Question about Car Audio & Video
AMp keeps blowing fuses
Hi there, i have a rf2002 amp that ios wired correctly. however for some reason the amp itself keeps blowing its external fuse. literally as soon as i put oin in it fries. any ideas on why this is happeneing and if so how can it be fixed? thanks in advance i have a kenwood kac-7203 amp and it keeps blowing fuses.if i keep the volume low its fine.when i turn it up,fuse blows and no more bass!all i did was disconnect a 1400 watt infinity amp and simply installed this kenwood amp,i checked the ground and it seems fine.can you help me plz?
  • Anonymous May 13, 2008
    yeah i ahve the same problem its when i adjust my bass is when it blows
  • 1,689 Answers
When any amp blows fuses, this indicates that something is drawing too much current. The most common cause are components in the output stage and driver stages that have become defective.
On the amp that is blowing the fuse with the volume being turned up, this means that the output stage is partially working. The short or over-draw of current must be in the output stage, or what is loading it. It is possible in this case that a crossover in a speaker unit is defective, and is drawing too much current. I have seen this with especially sub-woofer crossovers, and the driver itself. Subs pull a lot of current because of the amount of drive power required to have very strong bass sounds. Other than that, this still does not rule out the possibility of the problem being defective components in the amplifier.
Jerry G.
Posted on Apr 25, 2008
My pioneer SX 20 blowed fuse and unhooked all external wires and keeps blowing fuse
If you've disconnected everything and the amp is still blowing fuses you'll need to have a technician look at it. Most commonly I find that condition caused by a failure in the power supply section of the amp.
Good luck.
Mar 21, 2015 | Cars & Trucks
What size fuse amp do ineed 4kompesser2000 driver seat ajustment
Fuses are incorporated in circuits for a good reason; to protect components and wiring in the event of a current overload.
If a lower rated fuse is installed in a circuit, it will blow under normal load conditions as it is rated for lower power usage.
If a higher rated fuse is used in a circuit, it would not blow before a overload causes damage to circuit components or causes a overheating condition and possibly a fire.
Therefore, it is essential that the correct fuse be used in the circuit it was designed for...
Your particular auto may have a fuse diagram in the owners manual, or printed iside the cover to the fuse panel - if not, ask a dealer for the correct fuse designation. The fuse diagram should show the size fuse needed for the seat controls.
IF the fuse you are blowing is the correct size, STOP using the seat controls until you have the problem troubleshooted by the dealer or a good mechanic.
Good Luck. JWM
Feb 22, 2015 | AMP Fuse Wiring Panel
Fuse 18 keeps blowing
Once a fuse blows,it does so for a reason
Common Sense
In a 60 year driving career you have maybe 6 fuses blow
Replacing them 5 out of 6 time they blow again
Ask yourself why
You need to find the most logical item in that circuit
& start testing & that usually requires a wiring diagram
or you have no map or now where to start any testing.
Something overloaded a circuit find it & replace it or
resolve the wiring issue
Aug 03, 2013 | 1994 Ford Mustang
My 1800w kenwood amp keeps blowing the fuses
there are 3 reasons your amp is blowing fuses. The first is that it is no good. If amp plays at all then that is not the case.
Then it is more likely 1 of or both of these 2 reasons.
  1. The fuse is too small for the load you are putting on it and needs a bigger one.
  2. You have the amp wired to an ohm load that is too low.
Try upping the fuse to the next size up.
If the amp just blows the fuse and will not work at all. It may be shot.
Dec 02, 2009 | Kenwood KAC-9104D Car Audio Amplifier
3amp fuse keeps burning out
when a fuse blows, its telling you that theres a fault. this could be a loose or broken wire.
or alternatively, the fuse rating is too low. you could check the wires are tight. and also possibly try fitting a 5 amp fuse. check first that the fuse is rated correctly for the appliance. usually 3-5 or 13 Amps.
Mike @ compurepair.
Nov 17, 2008 | Goodman GMS90703BXA Heater
Blowing of fuses
The reason your blowing fuses is the amp needs at the least a 150 amp fuse on the wire that runs to your bat. There are fuse blocks that you can put 4 40amp fuse and theres the high dollor ones that you can put all the way to 200amp. When you trun up your amp its drawing to much current for the little 40 amp fuse that you have and will blow it everytime. I recomend Running a 4 gage wire to bat and ground with same. Get you a 150 or above amp fuse from a car audio shop somewhere. anyway sounds like from what you decribed, theres nothing wrong with your amp just the wires and fuse are not big enouf to handle the current that your amp pulls.
Oct 21, 2008 | Lanzar OPTI 50c Car Audio Amplifier
If it blows fuses only after the remote voltage is applied, the amplifier likely has shorted output transistors.
Let me know if you have any other questions.
Aug 30, 2008 | Rockford Fosgate RF2002 Car Audio...
Keep Blowing Fuses
Sounds like the amp is shorting somehow. You are obviously shorting out somewhere between the battery and the amp. Are you sure you grounding location is a good one? is the fuse blowing only when you turn the stereo on? Something is not hooked up correctly.
If the fuse at the battery is blowing then it's a short.
If the fuse on the amp is blowing then its probably a bad amp.
Jun 12, 2008 | Kenwood KAC-728S Car Audio Amplifier
40amp fuse blows
Measure the DC voltage across the B+ and ground terminals as well as across remote and ground. If you have less than 11 volts when the amp tries to power up, the amp could be shutting down due to low voltage.
If the voltage remains near or above 12v, disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down or blows the fuse when you apply remote voltage (turn the head unit on), the amp likely has blown output transistors.
Nov 24, 2007 | Rockford Fosgate P3001 Car Audio Amplifier
Hi You can refer to my detailed solution above...if you still have issues please feel free to contact.
Feb 15, 2007 | Kenwood KAC-7202 Car Audio Amplifier
Car Audio & Video Logo
997 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
