Question about Xerox CopyCentre C118 Copier
How can i chage to ledge tray 2 - Xerox CopyCentre C118 Copier
    President:
  • 2,072 Answers
Adjust the tray guides then confirm the size when the message comes up after the tray is reinserted, Then
  1. Press the [Log In / Out] button on the Control Panel.
  2. Press the [Select] button below the Display Screen to select 'System Settings.'
    NOTE: There are three unlabeled [Select] buttons located directly below the Display Screen that are used to select items on the screen. See the Related Items below for additional information on navigating the Control Panel.
  3. Enter the System Administrator LoginID using the numeric keypad, and then press the [Select] button to select 'Confirm'.
    NOTE: The default LoginID is 11111. If the LoginID has been forgotten, a service call must be placed.
  4. Press the [Select] button until 'Copy Settings' is selected, and then press the [Enter] button on the Control Panel. The Copy Settings 1 of 2 screen will be displayed.
  5. Press the [Right] arrow button on the Control Panel to display the Copy Settings 2 of 2 screen.
    the [Select] button until 'Paper Type' is selected, and then press the [Enter] button.
  6. Press the [Select] button until the required tray is selected, and then press the [Enter] button.
  7. Press the [Select] button until the correct paper type is selected, and then press the [Enter] button.
  8. If necessary, repeat steps 7 and 8 to set the paper type for another tray.
  9. When finished, press the [Log In / Out] button to return to the default screen
Posted on Aug 02, 2010
Where is the signal flasher located on an 03 ultra classic
On an 03 bagger it will be under the seat. You'll have to remove it. Under the seat is the battery you should see a little silver clip towards the back ledge of the battery tray. That's the turn signal module. Remove the clip and pull the unit up amd out.
Jan 08, 2015 | 2003 Harley Davidson FLHTCUI Electra Glide...
REMOVE WATCH BATTERY
some watches have a rectangular ledge on the back which gets contact with your wrist.. the ledge is about half a centimeter in length and you can use a COIN to twist the ledge until the battery cover gets off and simply remove the battery with any thin hard tool - could even be your nail. and viola. for other watches the screw needs to be removed with the appropriate size
Apr 03, 2012 | Watches
How do I open a brighton venezia watch? Can't find normal little ledge to pry it open.
mcdevito75 here, Besides a ledge to pry open, some watches have a cutout in the cover that matches the case itself, very hard to see, it should look like a 1/2 moon cutout in the cover and case.
Jun 26, 2010 | Watches
My icemaker isn't working. There's no water in the trays and it doesn't sound like it's trying. The model is tbx18ci.
Not sure what setup your ice maker has to let it know when the ice tray is full, but some ice makers have a bail that goes up with rising ice levels. When the ice bucket fills up, the ice maker shuts down.
Lifting the bail up all the way until it catches on a small ledge turns this type ice maker off. If ice is allowed to stack in the bucket too high, or is shoved back as someone scooped out ice, the bail may inadvertently have been pushed onto the ledge.
Bottom line; check whatever method your ice maker uses to turn off ice production when the bucket is full to see if it is in the OFF position.
Oct 13, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
Hi i need to chage my side mirror of my 95 buick lesabre, i recently was clipped by a truck so it needs to be replaced, im not really sure how to take it off, will i have to take the whole side panel off?...
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls. Then you can access the bolts that secure the mirror onto the door
Jun 26, 2009 | 1995 Buick LeSabre
The fittings and bodywork on my car rattle like a bus when going along the road. Is there any way to prevent this?
The plastic ledges either side of the rear parcel shelf are each held by three 10mm bolts. Take them off and stick pices of cloth to the back of them so that when you bolt them in the cloth is between the ledge and the interior trim. Wedge bits of rubber between the front of the ledges and the moulding either side of the rear seat back to stop the ledges flexing under the weight of the shelf. Put sticky tape on the rear shock absorber mounting covers in the boot to keep them still. If you have rear speakers in the ledges they may vibrate and need little bits of rubber to stop this. Check that the front passenger seat isn't rattling in its runners when unoccupied. I cured this by bending the runner channel slightly with a hammer and a piece of strong tube (an old jack handle). The sides of the dash moulding may rattle against the windscreen pillar mouldings-jam a strip of rubber between them. The cup holder (near the ash-tray) is a terrible rattler-wedge it with rubber or sponge tape. The rear view mirror needs atiny bit of rubber pipe between the front of the bracket (where there is a little blob sticking out) and the windscreen. I hope this helps.
Apr 25, 2009 | 1993 Suzuki Swift
Trying to print an invitation
1. load your blank card in rt side of the tray
2.keep your card matter left top of your computers file then try
first you can try it with your 8.5" x 5.5" peace of papper.
this can help you
Mar 08, 2008 | HP OfficeJet 6210 All-In-One InkJet...
U6446-900
from the underside: 1. remove 4 screws holding agitator cover in place 2. remove 2 screws (black screws) holding hose retainer in place, pull hose out through top 3. remove three screws, 2 long, 1 short holding top cover: short screw is at center of inside of brush housing, long screws are inboard of wheel axles, and slightly forward (all of these screws are aluminum colored) 4. from inside surface of each side, at approx the center, locate and push down on ledge inside right and left inside with a screwdriver to slightly displace the plastic ledge that holds the cover on; this ledge-lock-detent can be released with your fingers. You'll have to support the drive mechanism to allow the top housing to drop free. 5. remove housing, turn vacuum over, then go find the torx driver you need to disconnect the cable. Good Luck MB http://in4m8ion.com
Aug 19, 2007 | Hoover U6630-900 WindTunnel Bagless...
Xerox CopyCentre C118 Copier Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
