Question about Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
Why wont my bissell proheat 2 pump out water - Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Sep 04, 2010
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
My Bissell proheat wont vaccum up the water when cleaning the carpet
1) see if therea are water with the properly mixing
2) lint trap clogged repair
3) pump is prime, test it
4) pump belt worn, replace
God bless you
Jul 06, 2012 | Bissell 8910 ProHeat Clear View Upright...
I have a bissell 9200 proheat X2 wont **** up water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
r
Aug 03, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Is not pumping water through
heatman101
8f
Aug 01, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Bissell Proheat is not spraying water. What is causing this? and will it be expensive to fix?
It is very simple and inexpensive to fix. All you need to do is replace the pump belt. Here is the belt you need:
Bissell Proheat Pump Belt
May 20, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell Proheat 2x. The pump wont prime. The water is full and the tanks are sealed. Second time we hace used it.
I had the same problem. I took the whole thing apart and cleaned all the lines, water heater, brushes, etc. After putting it together the tools sprayed great and the side sprayers but the water tank would not allow the water out. THEN I saw this. http://www.bissell.com/FAQDetail.aspx?id=1122 and I was finally able to figure it out. So what I found out was that the water tank gasket was damage. lol
Dec 21, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissel proheat no water will dispense
Check all your hoses and make sure that they are not blocked and everything can run freely through your sstem
Apr 25, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell carpet shampooer
First check that the top cover on the back side hasn't come loose. Sometimes the plastic around the screws break away and the top starts to separate, raising the tank, and no spray. Make sure that the gaket is on the valve at the bottom of the tank and not sitting loose in the hole. Check the pump belt. The pump may be bad.
Jun 15, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum Logo
128 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
