187-7583 Silver Multimedia Keyboard With Media Player
The crescent key is for the computer to go night night!
Look under power settings in control panel this could be a key that can be reprogrammed. Usually out of the box it will but the computer into sleep mode.
For some key boarda the "Fn" key and crescent both need to be depressed.
Shaking the mouse or hitting space bar will wake up the computer.
Hope this helps?
Jun 20, 2016 | HP 5187-7583 Silver Multimedia Keyboard...
How to use hp remote controler
Certain HP entertainment PCs come with a remote controller. It can be used to power up the computer (Windows icon)., or power up the computer and launch the Media Center. Other buttons should be self-evident.
Oct 30, 2013 | HP Computers & Internet
HP TSGH-IR02 Remote Control how to install
This document pertains to HP Media Center computers with Windows XP, Media Center Edition.Use this document when the remote control does not work correctly with the Media Center software.Troubleshooting the remote controlUse the following items to troubleshoot when the remote control does not respond or when the remote control does not work properly. For example, when a key is pressed the selection moves all the way to the top or bottom of a list, or moves a selection many different places instead of the item you were trying to select.Before attempting these steps, make sure that PC has been updated with all of the latest Windows updates. Many updates for Media Center, like Update Rollup 1 for eHome Infrared Receiver, can be downloaded easily through the Windows Update software Tool.
Make sure that the batteries for the remote control are installed correctly and charged.Make sure that the front of the remote sensor is unobstructed, within a 45-degree range, and is less than 26 feet (8 meters) away. Disconnect all devices that use a USB connection except to the receiver, keyboard, and mouse. Restart the PC, and then try the remote again.If a pressed button repeats itself (sticks), unplug the IR receiver from its USB connection, wait one minute, and plug in the IR receiver. If the pressed buttons continue to repeat, alter the lighting conditions in the room or move the location of the IR receiver. Other remotes and HP Media Center PCs within range can also cause this issue.Try pressing the Enter key on the remote after changing a channel.If the remote control works when using the media center software, but does not work when changing the television channels, re-configure the Media Center software settings for the cable set-top box or satellite receiver
Point the remote control towards the IR receiver and press a button. A faint red light should appear on the IR receiver. If the light appears, then the problem is probably in the software that is using the remote control (most likely the configuration of the Media Center software). Close the software, restart the computer, and then re-open the software to solve this issue.
Troubleshooting the IR receiverThe IR receiver is the small device that receives the signals sent by the remote control. Use the following steps to test and reset the IR receiver.Disconnect the IR receiver from its USB port on the computer, maximize the Media Center window if it is open, and then reconnect the IR receiver. Test again.Point the remote control towards the IR receiver and press a button. A faint red light should appear on the IR receiver. If the light appears, then the problem is probably in the software that is using the IR receiver (most likely the Media Center software). Close the software, restart the computer, and then re-open the software to solve this issue.Click Start , right-click My Computer , and then select Properties .Click the Hardware tab and then click the Device Manager button.Click the plus sign next to Universal Serial Bus Controllers.If the eHome Infrared Receiver is listed under Universal Serial Bus controllers, Windows is properly detecting the IR receiver. If eHome Infrared Receiver is not in the list, or there is an exclamation mark or a question mark on the device, perform the following until eHome Infrared Receiver appears correct in Device manager:Unplug the end of the USB cable on the IR receiver from the computer and plug it into the same USB port.Plug the end of the USB cable on the IR receiver into the front USB port on the computer.Disconnect all other USB devices, leave the IR receiver plugged in, and then restart the computer. Plug in other USB devices after the IR receiver shows up in device manager.Figure 1: IR receiver listing in Device Manager
Testing the remote controlUse the following steps to check the responsiveness of the remote control:
  1. Open the Media Center software by double-clicking the Media Center icon the desktop or by pressing the green Start button on the remote control.
  2. Click Settings , and then click General .
  3. Click Check Your Remote , and then click Next .
  4. Press the numbers on your remote control. The corresponding numbers on the numbers on the screen should glow when each button is pressed. A faint red light should also glow inside the IR receiver each time a button on the remote pressed.
  5. Click My control is working properly , and then click Next . Do not click I am having problems with my remote control as this will not do anything.
  6. Click Finish after you are done.
Dec 17, 2011 | HP Computers & Internet
Problem hooking up bose speakers
mcdevito75 here, The HP speakers that came with your computer work fine, the bose speakers work fine on your other computer, the plug on the Bose speakers is a little shorter than the HP speakers, and only the right Boss speaker is working, HMM, Check the Bose speakers, both of them for a volume control 1 of them may need adjustment on this particular computer. If that"s not it, I would speak to a Radio Shack, Staples etc.
Jul 04, 2010 | Bose Companion 2 Series II Multimedia...
My problem is with the HP Personal Media Drive
> When I unplug the media guide, then it doesn't show up on my computer.
That makes sense -- when _not_ physically connected, then it will not show up within "My Computer".
Try a different USB-port on your computer.
Or, connect it to another computer, to see if Windows will detect it, and will assign a drive-letter. If not, then try a third computer -- it could be "dead", if 3 computers cannot detect it.
Dec 14, 2009 | HP Computers & Internet
My laptop responds to tv remote
you can turn off the IR on the laptop or put black tape over it!
Sep 19, 2009 | Microsoft Windows XP Media Center Edition...
How can i use rc6 remote on my computer
The remote control which ship along HP notebook works with only Windows Media Center ..... all you need to launch Windows Media Center application and use the remote to control on notebook, hope this help u.
Jul 23, 2009 | HP Pavilion dv2000t Notebook
My cordless HP keyboard Media Controls and quick launch buttons such as: Search, Internet, Info and E-Mail do not funcion. Need set-up instructions or troubleshooting info. Please advise.
You didn't specify the type of computer.  If you go to HP's support page for your computer there should be a download for the keyboard software.  You will need to install that for the extra buttons to work.
HP Multimedia Keyboard/Mouse Driver Update
Apr 26, 2009 | HP Multimedia Cordless Keyboard/Mouse...
What goes into the media centre inthe front of HPm9590a
media centre is all in one.
U can watch TV's, Listen to ur favourite MP3's, watch ur movie's & video's, Burn a cd and control ur computer..
Its a nice software to work upon
Apr 10, 2009 | HP Computers & Internet
No Ethernet Controler device drivers after reinstall of windowsxp
I contacted HP and this is the link to the driver they said will work.
Link to driver
It is an FTP link, which is here if the link is not working:
ftp://ftp.hp.com/pub/softlib/software5/COL11958/pv-35412-1/sp26561.exe
Your computer has intel 945P chipset.
Dec 11, 2008 | HP Media Center m7250n (ED842AA) PC...
HP D8597A Keyboard Logo
124 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
