Question about Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver
Can I adjust the slip clutch on my Dewalt XRP?
  • donn_olson Aug 01, 2010
    My slip clutch is now so loose that to apply enough torque to drive a screw into wood it needs to be on the screw setting or it will slip so bad it will just stall. Can I re-adjust my clutch setting to bring it back to original setting strength?
  • 454 Answers
Yes it is the black ring with the numbers on it, the lower the number, the easier it slips. Higher number, less slip.
Posted on Aug 01, 2010
Dewalt 18v xrp clutch slipping and electrical smoke smell in rear
Yes you can. Depending on the model of the tool it may not be the clutch causing your problem though. On some models the transmission is more likely the problem. Brushes create an ozone smell when the motor runs so that could be the smell. Does it run slow or get hot?
Jan 01, 2012 | Dewalt 18 Volt Compact Drill Kit
The clutch is slipping how do i fix
If its clutching out in drill mode the clutch pin is worn. This part is 635718-00 its only a couple bucks. not hard to repair either bout 5 min.
Sep 07, 2011 | Dewalt DC988kar XRP 3 - speed 1/2" 18v...
Can not adjust clutch on DeWalt dcd951 xrp
This uses a centrifugal clutch and it is not adjustable. If it is not engaging or slips replace the clutch drum
Apr 27, 2011 | Garden
Can I use a 18 volt XRP battery in the DeWalt DW938 Reciprocating saw?
Yes. Dewalt says the 18volt XRP battery is compatible with all Dewalt 18volt tools
Have a great day.
Dec 29, 2010 | Dewalt Dw938 18v Reciprocating Saw Sawzall...
My dewalt slips bad in the drill mode whiile i am drilling in hard material the drill slips real bad and it also does it in the hammer mode. Is that normal
Check the speed selector switch. if it is not fully engaged (usually because of dirt) the gears will slip. cycle the switch a few times.
May 21, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Amount of torque per setting in dewalt dc925 xrp
The torque settings are not tightly controlled so they are not all that repeatable from drill to drill. They also vary somewhat with the speed of the drill and the condition of the battery. And they aren't linear (a setting of 10 is not twice the 5 setting) Simplest thing to do for a rough idea is to use your hand to hold the chuck still to feel how much torque you have at each setting. (start low and grip it tight!) If you want a specific torque setting, say 10 ft-lbs, then put a stout screw in a scrap of wood, hang a 10 lb weight on it 12 inches from the screw and adjust until it just starts to slip.
Apr 02, 2010 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
Dewalt 18v xrp clutch??
Hello Matt - I recommend that you get your drill to the nearest Dewalt service center. That way you know it will be done right and under warranty. Go to this site to find your closest dewalt service center:
http://www.dewalt.com/us/service/center_finder.asp
Apr 04, 2009 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
HAMMER MODE SLIPS OUT
i am guessing the transmission problem not enough tension to the clutch
Aug 11, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt Drill
if the drill is slipping in speed 3 & drill mode. it needs new transmission assy. see www.toolpartsdirect.com , www.ereplacementparts.com for pricing for the the parts.
Jul 27, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt 18V XRP Clutch Slipping
it very economical to repair the drill. replace the transmission.
Apr 27, 2008 | Dewalt 18 Volt Compact Drill Kit
Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver Logo
752 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Jim Thurston
Craig Butler
Craig Butler
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
