Question about Dometic Rooftop RV Air Conditioner
Ihave a probllem with the front dometic A/C not starting it is coupled with front dometic lp gas heater with wall thermostat.(rear has identical) Switched waqllthermostats and power boards on heatersno start. there is 7.? amps on the red wire at the rear thermostat none at the front thermostat.and there is 120 volts st the front A/C ..I dont Know wher the 7.?amps at therm. is supplied from I hope you can help me get the front A/C working.remember when I turn the thermostat on nothing happens & all fuses that I checked are good.Charlie fowler ..E Address is fowler7098@charter.net
  • 532 Answers
Hi
There is a fuse inside the control panel of the AC itself. You have to take the cover off (from inside on the ceiling) and look up in there with a flashlight to find it. It is usually a very small amperage fuse. Maybe a 5 amp.
Thanks for contacting Fixya.
Posted on Aug 01, 2010
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
HOW TO TROUBLESHOOT ROBERTSHAW GAS VALVE
check the pressure switch if voltage to both sides its ok then check the gas valve to see if voltage at brown and yellow wires
Oct 14, 2014 | Honeywell Robertshaw Grayson Gas Valve Lp...
Gas conversion lp kit 8927 has 2 pilot orifices...I only need 1, correct?
The smallest pilot orifice is used for LP. Make sure you read the instructions thoroughly. Usually the gas valve pressure regulator is disabled and the burner orifices are also changed. Good luck and hope this helps.
Aug 11, 2014 | Williams Wall Heaters: 30,000 Btu/hr...
Last year my dometic rv fridge would run fine on propane then up and quit cooling, the freezer would warm up and the pilot light was still on. When I turned it off for 1/2 hour it started to cool with no...
Here is an interesting possible problem to look in to
First a bit of background on LP gas
Your LP system operates on 1/2 lb of pressure Not much more than a breath of air. Keep this in mind for a minute.
A lot of RV's have been built over the years using rubber hoses to connect LP gas to water heaters, furnaces, and refers.
Over time rubber and LP gas create an oil, if you have a low spot in your rubber line that oil will collect in the low spot - - Remember the 1/2# of pressure from earlier? Does not take a lot of oil build up to over power the 1/2 # of pressure and now you are not getting LP gas to your refer.
This is one possibility. The lines will need to be removed from the refer and other low setting items like the water heater and furnace also from the LP tank regulator and the using NO MORE THAN 10 pounds of air pressure blown out. BE VERY CAREFUL this oil is some really nasty stuff - cover the ends of the lines with a cloth in a plastic bag with some holes poked in the bag and rubber band it on.
But first lets look at some other options
Your refer has to have 12 volt power to it to operate
90+ % of all 12 volt issues are grounding problems.
Make sure you have at least 12 to 13 volts to the refer and that you have a good ground.
Next Are you getting gas flow to the burner?
If you are getting gas try changing your thermocouple They run a couple of buck and is an easy test.
If you have 12 volt power and gas have you noticed an ammoina smell?
This model has been known to lose the cooling unit
Hope this helps
Coyote
Mar 24, 2010 | Dometic RM2620 Refrigerator
Reliance gas water heater 640ycrs pilot light will not stay after 1 heat period replaced thermal couple has gas thermal switch
if water heater will heat a tank of water before the pilot light goes out you need to replce the gas thermostat
Mar 04, 2010 | Reliance & 30 Gal LP Gas Water Heater
I have a suburban lp furnace and duotherm air/heat pump roof unit. duothern thermostat. 20 amp breaker kicked ( reset breaker) & furnace quit. NOW furnace fan comes on but does not light, and the front...
I'm not sure what the problem may be but you could try calling All Seasons RV Appliance Parts & Service. There number is 1-800-344-0673 they have helped me in the past. That and there tech calls are free so it wouldn't hurt to give them a call.
Jan 23, 2010 | Dometic Rooftop RV Air Conditioner
I have a Dometic RV refrigerator Model # NDR1062 and it works with the electric power with the generator on (not on battery)but will not work on gas. The gas unit clicks like it wants to start but will not...
My best guess without seeing it is you are not getting gas to the unit
Break the gas supply line at the gas valve with the LP turned on and see if you are getting LP gas
Without the proper water column inch meter it is impossible to tell if you are getting the right pressure, but if your stove top, heater and water heater work then I sill guess you have rubber hoses feeding your refer. Propane and rubber build an oil that will over time plug the supply line and not allow LP to reach the refer. They have to be cleaned out and it is a messy job
Dec 19, 2009 | Dometic NDR 1062 Refrigerator
I have a direct vent wall heater that I switched from a larger lp tank to a double 100 lb cylander tank, now the pilot will light but when I turn the thermostat up the heater won't start.
If you can jump out the thermostat connections on the gas valve and the heater still does not turn on, check to make sure the thermopile is well into the pilot and getting hot. If it is, replace it. That is the safety for the main burner.It will have two wires wrapped with metal and note which terminals it is connected to on the gas valve.
Nov 18, 2009 | Empire Heating & Cooling
Dometic Rv fridge will get cold on a/c power but
does the flame ever got out if not ,the tsat is not the problem. It could be that the flame is not hot enough or the flue has a restriction
May 18, 2009 | Dometic RM2620 Refrigerator
Cozy natural gas heater Mod # CLV 335A
get someone to check the gas pressure that is poss problem gas company if nat and the lp supplier can do it
Dec 17, 2008 | Cozy Enclosed Front Console Heater 20,000...
Dometic Rooftop RV Air Conditioner Logo
22 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
