Question about Mr. Coffee TCX83 Coffee Maker
Hello, the spring loaded arm under the coffee basket broke part way off. Now the unit a Mr. Coffee TCX 83 has a small leak while brewing. Can I purchase a new part? If not any idea for a fix? Thanks. ****
4 Suggested Answers
  • 17 Answers
SOURCE: Mr Coffee
If your coffee maker is under a year old, take it to a authorized service center for free repair or replacement.If its over a year then the complete heating element assembly must be replaced.However, this part is only available to authorized service centers and is not sold to consumers.
Posted on Nov 07, 2007
  • 1214 Answers
SOURCE: Mr Coffee stopped brewing
Sounds like there are a couple of problems -
First, are you certain that the coffee basket is clean? If the coffee basket has a valve on the bottom that allows you to remove the carafe to pour a cup of coffee, make sure the valve is clean. Being dirty would cause it to trickle coffee slowly into the carafe, and will hold coffee in the basket too long.
2nd, you may need to flush the water heating system as they can become corroded with precipitated solids from the water.
To do this, mix 1 part vinegar to 2 parts water in the carafe. Pour into the coffee maker and tell it to make coffee. Do this a couple of times, using a fresh mix of vinegar and water each time. Pour the used mixture down the drain.
When you feel it is clean, follow it up with a fresh pot of water. Then wash and rinse the carafe.
The coffee maker is now ready for it's next use.
Posted on Jan 30, 2009
  • 186 Answers
SOURCE: my mr. coffee coffee pot won't brew. it will make
Try running a cupfull of vinegar through it followed by a pot of plain water.This will remove any hard water deposits which may be blocking the tubes.
Posted on Nov 05, 2009
Why does my mr. Coffee decanter leak?
First I'm not a Mr. Coffee tech but I have worked on similar machines.
* Most decanters are made of tempered glass and unless cracked it should not leak.
* Most overflowing pots are caused by over filling brewing tank. This can be caused by re-pouring additional water into the brew tank. (automatic brewers may have a leaking water valve - call your vendor for service)
* Partial brewing (taking coffee from a brewing pot) and then putting in more water.
* Removing the pot BEFORE it stops dripping. It leaves a puddle of coffee on the warmer plate
*Over filling the water tank. Most times the extra water will spill out the back. But some may overflow into the basket area then the warmer plate.
* Follow the MFR brewing instructions for filling.
* All brewers should stop water drips after brewing. If you get a constant drip AFTER brewing then have the brewer checked or replaced. Call your vendor.
Aloha, ukeboy57
Jan 15, 2018 | Mr. Coffee Coffee Makers & Espresso...
Does thge mr coffee brew basket has a spring on the bottom?
Yes it does. The spring is around a plastic plunger that closes the opening to the brew basket when you remove the glass carafe during brewing. When you put the carafe back in it pushes up on the plunger the spring is around and lets coffee flow again.
May 01, 2017 | Coffee Makers & Espresso Machines
My mr coffee pot will not stop brewing when I pour a cup of coffee while it is still brewing. My model has the brew/pause feature
There may be grounds stuck in the spring loaded gadget next to the pot's pour spout - Remove all interior parts and rinse under water.
Sep 29, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
The coffee will go all over the counter. We did not get a manual with the coffee maker. Could I possibly be setting the pot incorrectly on the plate?
Check the following:
1. Make sure that you are using the correct size coffee filter in the basket. Only one filter is needed to allow proper drainage.
2. Check the spring loaded button on the bottom of the coffee basket. Remove the basket, put some water in the basket, push the button up to make sure the water is released from the basket.
3. Put the basket back in place, insert the carafe and check to make sure that the top of the carafe cover pushes up the button on the basket to release brewing coffee.
If all these check out, then there is an internal leak and the unit need to be repaired or replaced.
Aug 11, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
Coffee spilling out the sides of the carafe
I had a Mr Coffee that did that. It was running across the brew pause arm and making a mess. I discovered that the position of the carafe had a lot to do with it. If I brewed with the handle pointing out towards me, very little leaked out. I finally tore the brew pause arm off of the bottom of the brew basket. I works great and hey, I can wait ten minutes for a cup of coffee! However, if yours is new and doing this, I would contact the company and see if they'll make it good.
Jan 04, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
I have a FTX49 Mr Coffee Maker purchased 9 months ago. It just started to leak in the front area where the round burner casing meets the tall front face of the unit (the groove area on both sides??) What...
There is a lever in the back of the carafe area that pivots and controls a spring loaged valve on the bottom of the removeable filter basket. This lever breaks easily. Pull the filter basket out and you can see the lever hanging down into the carafe "bay". (assuming it's not broken off entirely).
When you pull the pot out during brewing, the lever swings forward and allows the valve on the bottom of the filter basket to close. This shuts off the flow of coffee to avoid drips. The plastic lever is held in place underneath the valve by two round tab "ears". One of these ears can break off, causing the level to hang at an angle. This means the filter valve never completely opens, even if the pot is pushed in all the way. During brewing, the filter basket can't drain into the pot fast enough and overflows.
I fixed mine by going ahead and removing the damaged lever and then wedging the valve open. The spring loaded valve has a little drip "Spout" which hangs underneath the filter basket that directs the coffee into the pot. You can push in on the back of the drip spout and wedge something into the two slots at the back to hold the valve open. This let the coffee flow freely during brewing.
Oct 15, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
The basket bottom spring-came aprt
it's broke. you didn't say what kind it is, but it's probably cheaper to by a coffee pot
Aug 06, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Cuisinart DGB-300 coffee maker brew pause valve
No one has just the individual part, but you can get the whole brew basket with the part included on Cuinart's website, or by calling them.
Feb 03, 2009 | Cuisinart DCC-100 Coffee Maker
How to
Fill the pitcher with water to the water level park on the pitcher and pour into water intake in the top of the tea brewer.
Fill pitcher to ice level mark (if there isn't one, put in about 2 - 3 trays).
Make sure that the brew basket lever is closed by pushing in then down.
Put 6 - 10 regular tea bags in brew basket and place brew basket on top of pitcher.
Slide the pitcher with the brew basket under the machine where the water comes out and make sure it is snug. Turn machine on.
When the machine is done brewing, the unit will shut off automatically.
Carefully slide the pitcher away from the machine and release the lever. This will let the tea pour into the pitcher.
That's it! Just don't put the pitcher, lid or brew basket in the dishwasher - that's how I ruined my first one.
Jan 24, 2008 | Mr. Coffee Iced Tea Maker TM1S
Mr. Coffee TCX83 Coffee Maker Logo
423 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
jmt
Level 1 Expert
Craig Butler
Craig Butler
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
