Question about Kenmore Heating & Cooling
HI there, I got a kenmore mod. 129-35710 (portable) and i just cleaned the filter and the backing of the air conditioner, and i placed everything the way i found it. Placing the power back on... the little display is now flashing 'Ft'...... how do i fix this problem??
SOURCE: Air conditioner turns on then shuts itself off immediately
There's something wrong with your aircon. Usually the lights will start to blink. Depending on the brand and model, the number of times it blinks will give you an error code which tells you what's spoilt. You may like to check this out http://www.astiquer.com/blinking.html
Posted on Oct 07, 2008
SOURCE: Whirlpool portable AC, compressor works, but no exhaust fan
This is a single speed permanent split capacitor motor for the condenser. One of the capacitor wires shows infinite resistance to hot and netral. The motor needs to be replaced.
Posted on Mar 31, 2009
james3751
  • 614 Answers
SOURCE: MY PORTABLE AIR CONDITIONER NOT WORKING!
There is a switch inside the bottom of unit that shuts it off when it is full of water. Has to go in just right to be able to work. Russ
Posted on Jul 24, 2009
  • 3 Answers
SOURCE: what does the PF stand for???
Posted on Oct 05, 2009
  • 400 Answers
SOURCE: Air Conditioner cannot be turned on when power-light is flashing
The flashing light is a delay timer, usually activated when changing from heating to cooling and visa versa. The fact that the unit can only run from certain times shows that the timer is activated. You need to cancel the timer function on the remote.
Posted on Nov 19, 2009
My kenmore 12000 btu portable air conditioner keeps switching to DH mode out of AC mode
That means that it is dehumidifying. Is the air coming out still cold? I assume you have tried using the mode button to switch it back? Is the air extremely humid? Perhaps it is humid enough that the machine needs to dry the air before safely operating as an AC. The manual is available here:
http://www.sears.com/kenmore-portable-room-air-conditioner/p-04272012000P
Jul 05, 2015 | Kenmore Portable Air Conditioner 10000 BTU...
My portable. Air conditioner. Isn't cooling
Could be a number of things, Is the compressor running? If so, are the filters clean? ( Both the outlet and the inlet filters.) One at the front where the air comes out and one at the back where the air goes in.
Sep 07, 2013 | Portable Air Conditioners Portable Cooling...
Where is the filter to clean on your air conditioner
Hello, typically the filters are located in the back of the unit.
Jul 15, 2012 | Maytag M6P09S2B Portable Air Conditioner
How to change or clean the filter and where to download a manual
DeLonghi has the manuals for their portable air conditioners here: http://delonghiusa.com/support/product_manuals/5#table-jump . The direct link to the PAC C120 manual is http://delonghiusa.com/support/sites/default/files/product_manuals/m-PAC+C120.pdf .
Before cleaning, turn off the air conditioner. To clean the filter, pull it straight up from behind the top of the air intake (on the back of the PAC C120). Vacuum off the filter. If it is very dirty, immerse it in warm water and rinse several times. (The water should not above 40 degrees Celsius (104 degrees F)) several times. Then allow the filter to air dry. Slide the filter back into the air conditioner and turn the unit back on.
I hope this helps.
Jul 17, 2011 | DeLonghi PAC C120 Portable Air Conditioner
I have a Kenmore C120 portable air conditioner. It is leaking water from the back bottom. There is a white drain but this unit is supposed to self evaporate. At least it did last year. Now it is leaking...
Interestingly, your Kenmore Portable AC is manufactured by Delonghi. Occasionally, what you are experiencing happens when the humidity level is high and the air intake filter needs to be cleaned.
That also means that you will need to drain the tank, at least once.
You know where the drain plug is, so you can either carefully take it outside to drain or put a low sided container, capable of holding 1 1/2 quarts of water under the drain plug. If you drain it inside, turn the Master ON/OFF Switch to OFF and unplug the unit, before attempting to drain it.
Hope this helped you to solve the problem.
Jul 13, 2011 | Heating & Cooling
I have purchased a Kenmore Elite A100E floor model airconditioner and when it is running water pours out from where the wheel castors are connected underneath the unit??
This also happen to me and it means that your drain is clogged it needs to be cleaned out. Your grill in unit could be dirty and probably needs to be cleaned also.It is really simply but might sound complicated it's not and if it is not under warranty it would be cheaper to do it yourself. You need to take offf the sides and get a little flash light one of the sides have the drain hole and you get like a piece of wire or something like that, something thin to dig out what is clogging the hole & get a small dust brush or vacuum the dust from the grill and drain the air conditioner put the plug or stopper back in and put the sides back on and screw them into place and everything such be fine.
Jun 12, 2011 | Kenmore Heating & Cooling
My NewAir ACP-1400/H air conditioner freezes up. I have cleaned the filter and check the air flow. Everything seems good, but it still freezes up.
Its sounds like a refrigerant leak from the factory if you just got it. Check your warranty and call the manufacturer for repairs. Unfortunately there is no simple fix.
May 17, 2011 | NewAir ACP-1400E Portable Air Conditioner
Hi, we have a wa-903 air conditioner, which I think is by Kenmore, but we have no instruction manual. It doesn't seem to get as cool as it should, can anybody help with basic operating instructions please?
This machine needs to be vented to the outside of the building. There is an air exhause port at the back of the unit to which you attach the exhaust piping. Also try cleaning the filters. these are pullout filters at the top of the back plate of the unit.
Hope this helps
Nov 25, 2009 | Kenmore Heating & Cooling
My kenmore was smoking and is not blowing cool anymore?
Hi
Please check the air filter as it might be clogged with dust, you can try to clean the air filter and re-install it. Also check the air flow from the outside condensers as that might be obstructed and leave a clearance of over 1 meter between the back of the air conditioner and the wall behind it. If still the issue is not resolved then you need to contact a qualified repair tech. as this might be due to a burned wire inside the unit.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 10, 2009 | Kenmore 72056 Air Conditioner
Heating & Cooling Logo
258 people viewed this question
Top Kenmore Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
