Question about Roper RAS8445KQ Top Load Washer
My roper top loading washer agiatates and spins out the water, however, when it finishes the spin cycle it makes a thump thump thump sound for about 8-10 secs. It is like it is trying to stop but is having a hard time.
  • Roper Master
  • 2,605 Answers
Hi, Welcome to FixYa.
Based on your description this is what it sounds like. 1) The basket drive block has worn or come loose and the spin tub from the basket drive is "clunking" as it skips by the notches in the block. 2) The basket drive spin tub may have broke from the hub/base or both are worn as a result of prolonged "thump, thump, thumping". Hopefully the prior not the later. **Unplug the washer from the wall before attempting any DIY service/repairs...safety first** You'll need to remove the agitator, (the cap) and then the 9/16" or 1/2" or possibly a 7/16" bolt in the center...it may look nothing like a bolt, it may be a plastic block but it still screws off counter-clockwise.
Pull the agitator and inspect the block/hub in the center directly below the agitator which holds the basket in place. if it looks worn or is out of place, you'll likely need a tech.
If you can tackle it yourself, the block number is #389140. You want to be sure the spin tube still has the two notches in it though, otherwise the changing of the block will be futile.
Check that, and let me know how it goes and what you find.
Good Luck macmarkus :)
Posted on Aug 01, 2010
Thumping sound without spin
You can check the belt, pulley, and the motor
Feb 01, 2014 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag Top Loader Thumps When In Spin Cycle
My guess is that one of the three counterweights have separated from their support. Probably rusted away.
36 years is quite a feat. Today's machines would be lucky to 1/3 of that life.
Sounds like its time to go shopping.
Do you have an anniversary coming up?
Ladies love washers for an anniversary gift.
May 24, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Roper rtw434osq0 not spinning/draining water
Set the timer to spin manually and turn it on.
Does it spin?
If not,
Your lid switch is bad and must be replaced.
If yes it does spin.
The timer is bad.
Mar 12, 2009 | Roper RAX4233PQ Top Load Washer
I have a top load Roper washer that won't spin.Any ideas?
That sounds like a bad drum bearing, check and eventually replace the drum bearing.
Dec 28, 2008 | Roper RAS8445KQ Top Load Washer
Roper RAX7244EQ1 Vibrates during spin cycle
Dear customer
Please perform the following checks
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Please rate this,Thank u
Nov 21, 2008 | Roper RAS8445KQ Top Load Washer
Washer makes loud thumping after finished spin cycle
I replaced the drive block and it solved my problem. (thumping noise at the end of spin cycle) Easy repair. Videos on utube show all the steps.
Jun 07, 2006 | Whirlpool LSR7333 Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
303 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
